Old 12-04-2014, 10:08 AM   #43
D K
Stig's dark passenger
So, essentially, youll be turning your car into a 3 speed at the track?
Originally Posted by cdrazic93 View Post
I would get a rebuild on an R154 anyway, most rebuilders say the thrust washers are what most fail on since they're cast.
For $1600 the rebuild from jacks transmission looks to be a good working over. Total all in $3-3500 for a beefed up R154? Yes please.
http://www.jackstransmissions.com/pr...e-3-supra-r154
First- 3.251:1
Second- 1.955:1
Third- 1.310:1
Fourth- 1.000:1
Fifth- 0.753:1
Thats your spacing
D K is offline   Reply With Quote
Old 12-04-2014, 10:10 AM   #44
D K
Which Tremec?
First off, the 6060 is the same thing as the 56 Mag.
Both of those trannies will be fine at 7500, whereas the TKO, the T5 and even the older T56 (to an extent) will not!
The only problem is, do the Tremec spin to 7500 reliably?
**** it, who wants an auto 3 speed that will support anything under a jet engine?
Old 12-04-2014, 10:15 AM   #45
D K
Originally Posted by Reaper View Post
Tremec tko(the magnum won't fit) 5.5k $
TKO is not 5k.
The 56mag WILL FIT and with relatively minor modifications. Please stop telling people that it doesnt fit.
And, the magnum can be had for 2800 whichnis an absolutely fantastic deal.
Bellhousing would have to be manufactured of course, as well as shifter, etc. etc.
All modifications a person should be comfortable with - long before partaking in this conversation.
Old 12-04-2014, 10:51 AM   #46
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Depending on if you're willing to get a gear set made from another company.
Old 12-04-2014, 12:33 PM   #47
D K
Just looking at the spread....
Not too far off from our 1st and 6th.
Im finding 4 (somewhat) useable gears in our trans lacking.
Whos going to make a spray bar with a cooler kit?
That should getus an extra 75lb/ft on our trans??
Old 12-04-2014, 02:13 PM   #48
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
TKO is not 5k.
The tko is 2+k. Then it has to be sent to liberty gear so it will shift at our rpm. Then you need a custom bellhousing, shifter, crossmember, a new clutch disk and a new slave cylinder from Don sumerton. Out the door price was 5.5k $ me doing the installation myself.
Old 12-04-2014, 02:22 PM   #49
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
....so I still like the beefed up R154 option. Is the bell housing the same for the V160 as the R154? Or would @FullBlown need to make an R154 converstion too?
Old 12-04-2014, 03:11 PM   #50
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
bellhousing bolt pattern is the same with a JZ R154, not the same with a 7M R154 but the bellhousing is removable.
JP is offline   Reply With Quote
FRS Tranny C130NAV Want-To-Buy Requests 4 10-30-2014 10:01 AM
Is the tranny stubborn BrianBlueBRZ Engine, Exhaust, Transmission 9 06-16-2014 06:39 AM
manual tranny bjun BRZ First-Gen (2012+) — General Topics 19 01-29-2013 05:57 PM
Confirm Tranny Oil Mac1235 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 12-31-2012 02:37 PM
MT vs AT tranny... better MPG, 0-60? subatoy BRZ First-Gen (2012+) — General Topics 163 03-26-2012 06:08 PM
