Old 05-04-2015, 12:01 PM   #43
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Originally Posted by BlueSky View Post
Crazy crazy
With the scoring, do these motors bore easily?
Whats the plan on that?
Unfortunately, I'm not 100% sure.
The scoring is minimal, really. I'm talking with a few shops / people who have built these up and then i'll decide what the plan is.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 05-06-2015, 11:07 AM   #44
ybotspawn
ybotspawn's Avatar
Drives: 13 Subaru BRZ
sub'd
ybotspawn is offline   Reply With Quote
Old 05-06-2015, 11:19 AM   #45
Gopherboy6956
Update -
I Decided that based on time requirements, and the fact that i have a few events coming up at the end of the month, that buying a used engine and swapping it in right now is the best option.
I picked up a engine out of a car that was rear ended and totalled with about 8,000 miles on it for $3300 shipped to my door.
I don't feel comfortable replacing pistons, rods, etc without doing a ton more research or talking to people who have, and I just don't want to miss events because of that. Plus, the most reputable machine shop in our area is backed up two solid weeks, so boring or honing my block would take forever.
So, i am going to tear down my engine completely, remove pistons and really inspect, and then build it back up over the summer / fall. Will go with the flex fuel kit until then so i can run e85 and avoid this damn detonation again.
Old 05-06-2015, 02:57 PM   #46
blown
Drives: ft86
Originally Posted by Gopherboy6956 View Post
Update -
i didn't have any codes with mine, just smoke .. happened on the delicious e85 ff tune. I've learned my lesson, its much better to have a local "good" tuner tune your car than etune. I ended up grabbing a used built motor.
blown is offline   Reply With Quote
The Following User Says Thank You to blown For This Useful Post:
raven1231 (05-08-2015)
Old 05-06-2015, 03:26 PM   #47
Gopherboy6956
Originally Posted by blown View Post
mine popped the same way.. innovate stage2.. huge clouds of smoke at WOT.. idled fine and drove fine but it burned through 1 quart of oil on a 45min drive.. I did a leakdown which seemed to pass, but I also had tons of oil in the PCV catch can and oil all over the intercooler/manifold..
Going back and thinking about your situation more - it's odd that oil got to your intake if you have catch cans.] Do you have them on BOTH crank and PCV?
the only other way would be if your Supercharger Leaked it's oil into the intake.
My leakdown shows that air makes it to the PCV and Crank, but the cans prevented any from getting into my intake, as both the intercooler and throttle body were clean.
Old 05-06-2015, 03:27 PM   #48
Gopherboy6956
the only code i ever had was misfire cyl 4. When the CEL flashed at me while going WOT, it just flashing intensely and then went away, leaving no codes.
And the weird thing is cyl 1 is the one that popped oil, not 4.
Odd..
Old 05-06-2015, 06:02 PM   #49
blown
Drives: ft86
the one for the pcv was overfull with oil.. so much that it went past and back into the intake pipe on the sprintex kit..
yes I had a dual catch can setup for both sides..
Old 05-07-2015, 01:22 AM   #50
Lonewolf
Lonewolf's Avatar
Drives: Moped
Was yours a 2013 FRS as well?
Old 05-07-2015, 10:10 AM   #51
blown
Drives: ft86
13brz
Lonewolf (05-08-2015)
Old 05-08-2015, 09:00 PM   #52
Lonewolf
Lonewolf's Avatar
Drives: Moped
Why do 99% of these catastrophic engine failures come from 2013 twins? Is it because there are more higher mileage specimens or is it something else?
Old 05-08-2015, 10:22 PM   #53
congiiee
Drives: WRB Subaru BRZ
Was there any oil in the crankcase catch can as well?
congiiee is offline   Reply With Quote
Old 05-08-2015, 11:14 PM   #54
Gopherboy6956
My 13 only has 11k on it.
Old 05-09-2015, 10:29 AM   #55
blown
Drives: ft86
the one for the drivers side was none.
I had 24k miles
congiiee (05-09-2015)
Old 05-09-2015, 12:32 PM   #56
DarkSunrise
DarkSunrise's Avatar
I wonder if it's related to the AVCS issues these cars had early on. The re-flash made the ECU less prone to throwing a code due to cam timing issues, but that's really just masking an underlying hardware issue. If you notice, there were some tuners who reported losing control over cam timing/AVCS intermittently on some cars.
Perhaps there was a quality control issue that got fixed on the assembly line (or on the supply-side) after 2013.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
Lonewolf (05-10-2015)
Smoke from exhaust when warmed up after parking Elkton86er Engine, Exhaust, Transmission 1 12-03-2014 03:00 PM
White smoke coming from the exhaust. hansthegerman Engine, Exhaust, Transmission 17 10-02-2013 05:23 PM
Turbo, white smoke out the exhaust, ideas? Synack Forced Induction 44 09-09-2013 10:57 AM
Smoke coming from the Exhaust peachsnow Scion FR-S / Toyota 86 GT86 General Forum 18 12-09-2012 03:59 AM
Smoke from new USA TRD exhaust DaveFTW Engine, Exhaust, Transmission 22 10-03-2012 05:03 PM
