#43 |
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
#44 | |
APEXHNTR
Drives: 10 Series FR-S #1867
okay cool…worst case scenario I can play with this a little…my aim is to have less of a "peak" in that problem area?
2013 Sc10n FR-S 10 Series #1867 of 2500 in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer] |
#45 |
The Mechanic
Drives: Civic Turbo,FR-S
so what exactly does timing compensation per cylinder do?
#46 |
Hicas Thread Basher
#47 |
#48 |
#49 |
Drives: 2013 BRZ Limited
I downloaded RomRaider, loaded the RR_ZA1JA01C definition that I downloaded from the OFT site, opened the A01C 91 octane bin file, and when I open the tables in the instructions, the tables are incorrect. I get RPM down the left side, and a bunch of gibberish numbers across the top of the table (Timing Compensation per Cylinder tables).
RomRaider gave me a bunch of corrupt data mismatch errors: Checksum No 1 invalid P0300 P0355 P0604 WTF am I doing wrong? Shiv, please send me a 2.01 91 octane A01C BPB modified map or if someone has one, please upload it.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523 Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car www.makesmodels.com www.camautomag.com |
#50 | |
Hicas Thread Basher
#51 |
Where's the link to the 2.01... I can't find it.
#52 |
Disregard, I found it. No help with the search function as "2.01" can't be found.
#53 |
Quick review: This map is definitely smoother than the previous 1.59 tune. It does feel like there's more power up top.
#54 | |
#55 |
Drives: UK GT86
What the per cylinder timing compensation does is allow for different ignition timing for different cylinders. In our case on a standard map, it retards timing in cylinders A and B, which I'm pretty sure are the rear 2 cylinders, but I'm not 100%. As to why, there is plenty of speculation out there but I guess that no-one bar Subaru/Toyota actually know. From my reading the possible list is (and may not necessarily be just one of below): Knock Sensor Location if only 1 sensor - So that the cylinders closest to the sensor are the ones that will knock 1st, knock detection is easier. Heat - Maybe the cooling (oil &/or water) systems are more efficient in some cylinder than others, making some more knock prone Manifold Design - Both intake and exhaust, possible flow differential between cylinders require a change in the timing There's a good long debate on RomRaider and there is no defined answer. There's definitely signs that on older STi's, cylinder 4 was more advanced (ie positive values in the PCC) than the rest and was more often the 1st cylinder to go. Others have 2 cylinders more advanced, and that is usually 2 and 4 (same bank). Now, I don't know where the knock sensor is on the FA20 so I don't know if cylinders 1 and 2 being retarded is for the same thing, as that would mean the knock sensor is on the front of the block - assuming the layout is: R 1 2 3 4 F This is why I asked Shiv why he thinks this is a good idea. It seems (from other reports) that the car will run better with the compensations zero'd out, so I don't see why you couldn't/wouldn't do this on any tune but 1st of all I'd like to be sure why it's there in the 1st place as it could protect the longevity of your engine. If it is knock related, I would be looking to have a completely knock free tune before you change the PCC.
.: Stealth 86 :.
#56 | |
APEXHNTR
I flashed to the 91 tune this morning and drove to work...I'll do a pull on the way home and post
| Vishnu Tuning's Tales From The Dyno: Crawford Billet Power Blocks | Shiv@Openflash | Engine, Exhaust, Transmission | 129 | 11-24-2017 07:58 PM |
| Crawford Billet Power Blocks | smbstyle | Engine, Exhaust, Transmission | 799 | 01-18-2016 05:01 PM |
| Crawford Billet power blocks | Triumphrider | Engine, Exhaust, Transmission | 0 | 08-01-2014 01:39 AM |
| FS: One set of barely used Crawford Billet Power Blocks | Robert@Openflash | Engine, Exhaust, Bolt-Ons | 1 | 06-07-2014 04:13 PM |
| **Crawford Power Block Install Special -- R/T Tuning -- Call Today** | R/T Tuning | Engine, Exhaust, Bolt-Ons | 3 | 05-21-2014 11:18 AM |
