Old 01-06-2014, 01:45 PM   #547
MTCRX
MTCRX's Avatar
Drives: Whiteout FRS- autocross ready
I have read in these STX builds that when you install coilovers like the KW3 Variants, you need to add front sway bar adjustable end links. Does that apply to the back also? It looks like maybe an inch or less of ride height drop is the preferred setup, so that is where I will start.
MTCRX is offline   Reply With Quote
Old 01-06-2014, 02:06 PM   #548
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
Front adjustable endlinks are not required. I didn't run them until I swapped to a different swaybar.
3/4-1" is where I started.
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
The Following User Says Thank You to SubiePig For This Useful Post:
MTCRX (01-06-2014)
Old 01-06-2014, 05:14 PM   #549
MTCRX
MTCRX's Avatar
Thanks, I forgot to mention I already have the Strano front bar if that makes a difference.
Old 01-07-2014, 12:24 AM   #550
EN2_Squirrel
EN2_Squirrel's Avatar
Originally Posted by piknockout View Post
When I drove Andrew's car, I know he was running the stock pads and I had no issues stopping. I'll figure out more as I eventually set up my car, but I don't think you need much brake in this car for autocross. It's not like the car gains a ton of speed on the straight sections and it's not like the car needs to be woahed down to get it to turn. If you have too much brake pad/brake bite, you could be doing yourself a disservice by inadvertantly over-braking and possibly having too much bite making it harder to modulate.
In the STi I had the HP+ and loved how strong they would brake, but I was often overbraking for corners and was losing too much speed when just needing a slight brush of the brakes. This was some great feedback I received from Sam Strano, and we swapped them for some Ferrodo 2500's. The same amount of ultimate braking without the massive bite, which made it easier to play with under trail braking and needing to scrub just a touch of speed without doing too much.
I guess the whole point here is to think about what you need to make the car better/faster and not just throw on parts because you can. Not that pads are expensive, but the money could be used for parts that will do more for you than pads.
In san diego here third gear is not that rare and there is a bit of downhill so stopping means a bit to me. however with the stock pads i had a tendency to unstersteer which was corrected with upgraded pads. that may have been due to the driver needing experience. also on those rivals for sale i have zII's and love the consistency. drove on rivals didnt like the feel. too bad good deal for them
EN2_Squirrel is offline   Reply With Quote
Old 01-07-2014, 01:00 PM   #551
that_guy
Dances with Cones
that_guy's Avatar
Drives: 2013 Scion FR-S Raven
I would beg to differ that you NEED a front sway bar. I think people that are encountering issues with handling after installing KW V3's need to spend a little more time setting up the dampers than throwing more parts at their cars. "Full stiff" is not the approach...
2013 Scion FR-S - Raven
2011 Scion tC - Cement - SOLD
that_guy is offline   Reply With Quote
Old 01-07-2014, 01:23 PM   #552
piknockout
Drives: 2014 BRZ
He's talking about the endlinks for the swaybar. I don't think they're needed (according to Sam), but I'll probably get some for mine anyways. I think I've read that some have had some slight rubbing.
piknockout is offline   Reply With Quote
Old 01-07-2014, 04:43 PM   #553
MTCRX
MTCRX's Avatar
I thought I had read in some setups that adjustable end links were needed to attach the sway bar after lowering the car, and possibly to prevent rubbing. I suspect that lowering the car might lengthen the end link connecting points and thus you would need a longer end link to compensate and get the right stiffness on the swaybar. I plan to adjust the dampers etc, but if I can't attach the swaybar I am held up in my prep.
I have the Strano front bar now and like it with my stock suspension, so my plan is to move to coilovers, lower the ride height slightly with swaybar connected under proper tension, and start adjusting from there.
Thanks.
Old 01-09-2014, 05:48 PM   #554
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Siiiigh.....I sure wish the rules allowed a front lip/sideskirts and rear apron/winglets... :/ ..Anyways...looking forward to the new season.
Bill
Scooby South is offline   Reply With Quote
Old 01-09-2014, 05:55 PM   #555
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
Write a letter
2superblus is offline   Reply With Quote
The Following User Says Thank You to 2superblus For This Useful Post:
Scooby South (01-09-2014)
Old 01-10-2014, 07:50 PM   #556
EN2_Squirrel
When the car is lowered with adjustable endliks the sway bar rubs on the lower control arm. So shorter endlinks up front really helped me. I only had this problem with upgraded sway bars.
STREET MOD. My wallet now hates me....
Old 01-11-2014, 11:03 AM   #557
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Bill
Me too, I want to do it to make the car look cooler. It really doesn't help the car at autoX
Old 01-11-2014, 11:30 AM   #558
Scooby South
Conedancer
exactly...:/ sigh
Bill
Old 01-11-2014, 11:44 AM   #559
piknockout
Drives: 2014 BRZ
I completely agree with that, the problem is writing the rule in such a way to allow such things while not providing any aero benefits. Remember, that's the way things were, and then people started to take advantage. I would love to have that front lip/sideskirt setup (very subtle, nice little addition), but it is what it is.
The Following User Says Thank You to piknockout For This Useful Post:
Scooby South (01-12-2014)
Old 01-11-2014, 06:54 PM   #560
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
I also would really like the factory cosmetic stuff.
Ranatsu is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
