Old 11-19-2014, 10:11 PM   #5629
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Originally Posted by sam69 View Post
Where did you get that gauge pod from mate
From this fella: https://www.facebook.com/pages/Block...86061001612122
Fizz is offline   Reply With Quote
The Following 3 Users Say Thank You to Fizz For This Useful Post:
CarzCarzCarz (11-20-2014), Khorne (11-20-2014), whataboutbob (11-20-2014)
Old 11-20-2014, 01:42 PM   #5630
xxscaxx
Drives: 2013 SWP BRZ
I am going crazy trying to find this "leak" of mine on my supercharger.
Having a ton of issues starting, especially now that its cold. Took almost 8 turns to get it started yesterday. Keep getting a CEL for P0507 pop up and then disappear every few days. I've checked every vacuum line, sprayed them all down with electronic parts cleaner to check for signs of idle changes, and nothing. Every line is clamped. I'm starting to think its coming from somewhere else. Checked the vacuum hose on the BPV, checked around the TB, the gaskets on that and the elbow...everything seems fine.
I haven't had a chance to swap back the stock fittings as i'm using npt and not BPT, but I sprayed the living crap out of that area and found nothing. I used teflon on those so i'm pretty sure its not leaking...but you would think if I have a big enough leak to set off a CEL and have issues starting the car, I would be able to find this leak as its obviously not a tiny one.
xxscaxx is offline   Reply With Quote
Old 11-20-2014, 09:47 PM   #5631
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
Well. In the cold weather my 70mm intercooled pushes past the OEM clutch. I guess I am done with power mods. I don't really want to replace the clutch. Big money for 0 gain IMHP.
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 11-21-2014, 01:26 AM   #5632
Raven604
It's only 400$ and 6hr
Sent from my SGH-I337M using Tapatalk
Raven604 is offline   Reply With Quote
Old 11-21-2014, 02:58 AM   #5633
poorsche
poorsche's Avatar
Drives: 13 BRZ Limited, 2000 Impreza Sport
Same here with the clutch, waiting for it to go before upgrading. All part of the build--->break--->build better cycle that is so exclusive to car enthusiasts.
Innovate powered- Corn fed- FBM tuned
poorsche is offline   Reply With Quote
Old 11-21-2014, 02:16 PM   #5634
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
I had to replace my clutch about a month ago due to the throw out bearing crapping out. The clutch I've got now holds up to 270ft lbs so no worries for sure. If you can do it yourself Id highly recommend it....even though I got the clutch and light flywheel at dealer cost, they ass raped me with labor...not to mention wouldn't cover it under warranty. Gotta pay to play I guess.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 11-21-2014, 10:29 PM   #5635
sam69
Drives: GT 86
I might be blind but I've searched and searched for the thread that was a review on a Bosch quick response AIT sensor from the UK for the Sprintex Sc and was interested to know more but stuffed if I can find it or has it been deleted, so can someone point me in the right direction pls
sam69 is offline   Reply With Quote
Old 11-22-2014, 02:29 PM   #5636
Lawnik
Lawnik's Avatar
Drives: Flat grey Toyota 86
I think this thread is the one you are looking for, see post #33
http://www.ft86club.com/forums/showthread.php?t=48698
Lawnik is offline   Reply With Quote
The Following User Says Thank You to Lawnik For This Useful Post:
sam69 (11-23-2014)
Old 11-23-2014, 05:55 AM   #5637
Vex
The site says inter cooled supercharger system - hardware only.
What's the hardware only part mean?
Vex is offline   Reply With Quote
Old 11-23-2014, 09:52 AM   #5638
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Means you get everything you can physically touch as part of the system. Tuning AKA software would need to be purchased elsewhere.
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 11-24-2014, 02:57 AM   #5639
jflogerzi
jflogerzi's Avatar
To me it looks like the sweet spot for non IC users is the 72mm pulley and E85. This setup should yield 250WHP and 200WTQ with nice instant boost response. This should also allow the car to run on 91 if need be.
Old 11-26-2014, 01:34 PM   #5640
blown
Drives: ft86
anyone try installing a IAT sensor by welding on a bung?
blown is offline   Reply With Quote
Old 11-26-2014, 02:48 PM   #5641
JesseE
JesseE's Avatar
Drives: LS Swapped BRZ
Swapped the stock pulley to the 69mm pulley today... A bolt broke off in the supercharger, luckily with some reverse drill bits was able to get it out, and put some good quality grade 8 bolts back in... Along with the e85 I hope my clutch doesn't start slipping :-P Well maybe I do because that means I'm making some good power numbers :-)
JesseE is offline   Reply With Quote
Old 11-26-2014, 03:03 PM   #5642
Jac
Drives: Fiat Abarth
While doing my research on this kit the most common failure/issue seems to be coil packs going bad. Has anyone figured out why? Tune?
Phantom Supercharged BRZ | 205WHP / 185WTQ
Nameless FP/OP Combo
Jac is offline   Reply With Quote
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
