#43 |
Hail Magnet
A few people have had some success applying clear bra material along the area that is contacted. This seems to prevent the rubbing that creates this condition.
#44 |
Drives: 2013 frs
Hey if my car has been rustproofed every year ..do you think I'll have this issue ?
Can't check cause the seal is glued on tight |
#45 | |
| The Following User Says Thank You to strat61caster For This Useful Post: | Young_makaveli (01-02-2015) |
#46 |
Drives: FR-S 10 Series
I bought 3M door edge strips from eBay (~$10). Use ~1 inch strips from the excess (you'll have plenty as the strips are a lot longer than the doors require) and apply it under the rubber strips on the pilars. Done.. killed two birds with one stone.
Ditto for the areas that rub the paint under the mud guards. |
#47 |
Drives: 2015 Asphalt FR-S
Granted, I've only had the car since October, but looks like mine is ok, can't even move the rubber.
#48 |
Drives: 2013 frs
I just sprayed rustproof on that area so if there is already rust it won't get worse over time
#50 |
Drives: Ultramarine toyobaru
Made this thread a while back so just to update anyone who's wondering; the part was replaced under warrenty no issue.
Also to stop it from happening again I purchased some cheap phone screen protectors, cut them the width of the door strip and slid them under the seal. Much easier to do with a screen protector then tape because its stiff plastic and you can force it into place. |
| The Following 2 Users Say Thank You to headlikeahole For This Useful Post: | Di (05-14-2015), Young_makaveli (01-04-2015) |
#51 | |
Drives: 2013 frs
#52 |
Drives: Honda Civic Type-R FK2
Thanks for the heads up! Checked mine right away and there was a tiny little bit of rust growing right there. Took it to the dealership today and will have both sides replaced under warranty. Gonna check that spot regularly from now on.
#53 |
Drives: 2013 Raven
Do you have a case number by any chance? My dealer said they won't warranty this.
#54 |
Sorry but no I don't.
They never heard of this problem before but agreed that it's not acceptable on a one year old car so they just replaced them. Any reason they don't warranty this case for you? Seems like a lot of other stateside owners got theirs replaced by warranty so you might check with them to see if they have any case number for you. Good luck! |
| The Following User Says Thank You to Mindsucker For This Useful Post: | Tcoat (04-02-2015) |
#55 |
hey you, yeah you <3
Drives: 2014 37J FR-S
Thanks, found spot to have dead moth stuck though. Cleaned. Good as almost new!
#56 |
Drives: BRZ Sportech
Mine had that exact rust spot 6 months after purchase. Now 18 months I mentionned it to my dealership at the 3rd service and they replaced this vertical metal divider on the driver's side. They said it was covered by the waranty because there was a recall on the part....?
Can't get more info. BRZ 2013 - In canada |
| Beware: Excessive rust on suspension parts | mav1178 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 11-20-2013 02:22 PM |
| Small rust spot look a like stain? | Bach415 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 23 | 04-30-2013 02:35 PM |
| BEWARE DRL TSB! | Hawaiian | Issues | Warranty | Recalls / TSB | 34 | 03-30-2013 10:21 AM |
| Rust? even with rust proofing? | Chinadian | Issues | Warranty | Recalls / TSB | 8 | 01-26-2013 05:15 PM |
