Old 01-28-2015, 02:03 PM   #43
xero404
updated the template file last weekend and had no idea what i was doing lol. the data logging has helped me really ease my mind that the oil cooler is helping out on the track though (never gets past 215F) YAY!
I didn't see anyway to set the oil temp alert on the new template but for now i just check logs after the day is over.
that and figuring out how to add the BPB updates to the new 2.0 flashes would be pretty peachy.
oh here's the log from Session at Laguna seca if anyone is interested.
http://www.datazap.me/u/xero404/mrls...4?log=0&data=2
xero404 is offline   Reply With Quote
Old 01-28-2015, 08:54 PM   #44
TJ3000
Drives: MT Raven Black FRS
@Shiv@Openflash I think what the people are dieing to know is... What is this tune bot function.... What is it? What is the tune bot's name? What can "Tune Bot" do for me as well as what can I do for "Tune Bot"
TJ3000 is offline   Reply With Quote
Old 01-31-2015, 12:18 PM   #45
itsjustdavep
itsjustdavep's Avatar
Drives: Asphalt Scion FR-S
THIS! it's driving me nuts and I wanna know what it is
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
itsjustdavep is offline   Reply With Quote
Old 02-01-2015, 06:06 PM   #46
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
so i have a problem with the manager. ive redownloaded it since a fresh windows install and any time i try to open it, it jus says PWGPro has stopped working instantly. Under details the event name is CLR20r3.. any help. never seen this before
IG-Joey_Soul
Old 02-01-2015, 06:08 PM   #47
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Do the resent OFM updates change anything around logging? I logged on the previous non alert firmware, plugged in, updated (had no choice) and OFM crashed after reading my log, at the point where it should be rendering the results. Reinstalled 1.16, same thing happens.
Old 02-01-2015, 09:35 PM   #48
steve99
did you get new template FRScustomised5.slt i think ??
Old 02-01-2015, 09:47 PM   #49
Wayno
Wayno's Avatar
Yes i tried before and after updating the template. Looks more like an ofm problem than tablet problem.
Old 02-01-2015, 09:52 PM   #50
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Try deleting your Openflash folder and downloading it again from the website.
Old 02-02-2015, 09:23 PM   #51
PMok
Codename: Stitch
PMok's Avatar
is the how-to video up yet? Or has anyone successfully set up an alert using the new functions?
Old 02-03-2015, 12:58 AM   #52
Wayno
Wayno's Avatar
Same thing happens.
Old 02-03-2015, 01:03 AM   #53
steve99
yes using knock alerts fot FBKC and Knock Correction , and speed alert works too.
Old 05-02-2015, 02:02 AM   #54
steve99
Try downoading it again from the website.
@Shiv@Openflash
Hi Shiv,
Think I have discovered a bug in tuning Alerts. I am pretty sure it worked fine initially. But appears and update may have introduced a bug.
Now you cannot set up alerts with "OR" the oft screen says OR and then you save alerts but when you check them its set back to AND.
Trying to set these up these three separate alerts
Coolant greater than 212
OR
OIL TEMP greater than 240
FLKC less than -1
OR
Knock Correction less than -1
OR
Advance Multiplier less than 0.9
AFR greater than 13.5
AND
RPM greater than 5000
AND
Load greater than 1.0
I save it and all looks ok , but go back in and check and every alert set to AND
ie all the OR become AND on save
Also when any alarm triggers you cannot reset it with reset button it just keep beeping/flashing and reset is greyed out for some reason
Running 1.19.0 and Template 7.1
Could you have a look
Thanks
Steve
Old 07-24-2015, 10:44 AM   #55
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Did anyone get an explanation of the Tune Bot? I just flashed back to 91 oct after a few months of E85 and I don't recall seeing this before.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 07-24-2015, 10:50 AM   #56
mid_life_crisis
Drives: FR-S 10 #103 AT
I'm pretty sure that's a teaser for a future update.
Official OpenFlash Tablet FA20 Tuning Tech Discussion Thread Rombinhood@OpenFlash Software Tuning 2594 08-01-2017 01:03 AM
Weird template issue after 131 update fantah Software Tuning 5 03-31-2016 08:57 PM
[OFT] OPENFLASH TABLET: Tuning flexibility in one convenient package Garrett@Openflash Engine, Exhaust, Bolt-Ons 62 07-10-2015 02:40 AM
Local tuning shops who will tune with OpenFlash Tablet? Silver Ignition NY / NJ / CT / PA 24 02-20-2015 07:08 AM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 03:35 PM
