#43 | |
Drives: BRZ S
#44 |
Drives: BRZ S
It's depressed to turn on not a constant on like a door switch. I checked the user guide and i tried to unplug the switch up top when in gear. It's so strange I have reverse indicator and the reverse beep is working but the lights flicker when i wobble the shifter or when it moves when in motion. Super frustrating.
#45 |
#46 |
Drives: Many
I had a buddy down below and I worked from up above, if i remember correctly.
I have a lift at home now, so if it happens again it should be easier to deal with. |
#47 |
Resurrecting this thread since it was helpful to fix the reverse light not coming on and to comment the method that worked for me.
I've removed the old/faulty switch clip and plugged in the new one temporally so it dangles from above and to make it easier to grab the bolt end from below. Then, I've jacked up the car and accessed the bolt from below. In order to access the bolt, I needed to remove front pipe so my hands could fit through the area. Once I've created the space, an open ended wrench could be snaked between transmission and transmission tunnel to loosen the bolt. Reverse the sequence to install. *Keep in mind the wire will twist as the bolt is tightened so the clip end needs to be removed to unwind and reinstalled* |
| FR-S / BRZ Reverse/Backup LED Bulbs! See Comparison Photos, Ships Same-Day! | Diode Dynamics | Exterior Parts - Lighting | 72 | 11-30-2021 02:19 PM |
| Diode Dynamics Tail-as-Turn™: Make your LED tail a turn signal & add backup LEDs! | Diode Dynamics | Exterior Parts - Lighting | 192 | 10-04-2017 11:51 AM |
| Reverse gear signal on factory HU harness? | Panman | Electronics | Audio | NAV | Infotainment | 2 | 01-24-2014 10:24 PM |
| Interior LED + Reverse backup package? | Intake | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 07-12-2013 11:46 AM |
| Radio Signal Issue When shifting into Reverse | ruskymx | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 01-22-2013 09:05 PM |
