#43 | |
Addicted
Drives: 2013 Asphalt FR-S 6MT
Edit: Found the peripherals on the site. $400 for fronts and rears hmm
#44 |
Drives: 2015 CWP BRZ Limited
#45 |
Still waiting on my order from March 3rd, seems they have a little backlog of work. I was told to expect a delivery of mid April from an email I received last week.
#46 | |
Drives: 2023 WRB BRZ (MT)
#47 |
520
Drives: Series 10 Fr-s #520
I'm interested too in opinions on whether the 4" upgrade up front and the 3-way tune is worth the $$.
You can just drop in the upgraded drivers in the dash, but seems a bit pointless unless you also take advantage of their no-charge re-tune. $200 seems a bit pricey for this upgrade unless there is a big upgrade in performance. |
#48 | |
Drives: 2013 Subaru BRZ Limited (Black)
Would like to see some sort of hard data (audio spectrum or something) to validate whether adding mid-range speakers and a tune will really make a difference. But if there is a difference, then i'm in! |
#49 |
Drives: Specialized Hardrock
Going from a 2 way to a 3 way isn't something that is going to be easy to show with a graph. The difference is really in having the midrange frequencies come from dash height rather than in the doors, if tuned properly this will help the car image better.
#50 |
Addicted
^ agreed.
For the rears I'm not convinced though. Decided to go with just the front 4"s. From reading around on different audio forums, the rear speakers are not necessary and will only "fill in" whatever is missing or give a slightly different depth to the stage. The general consensus is spend your time and money on the fronts. For our cars especially I don't think the rears are necessary.
#51 | |
would love to hear more input from other members or OEMAUDIO about this! |
#52 | |
520
Setting up a true three-way front stage can be tricky, especially if you are running an "active" system, and requires much tuning. I am banking on the fact that OEM does their homework with the tuning on their 3-way tune for these cars. I mean, really, that engineering part is the hardest part to get right. Any monkey can throw drivers and amps in a car and call it good. I'm just trying to decide if the increase in SQ/Staging with adding the 4" fronts and the tune is worth the cost. In theory, if done right, the 3-way tune and updated drivers should lift the focal point of your sound stage significantly. |
#53 |
May b a while. All the orders are backed up bc their shipment of OEM connectors from Toyota got delayed. So blame toyota
#54 |
Agreed on tuning being the key thing here. A well tuned 2 way sounds better than a poorly tuned 3 way. That said, there are huge advantages to having the midrange on the dash. Keep in mind, some of the current best sounding cars I am aware of use a 2 way plus sub, all with 5.25" midrange and tweeters above the dash, and a single sub up front. And even the ones that have 3 ways that are competitive with those cars, use 4" midrange above the dash.
#55 |
Drives: 2017 BRZ - Dark Grey Metallic
Are the install instructions the same for right hand drive? Or every time it mentions "the drivers side" should I be doing these procedures on the passenger side (ie, the left).
*it's sitting in the box in the garage - Help!!* Last edited by softgrip; 04-01-2016 at 06:42 AM. |
#56 |
Drives: 2014 Ultramarine 6MT FR-S Monogram
I bought the OEM+ Reference system with the free rear speaker upgrades (preorder). Just been told it will arrive in less than 3 weeks. Can't wait to install it and hear the difference.
Borla axleback exhaust * mud guards * Michelin Pilot Super Sport tires * Opti-Coat * BRZ trunk lid liner * Rexpeed Wide Mirrors (heated)
| Tags |
| amp, audio, music, radio, subwoofer |
| Audio Equipment Part out! AVH-x4500bt, illusion audio, OEM amp, arc audio and more!!! | CamryDS | Audio/Visual, Electronics, Infotainment, NAV | 25 | 10-23-2015 09:10 AM |
| Incriminator Audio 6.4, Sundown Audio SAX-100.4, US Amps Xterminator XT800.2 | slicktop | Miscellaneous | 1 | 07-11-2014 08:58 AM |
| WTB: berk dual delete/perrin exhaust. JDL El headers. BBK kit. OEM Audio+/JL Audio | YEAHdams | Want-To-Buy Requests | 0 | 07-01-2014 11:37 AM |
| FR-S Audio Build - SQ (Illusion Audio/Mosconi) | DekaMori | Electronics | Audio | NAV | Infotainment | 28 | 04-17-2013 04:34 AM |
| 'Noobish' questions as I look to upgrade my car audio audio. | DkY in Vcr | Electronics | Audio | NAV | Infotainment | 0 | 09-22-2012 09:45 PM |
