Old 07-29-2012, 09:50 PM   #43
lordtakuban
lordtakuban's Avatar
Drives: 2013 FRS - Whiteout
I did mine this afternoon. WOW! It is so much better now. Thanks to the OP and others that mentioned where a good spot was with the pedal being right about the same height as the brake but ever so slightly lower. The engagement happens a little after releasing from the floor and feels a lot more natural now.
The hardest part for me was getting a good angle on the locking nut with the 12mm wrench. I had to lie on my back and keep positioning around the other pedals until I finally got a good spot to grab hold. The rest worked quite easy. And it is very true that a little rotation goes a long way with moving the pedal.
I did not need to adjust the clutch engagement sensor with the little bit that I moved the pedal. Selected gear display still works and I am assuming cruise control still works as well, but I just went around the block to test shifting and making sure the pedal was set right.
Thanks again for the info. It has definitely increased my driving experience with this car.
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified
lordtakuban is offline   Reply With Quote
Old 07-29-2012, 09:55 PM   #44
Synack
Boosted
Synack's Avatar
Drives: Sideways
a left hand glove is your best friend
Old 08-03-2012, 12:18 PM   #45
Koji_Online
N7 Spectre
Koji_Online's Avatar
Drives: 2017 Toyota 86 (Ablaze - 6MT)
Smile
Originally Posted by Synack View Post
YES! Thanks for this. Stock clutch lets out so high it feels like the clutch is almost completely burnt out! Personally for me, this way I can use less clutch and it'll last longer and shift smoother and more comfortably
Originally Posted by lordtakuban View Post
Fantastic guide! Thanks for posting it and thanks for the pictures. I will adjust mine this weekend. It is definitely needed. Now I need to go find that gear indicator setting...
THIS. I just adjusted mine a few times. It's absolutely perfect when it sits verrrrrry slightly below brake pedal. Like 1mm below. It's amazing how much the feel changes with even the tiniest change. If you set it barely below the brake, the cruise control will still kick in easily with no problem.
Improved driving experience is what it's all about! It's awesome most people also found the most comfortable point to be having the clutch just slightly lower than the brake.
As for the questions about if this method will work with adjusting the brake pedal, I personally wouldn't touch it because in the stock stroke; when you are braking hard, the current brake position puts you right in line for smooth heel-toe downshifting; moving the brake pedal further towards the firewall would possible make things awkward =P
GT 6/ Sport PSN: Koji_Online
Koji_Online is offline   Reply With Quote
Old 08-03-2012, 02:57 PM   #46
jarviz
jarviz's Avatar
Drives: Raven FRS MT
AH i wanna try this so bad, but don't wanna mess it up and kill myself
jarviz is offline   Reply With Quote
Old 08-05-2012, 12:26 PM   #47
NRGBalanced
NRGBalanced's Avatar
Drives: '13 Subaru BRZ Limited WRB
Followed the instructions and it worked out great! Rollout is so much smoother. I think it will even be easier to teach my GF how to drive standard, because now you can just clutch-out/gas-in simultaneously, rather than waiting to push the gas. Thanks for the DIY!
I also had a bugger of a time trying to get the rod to turn. Lacking any grip gloves, I grabbed a pair of needlenose Vise-Grips (which, BTW, have saved my ass SO MANY TIMES while working on cars) and adjusted them to give a very loose bite on the rod. I scratched the rod a bit while I was working out how to do it right, but no one will ever notice :-) It took a long time turning the rod 1/8 turn at a time, but it was a lot easier for me.
NRGBalanced is offline   Reply With Quote
Old 08-05-2012, 03:46 PM   #48
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Thanks! This took a while because I don't have the frame of a small, Japanese auto worker. Gah, gonna need a chiropractic visit but, damn .... it was worth it!
cobrabyte is offline   Reply With Quote
Old 08-06-2012, 08:28 PM   #49
thatWESguy
Power Ranger
thatWESguy's Avatar
Drives: 86
big props to OP on figuring this out, super easy fix and no more guessing on where the engagement point is!
Super easy to do, only took about 10 minutes. Luckily for me, I'm a small Asian man who can fit into the smallest of spaces lol, one of the few times where my stature is actually an advantage
cheers! :happy0180:
thatWESguy is offline   Reply With Quote
The Following User Says Thank You to thatWESguy For This Useful Post:
nix (06-07-2013)
Old 08-06-2012, 09:25 PM   #50
EvoXDD
Trident Motorsports Owner
Drives: DGM. DD for my EvoX
I did mine. Hope I did it right and not to much. When you ease out clutch at first my car would just keep going without gas at all. Eased out the pettle a little and now it doesn't seem as bad, could just be me doubting myself
previous cars:1998 chevy s10 2001 Prelude SH 1992 (JDM)RX7 FD Current Cars:2010 Mitsubushi Evo X GSR 2013 Subaru BRZ Sponsors:Mishimoto/Flossy/Tomei
Craig.tridentms@gmail.com
EvoXDD is offline   Reply With Quote
Old 08-09-2012, 08:11 PM   #51
PRORICAN
PRORICAN's Avatar
Just finished mine and now I'm going on a test drive. Thanks OP!!!
PRORICAN is offline   Reply With Quote
Old 08-09-2012, 10:03 PM   #52
PRORICAN
PRORICAN's Avatar
Test drive went great! I did some more adjustments and after the third drive it is now perfect. I hated the stock engagement.
The Following User Says Thank You to PRORICAN For This Useful Post:
EvoXDD (08-09-2012)
Old 08-10-2012, 12:14 PM   #53
TennisHsu
TennisHsu's Avatar
Drives: 2013 Whiteout MT Scion FR-S
I wish I had adjusted my clutch position sooner!! the difference is amazing! I was never comfortable with the high engagement from the beginning, lots of over revving and jerky starts, especially on hills! did what OP recommended, clutch level a touch lower than the brake, and shifting is smooth as butta now! I'm sure my transmission is thankful as well!
TennisHsu is offline   Reply With Quote
The Following User Says Thank You to TennisHsu For This Useful Post:
jcw99 (03-30-2016)
Old 08-10-2012, 08:54 PM   #54
so26
Drives: Raven FR-S 6MT
I can't thank the OP and the guys who uploaded pics enough. I made the adjustment within less then 48hrs of owning my FR-S and it made a huge difference.
I'm surprised that none of the "professional" reviews that I've seen and read mentioned anything about it.
so26 is offline   Reply With Quote
Old 08-10-2012, 10:36 PM   #55
MY13FRS
***** Super Senior Member
MY13FRS's Avatar
Drives: 13 FRS
Sadly, I tried and couldn't do this mod as my back gave out 15 mins of trying to get under the dash.
Too bad, as I too feel the clutch travel is waaaay too long.
MY13FRS is offline   Reply With Quote
Old 08-11-2012, 08:00 AM   #56
so26
It is awkward to get under there and make the adjustment. Other then paying someone to do it for you, if you took the driver's seat out that might help free up some room so you could make the adjustment.
BTW, Mods this should be a sticky!
The Following User Says Thank You to so26 For This Useful Post:
SkAsphalt (08-17-2012)
clutch adjustment, clutch helper spring
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 03:41 PM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 10:17 PM
Any (easy) way to stiffen up the feel of the clutch? Partial Stall Engine, Exhaust, Transmission 41 07-19-2012 02:17 PM
My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* wanger Scion FR-S / Toyota 86 GT86 General Forum 5 06-02-2012 01:41 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
