Old 05-29-2014, 10:07 AM   #5797
shif7i7down
Erected Member
Drives: frs
This is the only way it would be most accurate. However if you for whatever reason don't want to then I would pm shiv to make sure there wont be an issue.
It should be safe to leave the battery and controller untouched and just install intake and rom, then when I'm done with the base pull. Reinstall Rom and compressor right?
shif7i7down is offline   Reply With Quote
Old 05-29-2014, 10:42 AM   #5798
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
Yeah, that should do it. Just remember that you'll have to plug the hole where the Sound Generator used to plug into the intake tube.
In prep for my ESC installation (Removing Sound Generator, etc.), I simply used some thick plastic, folded it a few times, covered the hole and secured it with a worm gear hose clamp.
alexand3r is offline   Reply With Quote
Old 05-29-2014, 10:43 AM   #5799
fenton
Yup we did it many times. I would flash the base map for the stock run for sure. Don't forget to let it idle for a couple minutes between flashes.
fenton is offline   Reply With Quote
Old 05-29-2014, 10:46 AM   #5800
TM
TM's Avatar
Drives: DGM BRZ 6MT
Yup, you don't need to remove the batteries and controllers.
When I get my car dyno'ed this summer, here is what I'm going to test:
  1. Stock inlet tube - Stock tune
  2. Stock inlet tube - Stage 2 UEL tune
  3. ESC Compressor - Stock tune (ESC unarmed)
  4. ESC Compressor - Stock tune (ESC armed, DR only)
  5. ESC Compressor - Stock tune (ESC armed, WOT switch activated)
  6. ESC Compressor - ESC tune (ESC unarmed)
  7. ESC Compressor - ESC tune (ESC armed, DR only)
  8. ESC Compressor - ESC tune (ESC armed, WOT switch activated)
I will be installing my Borla UEL this weekend. Impulse buy because of Memorial Day sale $566 shipped...
TM is offline   Reply With Quote
Old 05-29-2014, 10:48 AM   #5801
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
I would do the ESC runs first though and when those are done flash to stock and remove the ESC. Definitely let the car run for a few minutes after flashing because otherwise the car will be in low power mode and no fully utilize AVCS.
Luckrider is offline   Reply With Quote
Old 05-29-2014, 10:57 AM   #5802
TM
TM's Avatar
Drives: DGM BRZ 6MT
Question for putting the stock inlet pipe back in. What do you use to cover the opening where the sound generator tube used to connect to?
Old 05-29-2014, 11:02 AM   #5803
fenton
There are little caps that you can get at a hardware store or rubber plugs. Just measure the diameter before you go.
My sound tube isn't removed so I just install the stock intake.
Old 05-29-2014, 11:04 AM   #5804
shif7i7down
Erected Member
Drives: frs
Thanks for the confirmation guys.
Old 05-29-2014, 04:07 PM   #5805
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Where did you run the wire if the sound tube is still in?
Khyron686 is offline   Reply With Quote
Old 05-29-2014, 04:12 PM   #5806
fenton
Just on the drives side through a Crack between the hood and door.
Old 05-29-2014, 04:31 PM   #5807
TM
TM's Avatar
Drives: DGM BRZ 6MT
Why not through the firewall pass-through gromet?
Image courtesy of Perrin.
Old 05-29-2014, 04:32 PM   #5808
fenton
Its what we did temp on the first install and it doesn't get in the way so I just left it. Maybe I will change it one day lol.
Old 05-29-2014, 04:35 PM   #5809
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
I don't know if you've seen it or not, but there is a little nipple you can cut off to run it into the driver's footwell from the engine bay. The only reason I know about it is because I used it in my OEM Audio+ installation.
Old 05-29-2014, 04:36 PM   #5810
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
Lol, beat me to it.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
