#547 |
Drives: Whiteout FRS- autocross ready
I have read in these STX builds that when you install coilovers like the KW3 Variants, you need to add front sway bar adjustable end links. Does that apply to the back also? It looks like maybe an inch or less of ride height drop is the preferred setup, so that is where I will start.
#548 | |
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
3/4-1" is where I started.
![]() Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication STX Build thread 14th/67 SCCA Nationals (2014) |
| The Following User Says Thank You to SubiePig For This Useful Post: | MTCRX (01-06-2014) |
#549 |
Thanks, I forgot to mention I already have the Strano front bar if that makes a difference.
#550 | |
#551 | |
Dances with Cones
Drives: 2013 Scion FR-S Raven
2013 Scion FR-S - Raven
2011 Scion tC - Cement - SOLD |
#552 |
Drives: 2014 BRZ
He's talking about the endlinks for the swaybar. I don't think they're needed (according to Sam), but I'll probably get some for mine anyways. I think I've read that some have had some slight rubbing.
#553 | |
I thought I had read in some setups that adjustable end links were needed to attach the sway bar after lowering the car, and possibly to prevent rubbing. I suspect that lowering the car might lengthen the end link connecting points and thus you would need a longer end link to compensate and get the right stiffness on the swaybar. I plan to adjust the dampers etc, but if I can't attach the swaybar I am held up in my prep. I have the Strano front bar now and like it with my stock suspension, so my plan is to move to coilovers, lower the ride height slightly with swaybar connected under proper tension, and start adjusting from there. Thanks. |
#554 |
Conedancer
Drives: 2013 Subaru BRZ SWP
Siiiigh.....I sure wish the rules allowed a front lip/sideskirts and rear apron/winglets... :/ ..Anyways...looking forward to the new season.
Bill
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
#555 |
Drives: 13 BRZ WRB
Write a letter
| The Following User Says Thank You to 2superblus For This Useful Post: | Scooby South (01-09-2014) |
#556 |
When the car is lowered with adjustable endliks the sway bar rubs on the lower control arm. So shorter endlinks up front really helped me. I only had this problem with upgraded sway bars.
STREET MOD. My wallet now hates me....
#557 | |
Grip>Drift
Drives: FRS
Me too, I want to do it to make the car look cooler. It really doesn't help the car at autoX
#558 | |
Conedancer
Bill
#559 |
Drives: 2014 BRZ
I completely agree with that, the problem is writing the rule in such a way to allow such things while not providing any aero benefits. Remember, that's the way things were, and then people started to take advantage. I would love to have that front lip/sideskirt setup (very subtle, nice little addition), but it is what it is.
| The Following User Says Thank You to piknockout For This Useful Post: | Scooby South (01-12-2014) |
#560 |
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
I also would really like the factory cosmetic stuff.
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 03:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 07:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 02:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 12:02 PM |
