#43 | |
Stig's dark passenger
So, essentially, youll be turning your car into a 3 speed at the track?
#44 |
Which Tremec?
First off, the 6060 is the same thing as the 56 Mag. Both of those trannies will be fine at 7500, whereas the TKO, the T5 and even the older T56 (to an extent) will not! |
#45 |
TKO is not 5k. The 56mag WILL FIT and with relatively minor modifications. Please stop telling people that it doesnt fit. And, the magnum can be had for 2800 whichnis an absolutely fantastic deal. Bellhousing would have to be manufactured of course, as well as shifter, etc. etc. All modifications a person should be comfortable with - long before partaking in this conversation. |
#46 |
Junior
Drives: a car
Depending on if you're willing to get a gear set made from another company.
#47 |
Just looking at the spread....
Not too far off from our 1st and 6th. Im finding 4 (somewhat) useable gears in our trans lacking. Whos going to make a spray bar with a cooler kit? That should getus an extra 75lb/ft on our trans?? |
#48 | |
in orbe terrum non visi
Drives: violent
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
| The Following User Says Thank You to Reaper For This Useful Post: | ATL BRZ (12-18-2014) |
#49 |
Junior
Drives: a car
....so I still like the beefed up R154 option. Is the bell housing the same for the V160 as the R154? Or would @FullBlown need to make an R154 converstion too?
#50 |
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
bellhousing bolt pattern is the same with a JZ R154, not the same with a 7M R154 but the bellhousing is removable.
| The Following User Says Thank You to JP For This Useful Post: | cdrazic93 (12-04-2014) |
| FRS Tranny | C130NAV | Want-To-Buy Requests | 4 | 10-30-2014 11:01 AM |
| Is the tranny stubborn | BrianBlueBRZ | Engine, Exhaust, Transmission | 9 | 06-16-2014 07:39 AM |
| manual tranny | bjun | BRZ First-Gen (2012+) — General Topics | 19 | 01-29-2013 06:57 PM |
| Confirm Tranny Oil | Mac1235 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 12-31-2012 03:37 PM |
| MT vs AT tranny... better MPG, 0-60? | subatoy | BRZ First-Gen (2012+) — General Topics | 163 | 03-26-2012 07:08 PM |
