#43 |
in orbe terrum non visi
Drives: violent
How are the rc6's when cold? My track pads on my bike are a death trap without heat in them.
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#44 | |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
They are amazing so far though I've only used them at Atlanta Motor Speedway so far which isn't very hard on brakes. Road Atlanta this weekend should be a better test.
![]() The Carbotech Bobcat street pads do not make any noises at any temperatures after bedding. |
#45 |
Drives: violent
I'm not to concerned with noise.
In the two wheel world I use ebc sintered pads for street and only use carbon on the track. The carbon tend to "un bed" themselves on the first long downhill corner leaving my house in the morning when cold and never quite recover before I get to work since its mostly uphill from there. I had to re bed them on my rides home!
#46 |
Drives: violent
Csgmike recommended ap s100 for the street. Who's running them?
#47 | |
Site Moderator
Drives: Stuff
They are OK. They aren't the best pads I've used cold and aren't the worst. They are LOUD though and since they are sintered pads are actually smaller than normal so on the BRZ with no anti-rattle provisions they move around a bit. I've driven them cross country (well south to north and back..) a few times on my track car and never felt unsafe at all. They actually aren't even loud on the track car, just the BRZ.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#48 |
Drives: WRB Subaru BRZ Limited
I was kind of in the same situation. I went with the AP sprint kit and figured I'd grow into them. I'm currently on XP10s at the track and 1521s on the street all around. I'll move on to XP12s when these 10s are done.
#49 |
Site Moderator
Drives: Stuff
As much as I normally agree with Mike... I wouldn't run the S100s on the street. They are decent pads but too loud. Get one of the pads that others here have had good luck with being quiet.
I still run the S100s myself and I think they'd last forever on the street but the noise is a bit annoying after awhile.
-Dave
#50 |
Drives: White Lancer Evolution X
Is there something wrong with the Brembo GT kits? I hardly ever see those mentioned in these forums, good or bad. But some of the mentioned kits are definitely in the price range.
#51 | |
Lacking brains
Drives: frz
price is a pretty good place to start. at the end of the day if you can justify dropping 5k+ for brakes on a 25k car than you probably had enough brains to buy a better car to start with |
#52 | |
Site Moderator
Drives: Stuff
I've installed and used a $10k brake setup of Brembo race bits (calipers/rotors) and a prototype Ford Racing booster and BMC and they were fantastic bits though. However, like AP, Brembo makes a bunch of different parts. Without having touched the GT kits, I'd imagine that they are similar to the AP Formula stuff quality wise. Spec wise, they are frankly too big for the car for most users (I'm focused purely on function here). I haven't looked at consumables but that all plays a role in selecting brakes for your car. Price wise, I don't think they are close.. isn't the GT kit ~$3,500? Compared to the Essex kit at $2,100.. or the Essex Endurance at $2,600. (to be fair that was the first google price I saw, I didn't go shopping for them). My motivation for a BBK was more or less the following: I destroyed the OEM rotors quick and boiled fluid (good fluid, not the OEM crap, which I did boil as well but...). The factors in picking a BBK were more or less the following: -Functionality in terms of thermal mass and cooling with my target being as SMALL of a brake system as possible to meet my needs with room for reasonable growth in power (due to temps in Florida, tracking FI cars isn't something I prefer to do, at least not aftermarket FI cars) as well as feel/modulation -Component quality -Consumable cost -Weight savings Going with HUGE rotors is just adding weight on most of the cars here.. without a need to do so.
-Dave
#53 | |
Automotive Connoisseur
Drives: too many cars
Not to mention both the OP and myself have over 400whp so being slowed by rotational mass isn't as much of a concern.
LSx Powered 86/ASE Master Certified Automotive Technician
#54 |
#55 |
Nothing except a higher cost. You can't go wrong with the Brembo GT kits, but like any other painted caliper, the paint turns an ugly brown if you actually track it and get a lot of heat into it.
#56 | ||
Drives: 2022 BRZ Limited
I don't see as many FRS/BRZ owners with BBKs though.. Can you provide a link/more info about this? Is this with their steel pistons or thermlock? I wonder if this is a car specific issue or a mismatched kit issueafter certain amount of time and heavy use every caliper will flex for sure.. many makers claim that the Monobloc design tend to flex even more than the 2 pc designs (unless it's an F1 superior race brakes ) Quote:
link to source: http://zeckhausen.com/Testing_Brakes.htm#Summary
| Deciding on LCA's. | natesparxxx | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 61 | 08-17-2014 01:33 PM |
| Need help deciding on Exhaust | DannyFRS | Engine, Exhaust, Transmission | 1 | 02-23-2014 05:10 PM |
| Deciding on an exhaust | JohnAyySays | Engine, Exhaust, Transmission | 32 | 12-28-2013 11:31 PM |
| What other car did you consider before deciding on the BRZ? | txeng86 | BRZ First-Gen (2012+) — General Topics | 132 | 10-30-2013 03:49 AM |
| Deciding between... (help appreciated) | rainmonkey | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 38 | 08-27-2013 03:53 PM |
