Old 12-31-2014, 08:45 PM   #5853
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by Fizz View Post
No but I'll post up a photo later. How do you want the shot to be? I can't really take a pulley level shot without removing the bumper though...
Oh, that would be an awful lot of trouble. I hope we can avoid that.
Basically any shot that shows position of some feature on the tension arm relative to the alternator, or that idle pulley upstream of the alternator.
I know you have another idler pulley just downstream of the alternator but if you can get something, I'll take another picture of mine from the same angle.
Old 12-31-2014, 09:30 PM   #5854
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Originally Posted by Mechazawa View Post
I don't have one of these on the car, but it just sounds like normal belt "squeal" to me. Usually resolved by increasing tension or changing to a different brand of belt.
I remember it was common on miatas with gates belts in general. The concensus was that American made belts used a very slightly different profile from the oem Japanese made belts. You might try figuring out who the oem supplier is and sourcing the correct length belt from them. Or as someone else suggested go with a slightly shorter belt to increase tension.
The sound I'm getting is a little different from normal belt squeal. Usually belt issues sound like "screeeeeeech". Mine goes "squeak-squeak-squeak-squeak...." from 2000rpm onwards and increases in tempo with higher revs/speed. It only happens when engine is stone cold and goes away after about 5-10mins driving.
Fizz is offline   Reply With Quote
Old 12-31-2014, 09:35 PM   #5855
Ultramaroon
not playing cards
Is it a rubbery sounding, or a more metallic sounding squeak?
And does its period seem to coincide with a revolution of the one of the pulleys, or the full belt itself?
Old 12-31-2014, 09:44 PM   #5856
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Mine does this too when it's cold out. I eventually just said fuck it.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 12-31-2014, 10:23 PM   #5857
Ultramaroon
not playing cards
Haha... likely the wise choice.
Old 12-31-2014, 11:01 PM   #5858
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Not really sure how to describe it. Could be rubbery squeak. Kinda sounds like an old cheapo bicycle squeaking....lol.
Old 12-31-2014, 11:07 PM   #5859
Ultramaroon
not playing cards
Heh, I get that.
If you have someone rev the engine, does the squeak match each time you see the belt label in the same place, or does it go faster than the belt?
Old 01-01-2015, 09:14 AM   #5860
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Heh, I get that.
Had a good look at it and the timing of the squeak coincides with the rotation of the belt, so I think the issue is belt related.
Funny thing is, when driving the squeak tempo is around 2-3 sps (squeaks per second) and increases with the engine rpm. But....if I lift off the throttle with clutch engaged the squeak tempo goes rapidfire-fast, almost similar to belt slipping sound (but without the constant "screeeech" sound).
If I lift off the throttle with clutch disengaged there is no squeak.
Here's a picture of the tensioner you requested....
Old 01-01-2015, 11:12 AM   #5861
steve99
Try getting a spray bottle and spray some water on belt, if the squeak goes (or gets rearly bad) you will know its the belt. If it does not change then its likely something else
Old 01-01-2015, 11:36 AM   #5862
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Actually I think I might have a can of belt dressing somewhere in the shed...might give that a go. If the squeal stops after the spray, that would indicate belt problem/slippage.
Old 01-01-2015, 12:52 PM   #5863
Ultramaroon
not playing cards
Yeah, but then you end up with belt dressing everywhere. Blecch!
Old 01-01-2015, 05:12 PM   #5864
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Or just buy a belt ($20ish), slap it on and if it goes away you know it's the belt. That's what I did and it was the belt for me. If not then you have an extra backup belt, which you probably want anyway.
stockysnail is offline   Reply With Quote
Old 01-01-2015, 08:06 PM   #5865
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Good tip...thanks. But mine is only couple of weeks old. Getting the same belt might end up slipping again. Do you think a new belt in one size smaller would fit better?
Current belt: Gates K061015 - 2593mm outside circumference
Next size down: Gates K061010 - 2581mm outside circumference
Old 01-01-2015, 11:07 PM   #5866
stockysnail
Just the tip
According to what I've read in this thread, there have been mixed results and I didn't want to take the risk. I ordered a mechanics stethoscope so perhaps you might was to try getting one as well to pin point the problem area. Got a supposed good one on amazon. If your belt is only a couple weeks old then odds are it's not the belt, unless water is getting in the engine bay, but not sure if that would do it if the belt got wet.
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
