Old 11-13-2014, 01:58 PM   #575
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Originally Posted by calmtigers View Post
Do you mind taking a picture of the engine bay in its entirety I'd like to see what it looks like after you removed those covers.
I'll try to remember to do it tonight.
Also when is the "day of reckoning" weigh-in coming?
Once the HVAC system's out.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
The Following User Says Thank You to Anthony For This Useful Post:
calmtigers (11-13-2014)
Old 11-13-2014, 04:15 PM   #576
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Anthony View Post
It's actually 3oz lighter. But you're right though, I bet that R is unreasonably heavy. And who needs a gasket?
Ha I knew you had weighed them. I underestimated the difference in weight between steel and aluminum. That plate doesn't see any real load I am sure you can turn it down quite a few thous.
The Following User Says Thank You to King Tut For This Useful Post:
Anthony (11-14-2014)
Old 11-14-2014, 11:53 AM   #577
TWMPerformance
Drives: Manual Transmission, All the Way!
Love the motivation and strive in your build, awesome!
Renato
Team TWM Performance
TWMPerformance is offline   Reply With Quote
The Following User Says Thank You to TWMPerformance For This Useful Post:
Old 11-14-2014, 02:23 PM   #578
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
It could probably be made thinner and also have a lot of the material outside of the fittings for the hole and the screws removed. At that point though it might be better to be out of thin steel though as it'll be more stressed.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 11-14-2014, 06:44 PM   #579
Anthony
Weight Nazi
Anthony's Avatar
I'll be driving without underwear from now on to make up for it, so don't you worry.
Old 11-14-2014, 09:53 PM   #580
Anthony
Weight Nazi
Anthony's Avatar
I took these earlier today without reading your post, so I'm just now realizing you wanted the whole engine. But here are some closeups for now.
calmtigers (11-14-2014)
Old 11-14-2014, 11:57 PM   #581
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
Ah now I see what you were previously talking about, just curious was there a reason you didnt run all of the pulleys? You had posted something earlier about it being harmful to boxer engines.
Care to expand?
"I love dinosaurs so much that I’ve based my life on burning as much black melted dinosaur flesh as I can on a daily basis...even the screaming sound of prehistoric reptilians being burnt through any of the classic Japanese four cylinders gives me great joy."
calmtigers is offline   Reply With Quote
Old 11-15-2014, 03:00 PM   #582
Anthony
Weight Nazi
Anthony's Avatar
I did that based on this thread: http://www.ft86club.com/forums/showthread.php?t=71240
calmtigers (11-19-2014)
Old 11-16-2014, 02:21 PM   #583
phobos512
phobos512's Avatar
Hey so I went to pull the covers just now and when I take the two bolts out of the ECU it is able to freely rotate around a point below it. It looks like there's only a single lower mounting point, where it bolts to a bracket that then bolts to the engine?
Old 11-16-2014, 05:38 PM   #584
Anthony
Weight Nazi
Anthony's Avatar
That's weird. I have mine mounted in two places. I took it completely off, so I can't remember if it was only mounted in one place, but I don't know why it would be. Here's an overhead view.
Old 11-19-2014, 09:04 PM   #585
Anthony
Weight Nazi
Anthony's Avatar
The good news: tow hooks and Stiff Arms came in today!
The bad news: I just realized the tow hooks are meant to screw into the bumpers. I thought they went directly into the chassis.
I've already come up with a simple solution for the rear, I'll just need to stop by the hardware store tomorrow. The front though... no idea. I may have to return it.
Also... here's a fun fact I discovered: Raceseng Stiff Arms will save you 10.4 ounces, and a Raceseng rear tow hook weighs 10.4 ounces. So if you were looking to move 10.4 ounces from high in your engine bay to low in the rear of your car... there's an option.
Munki (11-19-2014)
Old 11-19-2014, 10:48 PM   #586
Munki
Enthusiast
Munki's Avatar
Drives: Toyota (Firestorm, MT)
Hmm I thought u were gonna wait for raceseng's strut tower bar?
Munki is offline   Reply With Quote
Old 11-19-2014, 10:51 PM   #587
Anthony
Weight Nazi
Anthony's Avatar
I changed my mind. I am waiting on that AC pulley bracket though.
Old 12-05-2014, 12:46 AM   #588
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
What battery terminals did u use?
I went ahead and just ordered the 5lb shori battery LFX36L3-BS12 but need to know where and what to buy for the terminals? Also how did u install urs? Custom tray? I tried to scan for pics but I didn't see any. Thanks!
FRSfan111 is offline   Reply With Quote
mother fu(king winning!
