Old 04-24-2015, 03:18 AM   #43
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
UPDATED the map.
- I had to pull some more timing from the low load 14.7 AFR area because a user was getting IAM drop. The timing won't be missed.
- Economy is exactly the same
- WOT timing/power is exactly the same.
- Updated cranking values for 10C and 20C (50F and 68F) columns.
- Copy from the unlettered version "v44".
- Versions labelled "F" i.e. "v44F" have the exact same total timing as normal, but flat 6 deg knock correction advance. These are for analyzing where it's knocking due to the map being lumpy, don't flash these.
The Following User Says Thank You to Wayno For This Useful Post:
Trettiosjuan (04-24-2015)
Old 04-24-2015, 04:07 AM   #44
steve99
Originally Posted by Wayno View Post
UPDATED the map.
I got a bit of that knock when cold so fixed it with coolant temp timing retard for coolant temps below 60c and also adjusted the pi\di ratios for more di arround 2000/3500 rpm, still testing but looks promising
The Following 2 Users Say Thank You to steve99 For This Useful Post:
solidONE (04-24-2015), Trettiosjuan (05-01-2015)
Old 04-24-2015, 04:19 AM   #45
Wayno
Wayno's Avatar
This guy was on caltex which is probably the cause for most of his knock. I was getting -2 around the 3600rpm/0.7 range. Both areas are in closed loop, so I reduced the minimum I could from those areas, keeping the whole map smooth. Both cars with same headers and stock exhaust, just driven differently. I didn't get any IAM drop, he did.
His log
http://datazap.me/u/notrq/caltex-fle...-14&solo=10-11
My logs (I did 11 last night)
http://datazap.me/u/wayne/
I figured dropping timing from that cruise area is a small price to pay for better guaranteed IAM under load.
I tried to keep as much timing in 0.8 as possible as it's already pretty low, I dropped more from 0.7 so it doesn't ramp up there as aggressively.
Here's the diff from v33-v44.
Old 04-24-2015, 08:41 AM   #46
steve99
agree caltex fuel seems worse than shell or bp.
you could try reducing the pi to 25% in that area think its 50% at present but pulling that bit of timing not going to hurt as you say.
Old 04-25-2015, 09:08 PM   #47
504
504's Avatar
Drives: 2014 86 GTS
So I've been using the v33 el e85 tune on a stock 86 running eflex and I can confirm that I have been getting the slightest drop in fblk/flck (-0.6--0.75 once every 30 min driving session) under light load 3k rpm and heavy load 7400rpm. V44 should be good for this.
One issue I have been experiencing with v33 is somewhat erratic ltft staying at 6% on idle and hardly dropping from there. It goes up to 8% sometimes but under driving conditions it does drop to between -2-4%. So I take it from previous posts the original oft maf scale is best for stock airbox running a bigger range of ethanol concentrations? Would Steve/waynos o2 sensor scaling have something to do with this also? These are the main changes I see on v33 that could contribute to higher fuel trims
edit: I also tend to run rich under open loop reaching 10.5 AFR, I assume this comes part of universal tunes right?
Thanks in advance
504 is offline   Reply With Quote
Old 04-25-2015, 10:05 PM   #48
steve99
Thanks in advance
How are you measuring the 10.5 afr ? stock o2 scaling in oft tujes only goes to 11.25.
yes the ol maf scaling used in the standard oft tune make most cars run quite rich in open loop i gather its a safety thing, but since i only use united e85 i dont need it.
however i tested my tune a couple of weeks ago by running it down to fuel light so about 8 litres of e85 left then put in 12 litres of petrol, ran rich for a bit till fuel trims adjusted, no knock, drove it for 100 km or so no dramas, filled up with e85 again ran a bit lean did get some knock about -2 and iam drop to 0.7, till fuel trims sorted again then no dramas, i have increased the amount of knock correction timing in the knock correction max A table so the iam is verry agressive in countering knock though. running same overall timing though.
Old 04-25-2015, 10:29 PM   #49
504
504's Avatar
Drives: 2014 86 GTS
I have been monitoring with the openport 2.0
one instance of fblk/flck drop every drive seems ok compared to waynos logs, I think i may drop base timing B in areas I have been noticing it
my greatest concern right now is ltft, I am thinking of reverting to OFT e85 v23 maf and o2 scalings but am not sure if it will be the solution
For the sake of building the forum knowledge pool, why were intake and exhaust avcs modified in this latest update?
Old 04-25-2015, 10:37 PM   #50
steve99
I dont think wayno adjusted cam timings.
however it looks like he put ztans o2 sensor scaling in his roms so sensor reads richer.
if your actually running that rich in the 10 afr range that can cause knock you dont need to be anywhere near that rich on an NA car with E85 about mid12 is fine, i am running the full timing 33degrees at about 12.5 afr on united e85 without knock 7000 rpm
Old 04-25-2015, 10:50 PM   #51
Wayno
Wayno's Avatar
You don't need any other maf scale besides the ots one up to 3V, let LTFT do its job. Just change the open loop cells to flatten the curve and run 12.0 up to 7000 rpm.
Did you look at EL cam tables instead of UEL?
The sensor only reads richer and more accurate below 12.
Old 04-25-2015, 11:17 PM   #52
504
504's Avatar
Drives: 2014 86 GTS
I haven't yet setup datazap, sorry for any inconvenience
In a half hour log, flkc only drops in one instance as seen from the picture in previous post. Timing is mostly good then
ltft is not really stable. the peaks seen from the graph are from idling and am thinking of running ots v23 maf scale due to this seen below. Im not really sure on o2 sensor scaling aswell as the car is supposedly reading really rich (10.5).
the image here is just for reference comparing ots maf vs the latest one which I am currently running leading to potentially erratic ltft. It also shows the avcs changes wayno made with his UEL tune
Old 04-25-2015, 11:20 PM   #53
Wayno
Wayno's Avatar
Please compare anything to shiv's ots tunes then report any errors, not compared to my previous examples which may have the errors.
Old 04-26-2015, 12:52 AM   #54
Wayno
Wayno's Avatar
In screenshot comparing EL to UEL as i said before.
If you want to customise your maf scale, steve has tons of info for that.
v33 and later has ots e85 maf scale instead of petrol scale so it's less instrusive. You should forget the previous releases.
504 (04-26-2015)
Old 04-26-2015, 03:39 AM   #55
Trettiosjuan
Drives: GT86
Also noticing the high ltft when idle or releasing throttle, I only copied the economy related tables and this started as far as I can tell when I zeroed the CL Fueling Target compensation tables (A+B) which I skipped the first time. Don't fully understand the purpose behind changing these...
Trettiosjuan is offline   Reply With Quote
Old 04-26-2015, 03:50 AM   #56
Kodename47
Kodename47's Avatar
Drives: UK GT86
I've had a quick scour of this, might be worth a read. They mention advancing the intake AVCS might help quite a bit. However having not seen the maps I can't confirm if this is already the case.
http://www.romraider.com/forum/viewt...p?f=15&t=10725
.: Stealth 86 :.
Kodename 47 DJ:
Help uploading 2.06 tunes to OFT Jimmy817 Software Tuning 3 12-28-2014 09:06 PM
Custom Az Tunes Juggles Arizona 13 11-08-2014 10:15 AM
EcuTek Tunes Rio Engine, Exhaust, Transmission 1 04-29-2014 12:10 AM
How long until *other tunes? ScionFrsFan Engine, Exhaust, Transmission 61 12-07-2012 05:34 PM
Speedhunters - TRD TUNES THE 86 quik1987 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 69 05-22-2012 04:26 PM
