Old 12-04-2015, 09:14 PM   #43
StegaDragon
StegaDragon's Avatar
Drives: 13 Sc10n FR-S
Originally Posted by celek View Post
Here is one possibility
Sorry thought you were talking about this kind of set up that doesn't use a single plenum for the TBs
SC10N driver
StegaDragon is offline   Reply With Quote
The Following User Says Thank You to StegaDragon For This Useful Post:
celek (12-05-2015)
Old 12-05-2015, 09:21 PM   #44
wparsons
wparsons's Avatar
exactly a very large plenum, what else would go in the middle of the engine
It would need to be a HUGE plenum to get short runners to the two heads.
Remember that the boxer engines are much wider than a V engine, and the V engine has the intake ports MUCH closer together (between banks) than a boxer.
flickr
Old 12-05-2015, 09:41 PM   #45
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
The alternative, rather obviously, is 1 plenum per bank, with a dual MAF setup. Many cars (e39 M5, B7 RS4) have made dual-MAF work.
You could run the intake snorkels over the top of the radiator like stock, or down to the fog light cavities.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 12-07-2015, 09:55 AM   #46
celek
Resident Gear Head
celek's Avatar
Not a problem
celek is offline   Reply With Quote
Old 12-07-2015, 09:57 AM   #47
celek
Resident Gear Head
celek's Avatar
now you are on my same thinking path
Old 12-07-2015, 05:28 PM   #48
celek
Resident Gear Head
celek's Avatar
It's here. Now to cut it up.
The Following 3 Users Say Thank You to celek For This Useful Post:
Aztec (12-08-2015), Teseo (12-08-2015), Ultramaroon (12-07-2015)
Old 12-07-2015, 09:17 PM   #49
Turdinator
Señor Member
Turdinator's Avatar
That's the only practical way to use MAF with ITB.
I have never seen MAP-based speed-density work right with ITB's. You lose all your vacuum above about 40% throttle.
The smoothest running ITB setups (without a plenum) I've seen and worked nearby are all on a high-resolution alpha-N map where the primary inputs for fueling are throttle position and RPM. Significant corrections include ambient temp/pressure, wideband closed-loop at low throttle settings, and very thorough tip-in and overrun corrections.
Getting them to idle is harder than tuning them to run.
There are some ECUs that can run a blended MAP and Alpha-N setup, so that you get the low speed drivability and idle quality of the MAP setup but can still get the high load tunability of the Alpha-N.
1974 TA22 Celica
2013 86 GT
Old 12-08-2015, 03:01 PM   #50
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Well alright! subbed
Intent > Content
Old 12-11-2015, 09:16 PM   #51
celek
Resident Gear Head
celek's Avatar
Back from PRI has a good conversation with Borla on how to approach this.
The Following User Says Thank You to celek For This Useful Post:
Ultramaroon (12-11-2015)
Old 12-15-2015, 04:43 PM   #52
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
Are you planning on using off the shelf throttle bodies and adapting to them or machining your own?
Gear_One_Performance is offline   Reply With Quote
Old 12-15-2015, 07:36 PM   #53
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
/endthread
Hyper4mance2k is offline   Reply With Quote
The Following 4 Users Say Thank You to Hyper4mance2k For This Useful Post:
DocWalt (12-21-2015), go_a_way1 (12-16-2015), Guff (12-15-2015), LOLS2K (12-15-2015)
Old 12-15-2015, 08:04 PM   #54
Killianti
Killianti's Avatar
Drives: 2013 WRB BRZ 6MT
Originally Posted by Hyper4mance2k View Post
/endthread
So throttle! Much wow! Very power!
Killianti is offline   Reply With Quote
Old 12-15-2015, 08:15 PM   #55
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
Eventually I'm going to put 2 Gene Berg carbs on a F20.
I've been tuning down draft IDA style carbs for over a decade. Nothing builds a relationship with your car than going outside and optimizing it for that day's weather.
edit: or this thing is going to get a 13B bridgeport swap. 300whp NA should do me just fine.
Old 12-16-2015, 06:03 PM   #56
Calum
That Guy
Drives: 2013 asphalt FRS MT
I'm surprised by this. Does Borla have a back ground in such things? The only things I've ever seem from them are cheap exhaust parts.
*serious question.
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
[B is for Build] BRZ resurrection build im_topher Member's Car Journals 49 03-05-2018 10:41 AM
No build date on passenger side sticker, how to determine build date? BBYZILA Scion FR-S / Toyota 86 GT86 General Forum 5 01-20-2015 11:14 PM
Dat sound - ITBs RWD_only Engine, Exhaust, Transmission 88 11-18-2014 05:19 PM
20v ITBs Nafe NEW ZEALAND 4 05-20-2014 09:03 AM
