Old 06-16-2017, 10:59 AM   #561
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Why the change from the wilwood?
Cockatoo is offline   Reply With Quote
Old 06-16-2017, 11:22 AM   #562
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Pedal Feel/Caliper Flex, and they only used half the rotor face on STI Rotors. I'll post up some pictures in a bit
DustinS is offline   Reply With Quote
Old 06-19-2017, 04:25 PM   #563
DustinS
DustinS's Avatar
Import Alliance KC
Seems the soft Plastic of the Velox splitter doesn't really keep it's shape too well.... Guess I will just adjust the splitter until it isn't bent.
The Following User Says Thank You to DustinS For This Useful Post:
MJones_RB (07-05-2017)
Old 06-20-2017, 10:02 AM   #564
DustinS
DustinS's Avatar
Brembo VS Wilwood Comparison (Visual)
VS
Well I took the time to check some of the plugs yesterday. (Can't get to a few of them without taking the header off.)
Found even with a ton of wrap, still sort of melting plug wires -_-
Good news is the plugs I could get out looked pretty much all the same:
Only one different was the passenger side front plug. Threads were covered in water? Which is weird because it's been to temp a few times since the last rain.
Other than that, I think my oil pressure gauge is faulty. I paid real close attention to it yesterday and while cruising I noticed it fluctuate 10 degrees rapidly. So Going to look at buying a new sensor and sending the gauge in to be checked/serviced.
Car was dropped off this morning to check on having A/C Lines made. They didn't seem too enthusiastic about the job. I should have just spent the time/money on getting Aeroquip A/C Lines/Fittings and finding the fittings for the condenser and firewall.
Found this compressor fitting:
This should adapt the GM compressor to the aeroquip fittings. Now I just need the two for the condenser and two for firewall.
Old 06-22-2017, 01:45 PM   #565
DustinS
DustinS's Avatar
So I went to adjust the Splitter and I can't seem to get it to un-bend... Going to remove it tonight and see what I can do. Almost wondering if the bash bar mount bent somehow. Kind of frustrating.
Old 06-29-2017, 11:27 AM   #566
DustinS
DustinS's Avatar
Can't get enough of this car, so I am just going to post some pictures. Stealing their exhaust routing here soon.
Shows the box around the exhaust which I plan on doing as well.
Got the front calipers painted up.
Just need to get the stickers made up and then will get cleared over again.
4Running Daily (06-30-2017)
Old 06-30-2017, 01:28 AM   #567
DIY
DIY's Avatar
Drives: BRZ, WRX
I got a lot of inspiration for my build from those guys in Norway too.
DIY is offline   Reply With Quote
The Following User Says Thank You to DIY For This Useful Post:
DustinS (06-30-2017)
Old 07-03-2017, 03:39 PM   #568
DustinS
DustinS's Avatar
Some pictures with a friend this weekend.
Old 07-04-2017, 02:23 AM   #569
zizon93
Drives: GBS
did you opti coat the car or it's just a camera effect that makes an exterior color even more outstanding? I'm curious to know because I have same color as yours :P
zizon93 is offline   Reply With Quote
Old 07-04-2017, 02:38 PM   #570
DustinS
DustinS's Avatar
A polish and good wax goes a long way. Mostly the filter used though.
Old 07-04-2017, 07:05 PM   #571
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
VS
Was the Wilwood calipers from a kit? My RR Racing kit has Wilwood Superlite calipers which cover all but a centimeter or less of the STI calipers.
Old 07-05-2017, 09:41 AM   #572
DustinS
DustinS's Avatar
Bought the brakets/brake line as a kit and it just listed the caliper needed.
Irace86.2.0 (07-05-2017)
Old 07-05-2017, 10:43 AM   #573
Carlos_M
Carlos_M's Avatar
Drives: 2014 BRZ Limited
I'm really diggin' the over-fenders black. Typically not a fan, but on this application it works really well.
-Carlos
Carlos_M is offline   Reply With Quote
The Following User Says Thank You to Carlos_M For This Useful Post:
DustinS (07-05-2017)
Old 07-05-2017, 07:40 PM   #574
MJones_RB
MJones_RB's Avatar
Are those front turn signal LEDs those switchback ones from Diode Dynamics?
MJones_RB is offline   Reply With Quote
The reason I'm always broke - Dustin's Supercharged 86 Dustin Member's Car Journals 211 11-08-2015 10:57 AM
Help! New Car Engine Blew Up. What are my rights? Obsidiank Scion FR-S / Toyota 86 GT86 General Forum 53 12-11-2014 11:43 AM
Midwest Modified - Auto Photography by Dustin Faulkner (aka Fancy) Kuzuri Great Lakes 20 02-16-2014 05:23 PM
Engine Warm-up Time Chad86 Scion FR-S / Toyota 86 GT86 General Forum 44 01-10-2014 12:03 AM
So my engine blew up.... alliedcam1 Engine, Exhaust, Transmission 57 12-28-2013 02:50 PM
