#589 | |
that lft change probably caused by imbalance between pi and di injector scaling. I have heard of guys setting the di\pi ratio tables to full pi then full di and adjusting the pi scalling so fueling matches better so the transition between pi and di is smoother. i quoted moto mike in the tune tweaks thread he had a good explaination of pi and di http://www.ft86club.com/forums/showp...2&postcount=17 |
#590 |
with our crappy fuels it lets you run more timing advance, the guys in southafrica on 95 ron could add 2to 3 degrees timing back in just from running full di till 7200 instead of 5200 in stock tables. on petrol na you not getting near the 6 ms limit moto mike quotes but on e85 you do
#591 |
Drives: JAWS
@Wayno @steve99 @Kodename47
Just did this log, changed only the MAF scale for now, wanted to see what changes that alone would make. Now I see the 3.91 LTFT you were referring to. It's only got probly 10 miles of learning, but how's the AFR look? Slight FLKC but it's 80F out and I was in city driving it hard repeatedly. http://datazap.me/u/joshbustos86/206...-8-10-11-12-14 Any reason to worry about using full DI up to 7200? extra wear or stress on injectors? Last edited by JB86'd; 08-21-2015 at 05:17 PM. |
#592 | |
wayno tunes smooth the timing he adds base timing b to knock correction max A and then smooths the lumps and bumps, he has found that works better. anything we change like di\pi ratios may have some other effect we dont know about, oem guys do thousands of hours testing, but they also have other constraints like emmissions. Anyone on the E85 tunes runs the injectors 30% harder(longer injection time) and they run the full di up to 7200 not 5200 like in petrol tunes. dont know of any issues yet. |
#593 | |
Drives: JAWS
LTFT looks pretty spot on..AFR is definitely leaner than before the changes, but its much closer to Commanded AFR now. I have some knock, I'm guessing from the slightly leaner AFR and from it being about 85F out. I'm going to pull minimal timing in the problem areas and hopefully that will sort it out. http://datazap.me/u/joshbustos86/206...3-4-8-10-12-14 @steve99 @Kodename47 |
#594 | |
Drives: Toyota 86 GTS
You could copy the top half of my base timing if you want, say from 4600 and above. It will end up smoother than if you start filling your timing map with pot holes. Should look like this. http://datazap.me/u/wayne/98-v844-3-...&zoom=829-1034 |
#595 | |
Drives: JAWS
#596 | |
First you should get closed loop scaled really well the traditional way. Load limits only come in during open loop. If an area is running rich, you can lower the load limits until the amount of air gets to the desired mixture in the OL fueling table. Or vice-versa if you're running lean because you're bumping into the limit.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
#597 | |
Drives: JAWS
I think I'm going to load the standard OFT stage 2 tune, and try to do the closed and open loop scale after I put some miles on it. I've been reading up on MAF Scaling, and have downloaded the VGI scaling program. It's a bit over my head, as I understand how to log and what everything is, but setting all of the limits and settings in the program is confusing to me. I guess I'll keep experimenting. |
#598 | |
#599 |
Slow Learner
Drives: 15 Halo FRS
I have currently been running the Stage 2 EL E85 map on a entirely stock car.
I have some very basic understandings of tuning but am a total novice. I've been reading all of the information I can, especially all of the links that @steve99 has provided regarding the OFT and while there is a lot of great stuff It is not contiguous and I have a hard time making sense of it all, but I'm having fun and am slowly starting to absorb some of this. I have a local source of E85 and switched over a couple of days ago. At this point I have about 100 miles of easy to moderate driving on the tune so I'm assuming that the ECU has had time to learn and let trims settle. Here is a log I just recorded this morning and I'm wondering if some of you more experienced guys would look at it and make sure there is nothing abnormal going on or anything I should be concerned with. The car drives great and has not given me any issues. Just really looking to learn more and would appreciate any comments or advice. http://datazap.me/u/rustysocket/e856...1-4-7-11-13-14 This log was recorded this morning as I got on the freeway and then cruised with the flow of traffic. I noticed near the end that my IAM dropped a little from 1.00 to 0.96 Thanks for everyones help. Comments appreciated. |
#600 | |
odd bit of knock correction of -1 or less and iam of 0.9x nothing to worry about, it will likey go away with next fill of e85. ltft less than 10% all looks normal for car on oft e85 tune. |
#601 |
Drives: Still deciding
Got my OFT in today so went a head and updated, made a few runs. No reason to suspect anything is off but would appreciate you guys taking a look into it.
Running: JDL UEL JDL Overpipe JDL MIDPIPE PERRIN Catback OFT Stage 2 uel 93 oct Did a normal drive and a little spirited. Here you go: http://datazap.me/u/jph11/log-1441070030?log=0&data=1 Last edited by jph11; 08-31-2015 at 09:19 PM. Reason: forgot to include map |
#602 | |
little tiny bit of knock occasionally just dropped your iam to 0.97 from 1, looks like a hot day 100 plus intake air temps nothing to get worried about, maybe try different brand of fuel or if rearly kean maybe alter the intake air temp ingnition retard tables but no real need its very minor. see links below on logging ect |
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
