#5839 |
The noise is the clutch, basically what's happening is you have a sprung friction disk rotating between two plates (one on the flywheel, one on the pressure plate). When there is no load...like coasting to a stop in neutral, the transmission even in neutral produces some resistance to rotation. So basically the springs in the clutch are compensating for any of that drag from the transmission. When this happens the springs in the friction disk will give a little and then press the disk back to it's normal position. This back and forth motion of the disk causes light chatter.
My clutch does this all the time, but I'm running a stage 4 race clutch. I'd ask to have my transmisson fluid changed to a better fluid like Motul 300 Gear. If that doesn't cure it then it may be the clutch itself. |
#5840 |
Also I recommend not coasting in neutral, it's not what it was designed for. Occasionally doing it isn't bad, but when you have all those gears in the transmission spinning free you run the risk of causing gear lash and possibly breaking teeth if something sticks for just a second. The clutch was designed to be used when coasting...if you want to throw it in neutral before you come to a stop keep the clutch pressed in til you are actually stopped.
#5841 | |
#5842 |
Drives: S2000/FR-S
Okay so I drove around and it only happens when the ac is on! This also explains why I noticed this today. I usually drive around with ac off.
#5843 |
Drives: 2016 Subaru WRX
A lot of the guys are dynoing and either parking the cars or taking them to Firebird and parking them for the night. They don't want anything to happen to them till the shootout is over.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD |
#5844 |
Drives: 13 FRS
Not leaving our car there over night
#5845 |
Drives: Scion FR-S
If I just wanted to check out the cars what is the best time to show up I also wanna see Christian's z that day so gonna have to find time to do both
Sent from my SGH-T989 using Tapatalk 2 |
#5846 |
Mr. Jeff, what time do you think we will be done on Sunday? Not such a big deal but I will have a passenger that is curious
#5847 | |
Drives: S2000/FR-S
I did as you said and I didn't notice anything. mine stays around 600-700 rpm when in idle. running bone stuck |
#5848 |
#5849 | |
Drives: S2000/FR-S
thanks for your explanation. however I only notice this when the ac is on. that is why i noticed it today only. is there a link between the ac and clutch? Do you still hear this when ac is off? |
#5850 |
AZ FRS 86
I've heard it in the drive thu in neutral w/o the clutch in. When I press it in it goes away
@AZFRS86
#5851 |
AZ FRS 86
I'm guessing 2:00 ish. Meet at my house at 10:00 take a cruise then go get some pics and maybe lunch
@AZFRS86
| The Following User Says Thank You to jeffsides For This Useful Post: | Sivtec (03-15-2013) |
#5852 |
Rocket Bunny FRS
Drives: 2013 Rocket Bunny FRS
any meets established yet? Like Regular times and areas?
| Tags |
| arizona, fr-s, mesa, phoenix, scion, tucson, we need a subforum |
| Arizona Bill 'could' criminalize Internet Trolls | Giccin | Off-Topic Lounge [WARNING: NO POLITICS] | 18 | 12-30-2013 03:54 PM |
| Accessories page for Canadian BRZ owners | percyng | CANADA | 1 | 06-15-2012 08:27 PM |
| FR-S\BRZ owners give thumbs up to AE86 owners | Oriental Life | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 06-13-2012 04:12 AM |
| Home Sweet Home, it made it today. Delivery party 5/11 though.. | MarkRacerX | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 05-14-2012 04:24 PM |
