Old 06-04-2014, 03:23 PM   #43
HunterGreene
Hail Magnet
HunterGreene's Avatar
Originally Posted by tomato86 View Post
Just saw this the other day, unbelievable. Even if replaced it'll do it again.
A few people have had some success applying clear bra material along the area that is contacted. This seems to prevent the rubbing that creates this condition.
It has priests in it?
Old 01-02-2015, 03:50 AM   #44
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
Hey if my car has been rustproofed every year ..do you think I'll have this issue ?
Can't check cause the seal is glued on tight
Young_makaveli is offline   Reply With Quote
Old 01-02-2015, 04:32 AM   #45
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Yours might be fine then, mine moves around which is why the thin paint on that piece of metal is no longer there protecting it which is why people get rust, if that little trim piece isn't moving odds are the paint on that piece of metal is intact and the piece isn't rusting.
Young_makaveli (01-02-2015)
Old 01-02-2015, 05:52 AM   #46
dnieves
Drives: FR-S 10 Series
I bought 3M door edge strips from eBay (~$10). Use ~1 inch strips from the excess (you'll have plenty as the strips are a lot longer than the doors require) and apply it under the rubber strips on the pilars. Done.. killed two birds with one stone.
Ditto for the areas that rub the paint under the mud guards.
dnieves is offline   Reply With Quote
Old 01-03-2015, 07:35 PM   #47
V_86
V_86's Avatar
Drives: 2015 Asphalt FR-S
Granted, I've only had the car since October, but looks like mine is ok, can't even move the rubber.
V_86 is offline   Reply With Quote
Old 01-03-2015, 07:37 PM   #48
Young_makaveli
Drives: 2013 frs
I just sprayed rustproof on that area so if there is already rust it won't get worse over time
Old 01-03-2015, 10:21 PM   #49
BRZBlack
BRZBlack's Avatar
Drives: 2013 Subaru BRZ
Just checked mine. Nothing yet. Will keep an eye on it though. Thanks OP!
BRZBlack is offline   Reply With Quote
Old 01-04-2015, 02:33 PM   #50
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
Made this thread a while back so just to update anyone who's wondering; the part was replaced under warrenty no issue.
Also to stop it from happening again I purchased some cheap phone screen protectors, cut them the width of the door strip and slid them under the seal. Much easier to do with a screen protector then tape because its stiff plastic and you can force it into place.
headlikeahole is offline   Reply With Quote
The Following 2 Users Say Thank You to headlikeahole For This Useful Post:
Di (05-14-2015), Young_makaveli (01-04-2015)
Old 01-04-2015, 04:17 PM   #51
Young_makaveli
Drives: 2013 frs
All I did was spray some rustproofing in between the trim and the pillar, it should stop the rust from getting worst
Old 01-20-2015, 12:02 PM   #52
Mindsucker
Mindsucker's Avatar
Drives: Honda Civic Type-R FK2
Thanks for the heads up! Checked mine right away and there was a tiny little bit of rust growing right there. Took it to the dealership today and will have both sides replaced under warranty. Gonna check that spot regularly from now on.
Mindsucker is offline   Reply With Quote
Old 03-31-2015, 02:13 PM   #53
N_A
Drives: 2013 Raven
Do you have a case number by any chance? My dealer said they won't warranty this.
N_A is offline   Reply With Quote
Old 04-02-2015, 11:48 AM   #54
Mindsucker
Mindsucker's Avatar
Sorry but no I don't.
They never heard of this problem before but agreed that it's not acceptable on a one year old car so they just replaced them.
Any reason they don't warranty this case for you? Seems like a lot of other stateside owners got theirs replaced by warranty so you might check with them to see if they have any case number for you.
Good luck!
The Following User Says Thank You to Mindsucker For This Useful Post:
Tcoat (04-02-2015)
Old 04-03-2015, 12:17 PM   #55
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Thanks, found spot to have dead moth stuck though. Cleaned. Good as almost new!
Old 04-27-2015, 01:02 PM   #56
BRZJunkie
Drives: BRZ Sportech
Mine had that exact rust spot 6 months after purchase. Now 18 months I mentionned it to my dealership at the 3rd service and they replaced this vertical metal divider on the driver's side. They said it was covered by the waranty because there was a recall on the part....?
Can't get more info.
BRZ 2013 - In canada
BRZJunkie is offline   Reply With Quote
Beware: Excessive rust on suspension parts mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 11-20-2013 01:22 PM
Small rust spot look a like stain? Bach415 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 23 04-30-2013 01:35 PM
BEWARE DRL TSB! Hawaiian Issues | Warranty | Recalls / TSB 34 03-30-2013 09:21 AM
Rust? even with rust proofing? Chinadian Issues | Warranty | Recalls / TSB 8 01-26-2013 04:15 PM
