Old 03-04-2016, 01:50 PM   #547
enivid
enivid's Avatar
Drives: WRB JR BRZED
Originally Posted by sales@delicioustuning.com View Post
That would be the blower starting to make positive boost pressure. They don't really kick in very fast, especially at high elevation like you are.
Side note - We have an update coming for you very soon. Bill and I have been brainstorming on how to best approach your situation with regards to elevation.
Sincerely,
Zach
Is this a problem with all of us at that elevation or just a problem with the C38 blower? The rest of us are on the C30.
enivid is offline   Reply With Quote
Old 03-04-2016, 02:09 PM   #548
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
The C38 is a bit exaggerated as far as that goes. You're more than welcome to send a WOT log over to me to make sure everything looks kosher.
Sincerely,
Zach
Old 03-04-2016, 02:30 PM   #549
Hicklinc
Drives: N/a
They'll be about the same as the C30 at standard boost levels and pump gas fuels. E85 and high boost is where the C38 will really come into its own. This blower is more than capable of 400whp+ with proper fuel and boost levels. This is, of course, typically reserved for built engines.
Sincerely,
Zach
I have another question I'm interested in the jackson racing kit but would like more power than the carb tune provides but the hbp on the c38 requires a built engine what about the hbp on the c30 is that safe for the stock engine oh and I'm looking at going e85
Sent from my SM-N910T using Tapatalk
Hicklinc is offline   Reply With Quote
Old 03-04-2016, 02:57 PM   #550
DeliciousTuning
A C30 blower with the high boost pulley and E85 will get you to about the safe limits of the stock engine in terms of daily reliability. There are folks running this combo that have been fine for quite awhile, and others that fatigue quickly and require an upgraded block sooner rather than later.
Sincerely,
Zach
Old 03-17-2016, 03:44 PM   #551
YellowFR-S
Drives: 2015 Scion FR-S RS 1.0
Minor Update: Back in December we had finally figured out a way to fit overboost protection into our Flash & Go tunes. Now, we have implemented it into a physical release in version number 18.00.
Aside from added overboost protection, Version 18 also features:
* Improved closed coop fuel correction
* More top end power
Nothing more on the fuel pressure sensor* kit for now. Soon.
The Double D's will land soon, and all will be made clear.
Sincerely,
Zach
Great news on the overboost protection.
The Double D, is this only going to be used for SuperCharger applications, or will it also apply to the Turbo applications as well?
YellowFR-S is offline   Reply With Quote
Old 03-17-2016, 04:03 PM   #552
DeliciousTuning
The Double D is Edelbrock specific for now.
Sincerely,
Zach
Old 03-25-2016, 03:07 AM   #553
whatevervu
Drives: '15 FRS
After some consideration, I've decided to go in the get the flex fuel kit with the e85 flash and go tune today. Mike installed the fuel pump and injectors next door and then Zack flashed the tune soon after. I will comment back here with any updates but as for now I am very happy with how it turned out. My frs runs so much more noticeably smoother now than before (not to mention faster haha). Now gotta save up for a new set of wheels and tires!
whatevervu is offline   Reply With Quote
Old 03-28-2016, 07:09 AM   #554
denso
Drives: 86
Hi guys. Im about to FI my 86 in the next couple of weeks with a custom low mount setup. Im using a Garrett GT2871R with .86ar. My goals are around 280-300whp on a stock engine.
Im able to run 102ROZ fuel. Will the flash&go tune need adjustments for the fuel? How much boost I have to do to reach the 280whp mark?
Cheers from germany.
denso is offline   Reply With Quote
Old 03-29-2016, 03:43 PM   #555
DeliciousTuning
The 280whp mark would probably be achievable on wastegate pressure without even taking advantage of your high quality fuel over there. With your fuel and a bit more boost, I think we could get you above 300whp without putting too much stress on the engine at all.
Sincerely,
Zach
Old 03-29-2016, 04:14 PM   #556
denso
Drives: 86
Thank you for your answer @Zach. Im on wg pressure (0.5bar) w/o any boost control (yet). Im getting ECUtek soon. Wich boostcontroller do I have to get to be able to do boost control via ECUtek RaceROM? Are you able to implement the bc into the software?
Cheers from germany
Old 03-30-2016, 12:07 AM   #557
Flashfire88
Flashfire88's Avatar
Drives: Limited Silver
Cheers from germany
You can do an EBC with ecutek and set custom boost per gear or get a manual boost control and adjust it to what you wanna run with the tune of course, but wait till Zach gets back to you with what will be better for your goals.
-Avo @ 10.5psi-
Flashfire88 is offline   Reply With Quote
Old 03-30-2016, 12:42 PM   #558
DeliciousTuning
Cheers from germany
Any 3 port EBCS will work very well. We have one that we sell on our website from Infamous Performance that we're rather fond of!
Sincerely,
Zach
Old 03-30-2016, 03:41 PM   #559
denso
Drives: 86
Ah okay so I need a complete EBC. My thoughts are to implement the boost solenoid only into the stock ECU and use it with ECUtek. Is this possible in any ways? Wiring or other things arent a problem, im a technican at Lexus.
@Zach, you said that we can get over 300whp without pushing any limits with "my" fuel... I've read that the stock conrods will die at around 280whp. A friend of mine is pushing ~400whp on a stock FA20 w/o any failures @E85. How could this be possible? I know that the rods are weak at this power level and that they dont like any kind of knock.
IF its possible to get around 300+whp w/o punishing the stock long block Im your man. But just if its really safe to do this. Im completely stock (engine, injectors, clutch,...). w/ oil cooler @ Motul 300V 5W-40.
edit: I got a lot of track/race usage...
cheers from germany
Old 03-30-2016, 04:56 PM   #560
Kodename47
Kodename47's Avatar
Drives: UK GT86
@denso it's not power that kills the rods but torque, or more specifically cylinder pressure. That's why knock is bad but also if kept in check, especially at lower RPM, then you can be fine.
.: Stealth 86 :.
Kodename 47 DJ:
P&L Oil Cooler for Forced Induction Applications!! Compatible with FMICs!!! P&L Motorsports Forced Induction 9 03-26-2017 01:27 PM
Most *fun* forced induction bfrank1972 Forced Induction 45 12-22-2016 11:36 AM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Announcements, Contests, Giveaways 115 02-28-2014 12:38 PM
February Sale. All Delicious Tuning e-tunes are 10% off!!! Infamous Performance Announcements, Contests, Giveaways 19 02-28-2014 12:37 PM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Forced Induction 107 02-13-2014 11:36 AM
