Old 04-28-2017, 08:40 PM   #43
C4RBON
C4RBON's Avatar
Drives: '15 BRZ, '19 GTI
I was planning on chiming in here again, as I've made some discoveries regarding my issue in the last 6 months. It turns out, I have two noises that are similar, and sometimes happen independently, sometimes concurrently. There is also intake inductance resonance around 4000 rpm which makes the sources harder to identify.
One of the noises is in fact the clutch spring. The other noise is in the reverse lockout collar mechanism.
The clutch spring noise is louder, more metallic, and definitely sounds like it is in front of you. This goes away with a light press of the clutch pedal.
The reverse lockout noise isn't as loud and persistent. It sounds like it is coming from behind the center console, but after you identify it, it is definitely coming from the shifter area. Pulling up on the reverse lockout collar on the shifter changes the pitch to be much higher.
My car has been tracked twice now since I posted last, and nothing blew up. My oil analyses don't indicate any serious problems. I have stopped worrying about this (finally).
C4RBON is offline   Reply With Quote
Old 04-28-2017, 09:33 PM   #44
Ultramaroon
not playing cards
Ultramaroon's Avatar
The reverse lockout noise is the cable rattling inside the shifter lever, which is hollow. I've considered stuffing some spongy shit in there. But meh.
Old 04-30-2017, 08:22 PM   #45
MotoGrapher
Drives: 2014 White BRZ Limited
You'll just check it the next time it happens. Don't hold your breath though. I think I'm out to lunch here.
I confirmed that it was the cold air intake. I have an Injen cold air intake but somehow it started to rattle at certain RPM...
MotoGrapher is offline   Reply With Quote
Old 04-30-2017, 09:13 PM   #46
Ultramaroon
not playing cards
Nice. So many potential sources for rattle...
At the end of driving all day yesterday after 9 months of silence my old friend the clutch spring decided to get chatty. Quick tap and it shut up.
Old 09-13-2017, 11:21 AM   #47
mjfulk
Drives: 2014 FR-S
Sorry to leave a comment on such an old thread but this is the exact problem/noise I've been experiencing for the last several months and the reason I joined this forum. rburrow87 did you, or anyone else for that matter, find out what the cause was? Mine has been getting progressively worse but not consistent enough to have a shop diagnose yet. I have a gut feeling it's related to the fuel system. When I flashed to the OFT e 85 tune for a few tanks the noise was present more often. I'm getting really frustrated and hoping to find out the cause, and if neccisary, a fix. I'd appreciate any input people might have.
Sent from my HTC6545LVW using Tapatalk
mjfulk is offline   Reply With Quote
Old 09-13-2017, 01:18 PM   #48
strat61caster
strat61caster's Avatar
Many aftermarket tunes including OFT create a noise that may be what you're experiencing.
http://www.ft86club.com/forums/showthread.php?t=59475
ineedyourdiddly
Old 09-13-2017, 01:30 PM   #49
Ultramaroon
not playing cards
Welcome, and no worries. You're doing it right.
Can you post up a decent clip of the sound? It can be a real challenge.
Old 09-14-2017, 10:14 AM   #50
mjfulk
Drives: 2014 FR-S
Thanks for the reply's. The sound is actually getting to the point I was able to replicate it while reving in neutral this morning. Here is a video. Not the best quality but the sound does come through on it
https://www.google.com/url?sa=t&sour...jtvfnGP_UlkifA
Old 09-14-2017, 10:19 AM   #51
mjfulk
Drives: 2014 FR-S
One more time on the video link
Old 09-14-2017, 06:11 PM   #52
Ultramaroon
not playing cards
I'm going to guess it's the engine bottom cover. Try laying down and tapping on it from underneath. If not that, then pesky clutch spring.
Does it look like my axle nut went bad? Clicking noise on acceleration. hpde_addict Tracking / Autocross / HPDE / Drifting 50 08-12-2017 07:09 PM
Hard acceleration/revving noise oppiee CANADA 8 10-26-2014 01:59 PM
Rattling noise under Acceleration 5k RPM or more phuthinhon Issues | Warranty | Recalls / TSB 5 05-12-2014 12:34 AM
Engine pinging (rattle noise) under acceleration sho AUSTRALIA 95 08-10-2013 05:52 PM
Rattling Noise on acceleration Naughty AFRICA 2 05-14-2013 11:17 AM
