#43 |
http://www.crutchfield.com/p_142SAT6...er-reviews-tab
These were all I ended up needing They lined up just right. |
#44 | |
Drives: 2011 WRX
http://www.crutchfield.com/p_142SAT6...ts.html?tp=919 Those adapters that CF sends are useless in Subaru (non-BRZ) applications. |
#45 |
I measured them up the top 2 are 7 5/8" apart with the bottom one being 8 1/8" from the top 2. From the bottom of the speaker mounting plate the stock one is 1 1/16" high then some foam. Theres more room than that to work with though. Using those CF brackets I was able to mount some Infinity Kappa components on top with some space. I don't have a mm tape measure laying around or I'd check it that way. What I measured should be really close though.
#46 | |
Drives: 2011 WRX
#47 | ||
Drives: 2011 WRX
Reconciling the posts below, I got confused.
If you measured 7 5/8" and 8 1/8", respectively, the adapter in your first link would not have worked. Those measurements are off of the plastic. Also, in looking at your picture and using the measuring tape over the speaker, it looks like the "close" holes are closer to 6.5" apart. Due to the angle of the picture, I can't tell about the 3rd hole. ![]() Could you possibly re-measure the speaker and report back findings? Thanks! |
#48 |
doh lol
. I know what I did. subtract an inch from what I got. i was starting at 1inch instead of the clip on the end of the tape. Those brackets i used worked I didn't have to cut them at all to get it to work.
#49 |
Drives: 2011 WRX
#50 |
#51 | |
Drives: 2011 WRX
#52 |
Drives: 2011 WRX
Based on the pictures and measurements above, I was able to fabricate these templates for adapters:
![]() I made some PVC adapters (3/4" for the doors and 1/4" for the dash in which you could mount component tweeters). Two sets already went out for beta testing. ![]()
#53 |
Drives: 2002 BMW 325i
Thanks so much for the pics of the dash speakers. I'd love to see a pic of the 'hole' left after you pull the 3.5" speaker out of the dash......is there a cavity? does it vent to the inside of the dash?
2013 Subaru BRZ Limited
Pioneer.Mosconi.Morel.Audible Physics.Ascendant Audio |
#54 |
First 86 Driver Baby!
Drives: FR-S, Flex
Did anyone ever measure the depth behind the rear side panels? I'm contemplating putting an 8" sub on either side when I get my car back.
#55 |
wow not an easy factory fit car huh
#56 | |
Drives: FRS 6MT
Thanks for the pics and measurements. Looks like I'll be reusing the pioneer 6.5 speakers i have sitting in my garage. As long as they fit. |
| New Wheel Sizes/Photos from Rays / Volks | BPAuto | Wheels and Tires | 68 | 12-12-2013 06:14 PM |
| Stock FRS Headunit/Speaker preformance | jflogerzi | Electronics | Audio | NAV | Infotainment | 8 | 06-03-2012 02:03 AM |
| 8 Speaker stereo specs? | Rstalter77 | BRZ First-Gen (2012+) — General Topics | 56 | 04-24-2012 05:43 AM |
| Thoughts on ease of speaker replacement? | ahausheer | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 11-29-2011 12:16 PM |
