#43 |
Drives: '21 Crosstrek, '96 SVX
Thought I'd throw my hat into the ring with another GBS: Enkei TS10 18x8 +45 wrapped in 225/40x18 Conti ExtremeContact DWS 06. TRD lowering springs on OE '15 BRZ struts.
Last edited by NowImaBeliever; 09-20-2016 at 09:10 PM. Reason: Added another picture |
#44 |
Drives: 2017 BRZ WRB with PP
anyone know if the enkei ts10's 18x8.5 45offset will fit a 2017 brz with performance brake package?
i tried a yoshihara 18x8 40offset and i didn't clear the monster Brembo up front. -tim |
#45 |
Drives: Dark Grey BRZ
Heya, does anyone have any pictures of these on a DGM/Asphalt? I'm thinking the Grey might be best with that color?
Also, any pictures of these wheels on a stock suspension? I'm hoping it looks pretty flush? Thanks!! |
#46 | |
Sent from my SM-G930V using Tapatalk
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
#47 |
Thanks! What tires are you running with those 17x8s? I'm not sure whether to go 225 or 235 with stock suspension.
Any performance difference from driving around in with wider wheels? Oh, and do you think the eccentric bolts are required for the front? Are they essentially spacers? |
#48 | |
Drives: 2015 BRZ
Wide wheels will just give you more grip and using a 225/45 tire size is a great fit for wheels that are 17x8. Keep in mind though 225/45/17 are slightly larger tires than stock so your speedometer will be off by 1mph as gearing will be increased. But i doubt anyone can notice these differences No eccentric bolts are not required for this wheel and tire size. Eccentric bolts are used to get more negative camber. With our cars camber is not something you can change so these bolts allow you to change your camber. |
#49 | |
My brand of tire is the BFGoodwrench Sport Comp2. There's a noticeable performance difference from the lighter weight of the wheels & the stickier tires. The eccentric bolts aren't necessary. I installed them to get better traction at the front of the car under load. LCAs are necessary for the rear to change the camber. Sent from my SM-G930V using Tapatalk
#50 |
Thanks for your input! Is there a reason to go either 225/45 or 225/40?
#51 |
Drives: 2015 BRZ
#52 | |
Eccentric bolts are also called camber bolts. For camber adjustment. |
#53 |
Drives: '13 FR-S 6MT / '14 Prius-C
Enkei TS-10
I thought I'd share my pictures for those of you considering these wheels.
I bought the car new in summer of 2012, but I'm just putting wheels on now. Better late than never. I was hoping on a set of OZ Superturismo LM, but couldn't find them stateside. Im a pretty big fan of the Enkei RS05RR, but they are too expensive for my blood, so anyway I went with the Enkei TS-10.
Im literally shocked that the car actually feels smoother (like much much smoother) than the ride on the OEM Michelin Primacy HP 215 45 17" tires. Of course the grip levels are also much higher being that this is true summer performance tire and a tad wider than stock. This would be great for circuit racing or autocross, but it is much harder to break the rear end loose now being that the grip is higher and the engine is still stock. This does give up some of the fun to drive factor of the car. But boy does it look good on 18" wheels. Yup. Needs a tad more low. I'll work on it.
#54 | |
Drives: 2015 DGM BRZ Premium
Looks beautiful!! Sent from my iPhone using Tapatalk |
#55 |
Drives: 13 frs red
I think the stance looks great as it is
#56 |
Drives: black brz
just ordered 18x8.5 in gloss black with stance xr1's for my crystal black silica brz!!
gonna be taking some pics and video soon! |
| Enkei RPF1 Mega SALE!! Free shipping+ guaranteed lowest pricing!! +all Enkei wheels. | Moddiction | Wheels and Tires | 99 | 03-24-2018 04:46 PM |
| Enkei Kojin 18x9.5, Enkei RP03 SBC 17 9.5 or 18 9.5 and NT03 in White/SBC 18 9.5. | b2autodesigns | Wheels and Tires | 599 | 09-11-2017 11:51 AM |
| WTT: 18x8.5 Enkei TS9 with tires for 18x9.5 Enkei RPF1 or NT03 | JoeBoxer | Wheels and Tires | 9 | 09-05-2015 12:22 AM |
| PA:WTB/FT black enkei raijin 18x8.5 18x9.5 for enkei rpf1 17x9 | SterlingBrz | Wheels and Tires | 1 | 05-28-2014 11:36 PM |
| WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 | Touge Factory | Wheels and Tires | 2 | 02-05-2013 04:53 PM |
