08-10-2022, 10:18 AM | #589 |
I have been actively looking for a GR86 and after seeing that video I'm going to hold off. I had an engine failure in the last gen from the springs before the recall was announced and that wasn't fun. It took 2 years to get my money back from installing a new engine and don't want to go through anything like that again.
08-10-2022, 10:53 AM | #590 | |
Drives: 2022 BRZ sport-tech
Having said that, there is a degree of "gamble" regardless of the action you take so i am not advocating anything here.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
The Following User Says Thank You to Petah78 For This Useful Post: | Ultramaroon (08-10-2022) |
08-10-2022, 11:35 AM | #591 | |
We have a pile of amateur sleuths (myself included) giving opinions based upon theories while they will have an actual team of experts armed with facts.
The Following 9 Users Say Thank You to Tcoat For This Useful Post: | CincyJohn (08-10-2022), Dadhawk (08-10-2022), DylanJZA (08-10-2022), gcmak (08-10-2022), justinco (08-11-2022), Opie (08-16-2022), Panda Grahams (08-10-2022), Petah78 (08-10-2022), WolfpackS2k (08-11-2022) |
08-10-2022, 11:45 AM | #592 | |
Drives: 2022 MT Neptune GR86 Prem.
I wouldn't mind seeing a recall that replaces the oil pan and timing belt chain cover RTV with a gasket and would likely have it done. As opposed to the valve spring recall, I don't think it is likely that even a dealer tech would return it in worse shape than it was when it went in. Of course, I wouldn't want to be one of the first few at my dealership to have it done... |
08-10-2022, 11:52 AM | #593 | |
All the Subaru engines now use the same method of sealing and there is nothing wrong with it when it is done properly. They just need to consistently do it right!
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Dadhawk (08-10-2022), strat61caster (08-10-2022) |
08-10-2022, 12:06 PM | #594 | |
Personally, I will just endoscope the pan on my oil changes and do UAO for the interim to see if anything is up. But this also means I will have to perform oil changes myself which I will sure as hell document the crap out of. And I will send it harder than ever (though not abuse, must add disclaimer in case my warranty gets denied....lol) to make sure to expose the problem, if there is one.
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 Last edited by Petah78; 08-10-2022 at 12:19 PM. |
The Following User Says Thank You to Petah78 For This Useful Post: | Tcoat (08-10-2022) |
08-10-2022, 12:14 PM | #595 | |
Drives: 22 BRZ limited
As for the second, I agree with you that the amount of sealant appears to be the same amount that they use on other engines. The mid pan an oil pan assembly appears to be unique to the BRZ, and I suspect that they may just fit together a bit more precise(or thinner mount flange) causing the squished out rtv to dangle more than on the other engines. I plan to run out the warranty, then pull the engine and re-seal if I have no other issues. |
08-10-2022, 12:36 PM | #596 | |
Drives: GR86
They said Toyota hasn't sent them a peep about this and that they would expect that if Toyota suspected there may be a problem there would have been some "keep an eye out" kind of message. Not sure whether I totally believe that since I know how businesses work (and in particular, how damage control works regarding not sending out messages that will inevitably leak to the public). But in any case, the service manager recommended just waiting for the next service interval and having them inspect for loose RTV then. It's not my only car so if it takes a little while to replace the motor IF it seizes before (or after) then it's not the end of the world. Any car can die at any time from any number of causes. Nothing is guaranteed to run 10 miles without a problem, let alone 100,000. Live your best life, take every day and every mile like a gift, and whatever else would look good embroidered on a wall plaque. |
08-10-2022, 12:53 PM | #597 | |
1st86 Driver!
So RTV is also the "fix" for the recent Hummer recall:
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
08-10-2022, 01:34 PM | #598 |
extra what?
The Following User Says Thank You to Ultramaroon For This Useful Post: | Dadhawk (08-10-2022) |
08-10-2022, 01:39 PM | #599 |
Drives: '23 BRZ Limited
The car has a warranty. National attention has been brought to the issue.
I'm not worried about my '23 that should be here in a few weeks, neither should the rest of you. I'm just baffled that so many are still losing their minds over this.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
The Following 4 Users Say Thank You to OkieSnuffBox For This Useful Post: |
08-10-2022, 01:44 PM | #600 |
Drives: '22 BRZ
Because it's a HUGE pain in the ass if your car blows up 1000 miles from home?
The Following 2 Users Say Thank You to DocWalt For This Useful Post: | funwheeldrive (08-15-2022), joemysterio (08-10-2022) |
08-10-2022, 01:51 PM | #601 |
I get that, but you also have to realize, you are talking about an edge case. What you're describing isn't typical for most owners.
The Following User Says Thank You to OkieSnuffBox For This Useful Post: | Opie (08-16-2022) |
08-10-2022, 01:52 PM | #602 | |
Drives: GR86
There's cause for concern that it might be a serious issue for these cars, but we haven't yet gotten there. Maybe it's a few cars. Maybe it's significantly more than a few. We just don't know yet. Which means it's like every other thing in the world: it might break today, it might break tomorrow, it might break in 5 years. |
The Following 2 Users Say Thank You to Spektyr For This Useful Post: | Dadhawk (08-10-2022), OkieSnuffBox (08-10-2022) |
Tags |
oh no not again |
Similar Threads | ||||
New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! | steel86gt | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 14 | 03-09-2022 02:15 AM |
Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 07:09 PM |
Is my engine blown? | dallenj | Engine, Exhaust, Transmission | 39 | 01-30-2017 05:18 PM |
Blown engine due to 0W-20? | Benschneider06 | Engine, Exhaust, Transmission | 45 | 07-23-2015 03:33 AM |
Subaru BRZ complete engine gasket & seal kit 2.0L | JPxM0Dz | Engine, Exhaust, Transmission | 0 | 12-18-2012 12:11 PM |
