Old 08-04-2014, 08:27 PM   #43
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
Originally Posted by Silver Ignition View Post
can you guys tell me if I'm in the right area here…
should I be pulling those 20.62's back to 18.16 or the other 18.87?
you're at the right spot, but not on the right map
i've edited Base Timing B, you will see the timing is higher on the other map!
Walla Walla is offline   Reply With Quote
Old 08-04-2014, 09:49 PM   #44
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
Originally Posted by Malt View Post
Just use the 91 octane maps and try some logs. The only difference between the 93 and the 91 is the timing is 1.05 degree higher on the 93 maps above 6k like @Kodename47 pointed out. Far simpler and less chance for you to accidentally mess something up unintentionally.
yeah, I'm with you there! Uploading it now…I'll flash it in the AM and drive to work, then do a log on the way home…still on the same tank of gas too so we'll at least have some constant
okay cool…worst case scenario I can play with this a little…my aim is to have less of a "peak" in that problem area?
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 08-04-2014, 10:28 PM   #45
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
so what exactly does timing compensation per cylinder do?
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 08-04-2014, 11:01 PM   #46
Walla Walla
Hicas Thread Basher
yeah, what he said! still curious
Old 08-04-2014, 11:23 PM   #47
steve99
Drives: FT86
AFAIK per cylinder compensation is due to some cylinders being more knock prone than others so it allows you to adjust timing on a per cylinder basis,
Old 08-04-2014, 11:26 PM   #48
steve99
Drives: FT86
yeah that's a really weird spike…that's right in the wheelhouse where this thread is aimed too…6200-6700
as suggested by others its easiest just to run 91 tune , just timing top end pulled over 93 tune
Old 08-05-2014, 12:28 AM   #49
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
I downloaded RomRaider, loaded the RR_ZA1JA01C definition that I downloaded from the OFT site, opened the A01C 91 octane bin file, and when I open the tables in the instructions, the tables are incorrect. I get RPM down the left side, and a bunch of gibberish numbers across the top of the table (Timing Compensation per Cylinder tables).
RomRaider gave me a bunch of corrupt data mismatch errors:
Checksum No 1 invalid
P0300
P0355
P0604
WTF am I doing wrong?
Shiv, please send me a 2.01 91 octane A01C BPB modified map or if someone has one, please upload it.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 08-05-2014, 12:35 AM   #50
Walla Walla
Hicas Thread Basher
P0300
P0355
P0604
did you download the 2.01 package, with the tune and XML also inside? and did you load the right XML in romraider?
Old 08-05-2014, 12:40 AM   #51
zdr93523
zdr93523's Avatar
Where's the link to the 2.01... I can't find it.
www.makesmodels.com
www.camautomag.com
Old 08-05-2014, 12:46 AM   #52
zdr93523
zdr93523's Avatar
Disregard, I found it. No help with the search function as "2.01" can't be found.
www.makesmodels.com
www.camautomag.com
Old 08-05-2014, 01:51 AM   #53
zdr93523
zdr93523's Avatar
Quick review: This map is definitely smoother than the previous 1.59 tune. It does feel like there's more power up top.
www.makesmodels.com
www.camautomag.com
Old 08-05-2014, 02:55 AM   #54
steve99
Drives: FT86
P0300
P0355
P0604
Clean out your old defs from RR or at least make sure the def you want is firt on list under manage definitions. Make sure you have correct defs the v201 and v202 are different one is BO1C based and other is D00 based the old 1.5 x tunes were the A01 based tunes, i think thats your problem the tunes are not always based on you calid.
Old 08-05-2014, 05:10 AM   #55
Kodename47
Kodename47's Avatar
Drives: UK GT86
What the per cylinder timing compensation does is allow for different ignition timing for different cylinders. In our case on a standard map, it retards timing in cylinders A and B, which I'm pretty sure are the rear 2 cylinders, but I'm not 100%.
As to why, there is plenty of speculation out there but I guess that no-one bar Subaru/Toyota actually know. From my reading the possible list is (and may not necessarily be just one of below):
Knock Sensor Location if only 1 sensor - So that the cylinders closest to the sensor are the ones that will knock 1st, knock detection is easier.
Heat - Maybe the cooling (oil &/or water) systems are more efficient in some cylinder than others, making some more knock prone
Manifold Design - Both intake and exhaust, possible flow differential between cylinders require a change in the timing
There's a good long debate on RomRaider and there is no defined answer. There's definitely signs that on older STi's, cylinder 4 was more advanced (ie positive values in the PCC) than the rest and was more often the 1st cylinder to go. Others have 2 cylinders more advanced, and that is usually 2 and 4 (same bank).
Now, I don't know where the knock sensor is on the FA20 so I don't know if cylinders 1 and 2 being retarded is for the same thing, as that would mean the knock sensor is on the front of the block - assuming the layout is:
R
1 2
3 4
F
This is why I asked Shiv why he thinks this is a good idea. It seems (from other reports) that the car will run better with the compensations zero'd out, so I don't see why you couldn't/wouldn't do this on any tune but 1st of all I'd like to be sure why it's there in the 1st place as it could protect the longevity of your engine. If it is knock related, I would be looking to have a completely knock free tune before you change the PCC.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-05-2014, 08:21 AM   #56
Silver Ignition
APEXHNTR
I flashed to the 91 tune this morning and drove to work...I'll do a pull on the way home and post
#1867 of 2500
Vishnu Tuning's Tales From The Dyno: Crawford Billet Power Blocks Shiv@Openflash Engine, Exhaust, Transmission 129 11-24-2017 07:58 PM
Crawford Billet Power Blocks smbstyle Engine, Exhaust, Transmission 799 01-18-2016 05:01 PM
Crawford Billet power blocks Triumphrider Engine, Exhaust, Transmission 0 08-01-2014 01:39 AM
FS: One set of barely used Crawford Billet Power Blocks Robert@Openflash Engine, Exhaust, Bolt-Ons 1 06-07-2014 04:13 PM
**Crawford Power Block Install Special -- R/T Tuning -- Call Today** R/T Tuning Engine, Exhaust, Bolt-Ons 3 05-21-2014 11:18 AM
