#43 |
Drives: 2014 WRB BRZ Limited
I can't imagine you needing to spend any more than $200 for TRD springs, which will give you the perfect 2 finger wheel gap you're looking for, stiffer than stock, more composed ride (less bouncy over rough roads), and more comfortable (subjective). Really not sure why people feel compelled to pay $1000 for a suspension set up that's going to be worse than a set of quality aftermarket springs for 1/5 the price. If you're on a budget DON'T BUY COILOVERS.
As far as buying a turbo/exhaust/wheels/anything else immediately after purchase, drive the car in its current form for a while before you make massive changes to the car. The car is nearly perfect from the factory and really only needs minor tweaks. Want some really good dd mods? Try clutch spring removal, clutch pedal lowering, stage 1 tune, adjusting mirrors to have no blind spot, correcting your seating position, and removing the cotton ball in your sound tube. These are all completely free and much better for a dd than exhaust drone or a massive turbo. You should not spend a penny on mods until every single one of these are done.
#44 |
STX 188
I'd go with ST, I have it on my e90. It's my daily driver and it rides very smooth. It doesn't have any adjustment on the dampers but it's my DD so it's not an issue.
I got BC for my gf's CT and it rides pretty good, I don't see a problem. I used to be like some of the guys here that judge on some products because of their price range, they proved me wrong and have a very good warranty. $95 to replace a shock if it blows out, with a BRAND NEW one. My buddy got it for his e46, it rode nice, drove it down to SoCal without any issues. I still think proper damper and some lowering springs would ride better simply because of the softer spring rates but it doesn't allow you to drop it where you want.
#45 |
Drives: 2013 Firestorm FRS
riding on ST coils here...would buy them again
#46 | |
Drives: 2015 Scion FR-S
And the cotton ball in the sound tube ? That's the tube that comes from the left side of the intake ? |
#47 |
Drives: Mazda3 2013 / Scion FR-S 2015
i run bc. i love it. sure, some poeple had probleme with their set.
its not like nobody had problem with their xbox, cars, tv...nothing is perfect on this world. what can we really expect from a 1000$ coilover set? + i can set the height at the level I WANT. |
#48 | |
Drive upgrades. Don't buy them.
#49 |
No rice, no life
Drives: 2013 Asphalt FR-S
| The Following 8 Users Say Thank You to campy For This Useful Post: | BlaineWasHere (12-22-2014), cdrazic93 (01-08-2015), chas3wba0 (12-22-2014), flippy (12-30-2014), hmong337 (12-22-2014), Jake360 (12-23-2014), Jive Turkey (01-11-2015), Koa (12-22-2014) |
#50 |
poverty cause racecar
Drives: Subaru BRZ JRSC'd
That's exactly what my post is saying in an analogy. Could you please attempt to comprehend my post before you try to deny it?
#51 |
sorry i was at work and cant really spend a lot of time on forums. what i meant is that it doesnt work because good meals cost more that junk meals. it would work if eating a steak kept you full longer than eating 6 dollars worth of jack n the box.
#52 | |
The only reason why I say feels underpowered is because we're currently in a culture that pumps out 300hp+ SUVs and family sedans, 700hp challengers, etc. etc... the 86 is not quick, but good lord is she fast, especially when the roads start to take shape. |
| The Following 4 Users Say Thank You to Koa For This Useful Post: |
#53 |
| The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
#54 | |
Drives: 2013 FRS / 2013 427 Vert
Before you buy anything I would ask yourself specifically why you want coilovers. With that in mind you can decide if a low cost option will meet your needs. From my experience if comfort is a priority then skip this mod until you can afford something similar to a V3. For those who primarily want to be quicker around a track then the BC's are fine as part of an inexpensive upgrade plan.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
#55 | |
And the sound tube is the tube that comes from the left side of the intake. If you look inside the cabin where the passenger's feet would be and move back the floor mats, you should see the other end of the tube. A set of needle nose pliers and a flashlight are all you'll need to remove that cotton ball. Those two mods together give the car a menacing growl between about 3-4k rpms, and improves the tone through redline. Don't you need to get the alignment adjusted every time you adjust height? I guess if you have all the tools and know-how and a lot of spare time, this probably isn't a big deal, but it is much more complex than turning 4 screws. Oh, and the more adjustability you have in your setup, the harder it is to align correctly. People do adjust without aligning, but then again, people cut their springs and install steering wheels without airbags on their DD's. Just because you CAN doesn't mean you SHOULD.
| The Following User Says Thank You to xxBrun0xx For This Useful Post: | propulsion1 (03-07-2015) |
#56 | |
Check out Race Comp Engineering and maybe give them a call: http://www.racecompengineering.com/i...uspension.html |
| Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! | No Limit Motorsport | Brakes, Suspension, Chassis | 204 | 05-26-2017 01:09 PM |
| Buddy Club Racing Spec Coilovers - SpeedFactory Style - Good Photos and Video. | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 47 | 03-25-2016 06:22 PM |
| megan ez street coilovers good or bad? | juanam0909 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 10-02-2013 05:34 PM |
| Hi guys anyone know a good local shop to get tein coilovers ?? | s1monn | Southern California | 3 | 01-28-2013 06:30 PM |
| anyone know of any good shops to install my Tein Flex adj coilovers in El Paso?? | FRS-HHH | Southwest | 12 | 10-13-2012 02:58 AM |
