Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 02-06-2022, 01:45 AM   #547
Midnightsky
Midnightsky's Avatar
Drives: 2022 BRZ WRB
Got Betty off the nannies tonight and gave her redline, wow, 2nd gear is a gem. I learned there is 2 different ways to turn off the nannies. While pressing and holding track mode will turn off stability control, it however does NOT turn off traction control. Many probably already know this. The trick to getting both off, as soon as u start your car, press and hold the traction control button for about 5 seconds until both lights pop up on the dash. The cluster will also change to track mode. This can only be done tho immediately after starting the car as best I can tell. I had some great fun tonight, can't wait to keep pushing Betty and learning how to make her sing that magic song of awesomeness.
Midnightsky is offline   Reply With Quote
Old 02-08-2022, 07:49 PM   #548
Panda Grahams
Panda Grahams's Avatar
Drives: '22 BRZ
Originally Posted by CZ6T View Post
Added the GR86 premium spoiler on the car, since I'm a big fan of ducktail spoilers and I liked how well engineered the OEM one is.
I think it looks pretty good, and the paint match looks close. I can't tell if it's slightly more white or if my car is just that dirty already.
Did you end up drilling the trunk and using the factory bolts? I'm tempted to try this, sans the factory bolts and drilling.
Panda Grahams is offline   Reply With Quote
Old 02-08-2022, 09:05 PM   #549
eyeballs
Drives: '22 BRZ
Dropped a snow shovel on it and made a small dent in the hood.
eyeballs is offline   Reply With Quote
Old 02-08-2022, 10:34 PM   #550
Shub Deetle
Large Member
Shub Deetle's Avatar
Drives: 2022 Subaru BRZ
Don’t feel bad - I did the same thing with my kayak on my RAV4.
Baby, you can drive my car
Shub Deetle is offline   Reply With Quote
Old 02-08-2022, 11:08 PM   #551
Midnightsky
Agreed, it could be worse lol. My buddy a few years ago backed up his rsx out of the garage and didn't realize the door wasn't open all the way. Wrecked his wing, dented up the one corner, it was bad lol.
Old 02-08-2022, 11:11 PM   #552
Fletch
Drives: 2022 BRZ Limited
Pretty sure you can press and hold the traction button at any time to get both lights on the dash no? Or am I missing something?
Fletch is offline   Reply With Quote
Old 02-08-2022, 11:53 PM   #553
cpierr03
Drives: 2022 BRZ
Hit 1k miles today, and removed the fun limiter. So satisfying to experience the full rev range!
I also did the first oil change - used a fluid evacuator, but also pulled the sump plug to check for shavings (there were none). A few notes:
  • The filter was really cranked on there, I had to get a wrench to remove it
  • The crush washer was adhered to the sump plug with whatever paint they used on it - really easy to miss unless you're looking for it. I had to pry it out with a knife
  • There are three 10mm head bolts to remove an access panel to get to the plug - there's an access hole, but I can't see how you'd get a wrench in there
cpierr03 is offline   Reply With Quote
The Following User Says Thank You to cpierr03 For This Useful Post:
Midnightsky (02-09-2022)
Old 02-09-2022, 12:04 AM   #554
Midnightsky
Nope you are not missing something, I was lol.
Old 02-09-2022, 07:04 AM   #555
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
You need to be stationary now to do that.
Also, there is a diagram somewhere that shows with the auto you can never get into fully off mode, only the manual.
Blighty is offline   Reply With Quote
Old 02-09-2022, 09:49 AM   #556
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I have definitely done the long press to get both lights while driving.
The Following User Says Thank You to DocWalt For This Useful Post:
MacSpeed (02-09-2022)
Old 02-09-2022, 09:58 AM   #557
MacSpeed
MacSpeed's Avatar
Drives: 2022 BRZ
This
MacSpeed is offline   Reply With Quote
Old 02-09-2022, 03:03 PM   #558
OscarGeezer
Drives: Brz
How much oil was left inside after using the fluid evacuator? What brand is it and are you satisfied with the results?
OscarGeezer is offline   Reply With Quote
Old 02-09-2022, 03:15 PM   #559
PenGun
Drives: Red 2019 Subaru BRZ
I have a 2019 so I may be crazy here. By far the simplest car to change oil, that I have ever had. With my ramps and a wrench the plug came out just fine, the oil then comes out of the bottom hole in the oil system.
The oil filter was bit tight, drove a screwdriver through it, and out it comes. Hand tight with the new one and Royal Purple in the car, and we were done in about ... 5 minutes.
PenGun is offline   Reply With Quote
Old 02-09-2022, 03:21 PM   #560
cpierr03
Drives: 2022 BRZ
Not much - maybe like 4oz, if that?
It's a Mityvac MV7300 - it works fairly well once you get the hang of it, I own three cars I need to maintain (two of which have top mounted filters) so I think it'll be something I'll appreciate in the long term.
It's a bit pricey for what is overall a pretty simple system, but hey it works. I do wonder if I should have gone for the hand pump version instead, in case I want to use it when I'm not around my compressor.
As a plus side, it comes with an attachment you can use for power bleeding calipers/slave cylinders.
WHAT DID YOU DO TO YOUR FRS TODAY? KalbiCool88 Scion FR-S / Toyota 86 GT86 General Forum 1 11-04-2015 11:36 PM
Do you know what today is? Yruyur Off-Topic Lounge [WARNING: NO POLITICS] 26 01-21-2015 03:51 PM
just got my OFT today...help please! carlitosway6891 Software Tuning 9 02-20-2014 11:05 PM
TODAY, TODAY, I GET IT TODAY!!!! :D Trashed675 Scion FR-S / Toyota 86 GT86 General Forum 54 02-14-2013 02:16 AM
