#561 |
TALLY FT86
Drives: 2014 FR-S Monogram -- SBD Turbo --
Why the change from the wilwood?
#562 |
Drives: 2013 Ultramarine FR-S
Pedal Feel/Caliper Flex, and they only used half the rotor face on STI Rotors. I'll post up some pictures in a bit
#563 |
Import Alliance KC
![]() Seems the soft Plastic of the Velox splitter doesn't really keep it's shape too well.... Guess I will just adjust the splitter until it isn't bent.
| The Following User Says Thank You to DustinS For This Useful Post: | MJones_RB (07-05-2017) |
#564 |
Brembo VS Wilwood Comparison (Visual)
![]() ![]() VS ![]() Well I took the time to check some of the plugs yesterday. (Can't get to a few of them without taking the header off.) Found even with a ton of wrap, still sort of melting plug wires -_- ![]() Good news is the plugs I could get out looked pretty much all the same: ![]() Only one different was the passenger side front plug. Threads were covered in water? Which is weird because it's been to temp a few times since the last rain. ![]() Other than that, I think my oil pressure gauge is faulty. I paid real close attention to it yesterday and while cruising I noticed it fluctuate 10 degrees rapidly. So Going to look at buying a new sensor and sending the gauge in to be checked/serviced. Car was dropped off this morning to check on having A/C Lines made. They didn't seem too enthusiastic about the job. I should have just spent the time/money on getting Aeroquip A/C Lines/Fittings and finding the fittings for the condenser and firewall. Found this compressor fitting: ![]() This should adapt the GM compressor to the aeroquip fittings. Now I just need the two for the condenser and two for firewall.
#565 |
So I went to adjust the Splitter and I can't seem to get it to un-bend... Going to remove it tonight and see what I can do. Almost wondering if the bash bar mount bent somehow. Kind of frustrating.
#566 |
Can't get enough of this car, so I am just going to post some pictures. Stealing their exhaust routing here soon.
![]() ![]() ![]() Shows the box around the exhaust which I plan on doing as well. ![]() Got the front calipers painted up. ![]() ![]() ![]() Just need to get the stickers made up and then will get cleared over again.
| The Following User Says Thank You to DustinS For This Useful Post: | 4Running Daily (06-30-2017) |
#567 |
Drives: BRZ, WRX
I got a lot of inspiration for my build from those guys in Norway too.
| The Following User Says Thank You to DIY For This Useful Post: | DustinS (06-30-2017) |
#568 |
Some pictures with a friend this weekend.
#569 |
Drives: GBS
#570 |
A polish and good wax goes a long way. Mostly the filter used though.
#571 |
Drives: Q5 + BRZ + M796
#572 |
Bought the brakets/brake line as a kit and it just listed the caliper needed.
| The Following User Says Thank You to DustinS For This Useful Post: | Irace86.2.0 (07-05-2017) |
#573 |
Drives: 2014 BRZ Limited
I'm really diggin' the over-fenders black. Typically not a fan, but on this application it works really well.
-Carlos |
| The Following User Says Thank You to Carlos_M For This Useful Post: | DustinS (07-05-2017) |
| The reason I'm always broke - Dustin's Supercharged 86 | Dustin | Member's Car Journals | 211 | 11-08-2015 10:57 AM |
| Help! New Car Engine Blew Up. What are my rights? | Obsidiank | Scion FR-S / Toyota 86 GT86 General Forum | 53 | 12-11-2014 11:43 AM |
| Midwest Modified - Auto Photography by Dustin Faulkner (aka Fancy) | Kuzuri | Great Lakes | 20 | 02-16-2014 05:23 PM |
| Engine Warm-up Time | Chad86 | Scion FR-S / Toyota 86 GT86 General Forum | 44 | 01-10-2014 12:03 AM |
| So my engine blew up.... | alliedcam1 | Engine, Exhaust, Transmission | 57 | 12-28-2013 02:50 PM |
