Old 03-19-2018, 12:53 PM   #561
Somerandom18
Drives: 2017 manual BRZ
Looks like they have LC and FFS as well.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 03-21-2018, 12:35 PM   #562
timmydatooth
Drives: Scion Frs
will these new V4 tunes benefit my 2013 Scion FRS AT? or are these new tunes only for the 2017+ models? I have the (v2.076) stage 2 tune installed now.
timmydatooth is offline   Reply With Quote
Old 03-21-2018, 05:00 PM   #563
elBarto
elBarto's Avatar
Drives: Toyota GT86
It's for all USDM cars, ranging from 2012 till 2017
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 03-21-2018, 05:29 PM   #564
timmydatooth
Drives: Scion Frs
nice thank you, has anyone with a 2013 scion frs AT upgraded to the new tunes yet? any difference at all from the old ones?
Old 03-23-2018, 12:10 AM   #565
microSDHC
microSDHC's Avatar
Drives: '13 FR-S 6AT (Argento)
I’d be interested in knowing as well. I’d also like to know what exactly was changed. I downloaded the files and read the change notes and I recall something about reducing the ignition advance timing from 1 to 0.7?
microSDHC is offline   Reply With Quote
Old 03-23-2018, 04:10 AM   #566
Kodename47
Kodename47's Avatar
Drives: UK GT86
Which file are you using (Stg1/2/2+/E85)? The Stage 1 has 10 changed tables:
2x MAF Correction After Start (Cold Start Adjust)
5x Idle Speed Changes (Cold Start Adjust)
Target Throttle Plate Angle (Only changed above 6400)
Ignition Timing Post Start (Cold Start Adjust)
P0700 Code is disabled
The Stage 2 has, in addition:
Open Loop Fueling (Richer at high load low RPM, Leaner at high load high RPM)
LTFT Limits (Reduced to +/-2%)
Base Timing B (Less Timing at high load high RPM)
Knock Correction Advance (More Timing at high load high RPM)
Timing Comps Per Cylinder A & B (Now all 0)
FBKC Range (Enabled now set above 3k RPM)
Intake and Exhaust AVCS Changes
The manual is pretty much the same as the above.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-24-2018, 09:20 PM   #567
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
i drove around a bit today to do some stuff and holy shit the difference for cold city driving is night/day
Breadman is offline   Reply With Quote
Old 03-25-2018, 12:53 AM   #568
stlgrym3
Drives: 2017 Subaru BRZ Limited
has any 2017 AT owners used OTS v3.0? v4 does not support 2017 AT model as of now, i've heard v3.0 beta works on this model. can anyone confirm this before i try it? afterall its a beta.
stlgrym3 is offline   Reply With Quote
Old 03-25-2018, 01:00 AM   #569
My Key
My Key's Avatar
Drives: 2017 Toyota 86 - Raven
I'm running V3s. They aight. Make sure it matches your code.
Sent from my SM-G955U using Tapatalk
My Key is offline   Reply With Quote
Old 03-25-2018, 01:04 AM   #570
stlgrym3
Is yours 2017 auto? By code you mean the CALID tablet read off of the stock ROM correct?
Old 03-26-2018, 07:14 PM   #571
My Key
My Key's Avatar
Yes and yes
Old 03-26-2018, 09:18 PM   #572
N_AL_spyder
Drives: 2013 10-series, 2004 MR-2
Anyone else having issues with the v4 tune? I'm seeing some erratic idle after hot start on my 2013 MT car.
Also, is the advance multiplier supposed to reset to 0.7 every time you start the car?
I'm running the Stg 2+ tune with catless UEL and good quality 93 octane fuel...
Sent from my SAMSUNG-SM-J120A using Tapatalk
N_AL_spyder is offline   Reply With Quote
Old 04-12-2018, 10:55 AM   #573
ChrisGeezy
Drives: 2014 White FRS
Looks like shiv updated the files to v4.03 on their website a few days ago. Check it out. Unless I'm late to the party.
http://www.openflashtablet.com/downloads/
ChrisGeezy is offline   Reply With Quote
Old 04-12-2018, 11:51 AM   #574
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
You're late 🤣
OFT Openflash V4 tunes released for 2017+ with Launch/FFS
https://r.tapatalk.com/shareLink?sha...0&share_type=t
OpenFlash Tablet: Multiple Data Log files! Shiv@Openflash Software Tuning 95 11-09-2017 08:40 AM
OpenFlash Tablet: OTS v2.0 Beta (132 new maps, 12 new XMLs) Available for Download Shiv@Openflash Software Tuning 1062 08-13-2017 04:13 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet v1.55b: BIN files added! Shiv@Openflash Software Tuning 525 04-09-2014 09:42 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
