Old 07-05-2014, 07:40 PM   #43
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
The highest boost pressure the factory MAP sensor is capable of reading is right around 5psi (depending on atmospheric pressure). So if you see your boost logs flatline somewhere around that, it could very well be higher.
Shiv
The Following 5 Users Say Thank You to Shiv@Openflash For This Useful Post:
DAEMANO (07-05-2014), jflogerzi (07-05-2014), raven1231 (07-06-2014), Sojhinn (07-05-2014), WRB5titch (07-05-2014)
Old 07-05-2014, 09:10 PM   #44
DAEMANO
Time Traveller
More TQ250 v. TQ300
Originally Posted by fenton View Post
Want to say a big thanks to @shiv@vishnu on another quality tune. This tune feels stronger than the last which was already great
Shiv do you know why some of us up here in Calgary(specifically with ofh) are bottoming out the AFR when on boost?
Tq250 log
http://www.datazap.me/u/fenton108/tq...&zoom=811-1056
Tq300 log
http://www.datazap.me/u/fenton108/93...zoom=3025-3131
Wow @fenton you were right when saying the TQ250 spools faster and has really closed the gap on the TQ300. I compared your first TQ250 and TQ300 runs and the logs bear out how quickly the TQ250 gets up and on boost. Tried to get the pulls as "apples to apples" as I could from your logs starting both at 2692 RPM (TQ250) and 2691 RPM (TQ300).
Data is here (fascinating):
http://datazap.me/sites/default/file...20070514_0.csv
Graph is here:
http://datazap.me/u/daemano/phantom-...4&mark=28-0-99
The Following 2 Users Say Thank You to DAEMANO For This Useful Post:
Boofneenee (07-06-2014), raven1231 (07-05-2014)
Old 07-05-2014, 10:41 PM   #45
Urmyson
Does everyone who is running this tune have the OFH?
Urmyson is offline   Reply With Quote
The Following User Says Thank You to Urmyson For This Useful Post:
Old 07-05-2014, 10:44 PM   #46
DAEMANO
Time Traveller
No. Some are on stock, modified, or aftermarket headers including but not limited to the OFH. Check out the Phantom ESC owners thread for an idea of ppls setups.
Old 07-05-2014, 10:51 PM   #47
jflogerzi
jflogerzi's Avatar
If you you are looking for a header to use with this kit, the JDL EL header is your best option. EL headers provide better top in power. UEL headers were great for NA cars as it provided better TQ in the DIP than EL. I would love to see the 1.5 dump 250 setup with a full Exhaust and no cats with a JDL EL header with E85 could produce.
Old 07-06-2014, 02:09 AM   #48
fenton
Graph is here:
Did you line then up when they both went full throttle though? Because I think the 300 did actually go wot until a little bit after.
fenton is offline   Reply With Quote
The Following User Says Thank You to fenton For This Useful Post:
DAEMANO (07-06-2014)
Old 07-06-2014, 02:29 AM   #49
DAEMANO
Time Traveller
This really is a non-scientific comparison of a section of the two logs you posted. IIRC the 300 log had several pulls in it. Which one are you referring to? I started the comparison where the engine RPM increased continuously with no dips from about 2600 RPM to beyond 6k RPM. However since they were your pulls and logs I'm sure you'll have the keenest insights.
Old 07-06-2014, 02:32 AM   #50
fenton
Ya they both had multiple. The real take away is the 250 is actually a solid performer especially when it comes to spool and bottom end.
The Following 3 Users Say Thank You to fenton For This Useful Post:
DAEMANO (07-06-2014), raven1231 (07-06-2014), WRB5titch (07-07-2014)
Old 07-08-2014, 04:34 PM   #51
Sing4LTS
Drives: 13' FR-S
Will the TQ300 every be available for purchase?
Sing4LTS is offline   Reply With Quote
Old 07-08-2014, 04:38 PM   #52
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
The tq300 is still in beta testing but it doesn't make sense for BRZ or frs in its current form. The tq 250 spools up faster and has almost identical boost levels.
Installed Mods:
Old 07-08-2014, 06:33 PM   #53
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 07-08-2014, 07:59 PM   #54
Shiv@Openflash
Drives: 2013 FRS
What testing have you done or seen to confirm this? I've seen the opposite.
Old 07-08-2014, 08:06 PM   #55
jflogerzi
jflogerzi's Avatar
I have no testing but based on dyno posted by several shops in an na application shows that EL headers like jdl and hks had better top in power. Not sure if the same logic can be applied to this scenario.
Sent from my SGH-T999 using Tapatalk
2013 Series 10 FRS #553
Old 07-08-2014, 08:19 PM   #56
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I may just be crazy, but I still want to see 2 phantom compressors hooked up in series on the car.
10 psi witin ~.5 seconds of WOT. We would have to limit boost to ~7psi for stock engine config. Have maybe 4psi over 6k, if the boost scales 1 to 1. This should keep us from needing new clutch,cooling,fuel mods. Fitment would be easy if you ran a CAI, or some slight piping work to use the stock airbox. The alt charger could just be another controller and could control the second compressor. Both could be hooked up to the same throttle switch for activation. All that would leave is the need for a dump 2.0. 1 dump pack for each compressor, or if It will fit; two 1.5's. I realize this is getting really expensive and outside the purpose for the phantom kit, but I can't help but think about the upgrade path of the ESC. I don't know if the OFT could tune for that type of setup, but think about it, double(theoretically) the boost acrost the range for an extra $1600. If you already have a 2.0dump and OFT.
ok bored rant over, commence crushing my dreams.
Phantom TQ250 Dyno FBO (Dual Battery Pack) Shiv@Openflash Forced Induction 23 04-29-2014 02:40 AM
Clutch dump at 5000 RPM? fasteddy BRZ First-Gen (2012+) — General Topics 20 08-22-2013 01:55 PM
External dump and under tray? mrk1 Forced Induction 5 07-30-2013 09:43 AM
Photo dump. CanibeatNoel FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 07-17-2013 02:47 AM
Ricepuddin Picture Dump Ricepuddin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 15 12-03-2012 12:18 AM
