#43 |
VTEC just kicked in, yo!
Drives: World Rally Blue BRZ - 6MT
Very nice! I'm looking forward to seeing some installed pics
#44 |
Drives: BRZ Limited AT
Did you get these put on?
#45 |
Drives: 2013 FR-S. Raven 6 AT
Thanks. These were the wheels I was thinking of getting for my FRS raven. Now seeing yours I'm going to pull the trigger.
#46 |
Drives: 2013 Scion FR-S MT Ultramarine
Quick iPhone pic
Perrin Non Res Cat Back/CAI/Inlet/Tranny Mount/Shifter Bushing
Enkei PF01 18x7.5 et38/Conti DW 225/40/Eibach Pro-Kit H&R spacers 15mm rear/5mm front/Whiteline PSK/ECUTek Tune Alpine IND-S920HD/MRX-V70/CDT HD-62/JL StealthBox/Bel RX65/JPM Coachworks interior bits |
#47 |
Looks great. I need to jump on these while Tirerack has them on special..
#48 | |
Drives: 2013 BRZ, Limited, C7P, 6AT
Also, complexity of suspension setup is such that all adjustments are interrelated. You may be thinking that lowering a car just changes the ride height but that is far from reality. Depending on how your particular suspension is configured, you may also be changing track width, camber, caster, toe in/out, scrub radius, effective wheel rate...and the list goes on. Despite all this, most people aren't skilled enough to notice those changes when they are subtle but the changes do exist and they crop up when you approach 10/10ths, the time it matters most. If you're never going to push your car to it's limits, you may be able to ignore most of what I've just started to describe.
#49 |
just had some 5mm H&R Trak+ spacers installed on the rear.
pretty much perfect now for a dd
#50 |
and the front
#51 |
and a 3/4 view
#52 |
NW Region Moderator
Drives: FR-S No More
Merged another topic with same wheels and same specs.
#53 | |||
Drives: BRZ and NA
According to my calculations, a 7.5" wide wheel at a +38mm offset will stick out the same amount as a 8" wide wheel at +45mm. The 7.5" wide wheel gives you 13mm more in clearance to the inside. So if you look at these pictures a 17x8 +45 wheel will stick out just as far. |
#54 | |
Señor Member
Drives: white BRZ 6MT
was just comparing 7.5 +38 vs 7.5 +45 unless somebody confused something. so yes, with the same width it will stick out more
#55 |
I had done the measurements vertically between the top edge of the wheel opening and the outer edge of the OEM rims (all at stock ride height and on a level surface, of course). The front rims are about 15mm inset and the rears are about 25mm inset. If you change the width and offset by these amounts, your rim edges will be flush with the upper edges of the fender wells.
Note the 10mm difference between front and rear. Coincidentally, when you account for bothe left and right sides, that matches up to the 20mm difference in track width per the OEM specs. If you get the same size and offset wheels at all four corners and add 10mm spacers the the rear, you will get the same relationship vertically between the top of the fender openings and the outer edge of the rims. You will also end up with the same track width front and rear. There is another way to go about that with a staggered setup but having the same all around allows for tire rotation (for those who would prefer to be able to to that). All you need is some back math and the ability to convert between SAE and metric to figure this stuff out, at least until you start playing with changes to ride height and camber. Then you better have been paying attention in geometry class... |
#56 |
Drives: 2013 86 white
This Enkei PF01 double 5 spoke bright silver is a really nice looking light racing wheel. But I don't know why so many popular pick for the other funny looking rpf01 wheel. I'm thinking a set of 17x8.5 /17x9 would also be an option.
| Wheel Directory: Enkei PF01 17x8.0 +45 | NickFRS | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 53 | 07-30-2019 08:39 AM |
| Wheel Directory: Enkei PF01 17x7.5 +38 | FRSFirestorm | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 06-19-2017 10:36 PM |
| Wheel Directory: Work Emotion XT7 18x7.5 +48 / 18x7.5 +42 | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 07-26-2013 09:42 PM |
| Wheel Directory: Enkei Klamp 18x7.5 +45 | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 07-08-2013 12:53 PM |
| Wheel Directory: Enkei PF01 18x7.5 +45 | ollepellijeff | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 07-08-2013 12:25 PM |
