Old 06-17-2012, 09:00 PM   #43
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Originally Posted by Jason@Nameless View Post
I'm with Don. The tensioner pulley is on a spring loaded tensioner so seeing it move is probably not that big of a deal. Maybe compare it to another FA20 engine if you want some extra assurance.
My engine chirps too (idle or not), but after driving it a few miles. However here is a clear video of the tensioner shaking its tailfeather. Not saying its an issue, just showing its action. When I can hear my engine chirp I'll record a video.
Recorded with a Panasonic Lumix GF1 on a CF tripod.
[ame="http://www.youtube.com/watch?v=5ZC_XsJuZ20"]FR-S BRZ Belt Tensioner.mp4 - YouTube[/ame]
F1point4 is offline   Reply With Quote
Old 06-17-2012, 09:55 PM   #44
csaba
Drives: scion tc
Thanks for the video !!
By any chance can you press on the tensioner pulley. Against it by hand I assume it should not be easy to do so. Obviously when the engine is off ,to see how strong that spring is .
It should be hard to do so
Thank you
csaba is offline   Reply With Quote
Old 06-17-2012, 10:05 PM   #45
Jayde
Jayde's Avatar
Thank you
I wasn't able to move it, but I really didn't put too much pressure against it.
Jayde is offline   Reply With Quote
Old 06-17-2012, 11:08 PM   #46
csaba
Drives: scion tc
Would be good to know if others has the same experience!?
Old 06-18-2012, 10:06 AM   #47
robo_robb
robo_robb's Avatar
Drives: Whiteout FR-S
The Foreman from the Toyota dealer just called me. He did some research and is 95% sure the noise we are hearing is the DI system, which switches modes depending on temperature and other factors.
robo_robb is offline   Reply With Quote
Old 06-18-2012, 10:19 AM   #48
Jayde
Jayde's Avatar
That would make sense, since it seems we don't hear it till after the engine is driven for some time.
Wish it didn't sound like a bad bearing though.
Old 06-18-2012, 10:25 AM   #49
b.e
Drives: 2013 FR-S Hot Lava, 2007 Tundra
I hooked up my cheap Bluetooth ODB2 reader to look at the pressure in the fuel rail...at idle it was above 3000 PSI, and after running a bit it dropped to 1500 PSI. I'm pretty sure shooting fuel at 3000 PSI will make noise.
b.e is offline   Reply With Quote
The Following User Says Thank You to b.e For This Useful Post:
Jayde (06-18-2012)
Old 06-18-2012, 11:31 AM   #50
Fenrir
Drives: Mazdaspeed 3
I've had a Mazdaspeed 3 (with a DI 2.3l turbo motor) for just over two years now, and it makes the exact same noise. Your dealer is correct that it's the DI system.
I suspect that someone will eventually rip the HPFP off and run some testing to see if it can be upgraded. When I upgraded the HPFP in my Speed3, it smoothed the engine idle out and it made less noise under idle. More noise at WOT, but... yeah
Fenrir is offline   Reply With Quote
The Following User Says Thank You to Fenrir For This Useful Post:
Jayde (06-18-2012)
Old 06-18-2012, 11:48 AM   #51
Jayde
Jayde's Avatar
Both excellent things to hear! Thanks!
Old 06-18-2012, 07:57 PM   #52
seannyice81
Drives: 2013 Asphalt FR-S
I still suspect something is a little...off.
I can tell when the DI system switches. I've worked on other DI equipped cars and they all sound pretty much the same. They click-away, but don't chirp. If you ask me, I suspect there is something with the belt (not necessarily the tensioner). First off, It didn't make that chirp noise until a few days into ownership. Secondly this is the first Subaru-based boxer engine I've seen with a self adjusting serpentine belt tensioner. All the other ones I've worked on you turned an adjustment bolt/screw (and they'd squeal if you were a little off). Working as a dealer tech (granted, not Scion or Subaru) I can't help but wonder if there might eventually be a bulletin about this. Im not saying the guy is BS-ing, but there probably just aren't enough instances yet for it to become a "known" issue.
Its almost a clutch release bearing chirp, but the noise is un-changed when the pedal is applied.
seannyice81 is offline   Reply With Quote
Old 06-18-2012, 11:59 PM   #53
Scik
Drives: Argento 2013 Scion FR-S
Yeah, I mean it's good to hear that the source may have been isolated to the DI, but it doesn't change the fact that it really sounds terrible IMHO... Also, would the "upgraded HPFP" cost us any $$$? If so, I say boo... Want my new car to sound new!
Scik is offline   Reply With Quote
Old 06-19-2012, 12:10 PM   #54
Fenrir
Yes, an aftermarket upgraded HPFP would cost you money. I'm not aware of any companies who give away hundreds of dollars of R&D and parts costs for free.
Old 06-19-2012, 09:46 PM   #55
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Here's a vid of mine doing it as well. It seems to be intermediate, since some times it'll do it, and other times it won't. Happened as I was getting back to work after going to the bank and getting lunch.
You can also see the idler pulley moving back and forth in the vid too.
My car has the cricket noise now as well. I'm 1755 miles in. Started this evening. Just did a 850 mile trip this weekend. I will keep a eye on it.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
The Following User Says Thank You to feldy For This Useful Post:
Jayde (06-19-2012)
Old 06-19-2012, 10:15 PM   #56
nataku
Negative Mass
nataku's Avatar
Drives: Orange Metallic AVO Turbo GT86 6MT
Mine has been making these noises since day one. I also have the wonderful chattery clutch at low RPM / high-ish load. Being my first manual transmission, and my first brand new car, I am about as paranoid as they get. The chirping is almost always happening, but the chatter is difficult to pin down. I'll probably take it by the shop sometime this weekend just so they can give it a once over.
I can just see the sarcastic jabs from haters... Clockwork engine (DI sounds) that is powered by a cricket in a small hamster wheel.
nataku is offline   Reply With Quote
The Following User Says Thank You to nataku For This Useful Post:
Jayde (06-19-2012)
Hard shifting into first gear; normal? blalor Engine, Exhaust, Transmission 54 08-31-2017 09:57 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 10:42 AM
What function can it be used for, the idle button place yuli8466 Cosmetic Modification (Interior/Exterior/Lighting) 50 01-29-2013 03:17 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
Scion goes normal terrypm Other Vehicles & General Automotive Discussions 21 05-02-2012 10:16 AM
