Old 05-08-2014, 10:14 PM   #43
subiestyle
subiestyle's Avatar
Drives: 2014 Monogram FR-S White MT
Originally Posted by trevorovert View Post
I've still yet to see any solid evidence indicating something broke due to driving hard in the break in period. The only real way to tell would be to drive 2 identical cars the exact same way after 1k miles, but hoon one and drive one like a grandma for the first thousand miles.
I dunno how many times I hit redline on the way back from the dealership.. it would probably make most of you cringe
Its not that it will break.
The break in is to get max power and max fuel efficiency.
subiestyle is offline   Reply With Quote
The Following 2 Users Say Thank You to subiestyle For This Useful Post:
86-tundra (05-08-2014), lazyluka (05-23-2014)
Old 05-08-2014, 10:53 PM   #44
HLS30
Drives: Heavily modded '72 240Z
Do you have actual evidence of that, or just parroting what everyone says?
Like modifying cars? Worried about voiding your warranty? Then read up on the Magnuson–Moss Warranty Act, and 42 U.S. Code § 7541!
HLS30 is offline   Reply With Quote
Old 05-08-2014, 11:25 PM   #45
Ghost 86
Drives: 2013 Whiteout FR-S
Auto x'd with the stock Bridgestones lol
Ghost 86 is offline   Reply With Quote
Old 05-08-2014, 11:52 PM   #46
subiestyle
subiestyle's Avatar
It's not rocket science or take a genius to understand metal expands to different sizes depending on heat. You want all the parts to wear down evenly and your rings to create a nice seal. Nice seals create max power and max fuel efficiency.
Until manufacturing gets to the point where they can build a metallic engine that defies this law of physics, the engineers will continue to recommend the break-in.
The Following User Says Thank You to subiestyle For This Useful Post:
AznKirby (05-23-2014)
Old 05-08-2014, 11:57 PM   #47
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
What did you do when you hit the 1000 miles mark? Gunned it then instantly decided to start modding.
Old 05-09-2014, 12:19 AM   #48
Chazbo
Drives: 2020 Blue One
I have replaced pistons in 1 cylinder engines, and the sleeve (cylinder head) that the piston sits in gets a cross hatching to rough up the surface for the new piston and rings. This is a ball hone. The rings around the piston mate with this cross hatching to create a seal in a dirt bike engine anyways. I assume the same is for car engines.
Warming up the engine is important. I sit there at least a while to hear the rpm jump, then drop back down to 600 or so. Before 1000 miles I went over the 5-6000 rpm mark several times for short intervals. I don't really drive the car to red line ever because it is just mostly acceleration in traffic. Well maybe a few times. Of course. Everyone has their own choice to make regarding break in, but I have driven the car hard before 1000 miles.
It's a car. Drive it. It is not an investment.
Chazbo is offline   Reply With Quote
Old 05-09-2014, 02:17 AM   #49
HLS30
Correct, which is why letting engines warm up a bit before flooring it is important in general (not from a wear point, but you get extra blow-by past the rings and gaskets before it's warmed up). That has nothing to do with engine break-in though.
Old 05-09-2014, 07:45 AM   #50
innerthought
Drives: 2004 Toyota Corolla S
seems like most people forget that the break in period isn't just for the engine either. From the factory they put enough pressure behind the O-rings to seat them against the engine wall when they test it. However, you are also breaking in your gearbox, exhaust, the differential, and pretty much any other moving part. Do what you want it's your car, but I'll be happy to wait to smack it at 1000 miles after an oil change and visual inspection of components.
innerthought is offline   Reply With Quote
Old 05-09-2014, 09:02 AM   #51
Chimera
Drives: FRS
Got more gas
The Following User Says Thank You to Chimera For This Useful Post:
Barbarian (05-23-2014)
Old 05-09-2014, 09:03 AM   #52
Ingen
Drives: Ultramarine FR-S 6MT
Floored it
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 05-09-2014, 10:06 AM   #53
xmadror
Drives: BRZ Sport Tech 13
Originally Posted by extrashaky View Post
What's more important than limiting your revs is the break-in suggestion that you vary the load on the engine and avoid using cruise control. Driving along using the cruise control breaks the engine in at a single load and will cause the rings to seat for that load only. You want the cylinder to initially wear in a tapered shape so that the rings seat properly all the way through the stroke, but using cruise extensively during break in tends to create more wear at the top and bottom and less at the middle, so that the rings never really seat quite right throughout the stroke.
This is what I was told to say back when I was a salesman in a Mazda dealer. And while I made sure to stay at high rev for very small amount of time I didn't hesitate to take it near/to the rev limiter from the 1st day.
xmadror is offline   Reply With Quote
The Following User Says Thank You to xmadror For This Useful Post:
Karigan (05-09-2014)
Old 05-09-2014, 02:26 PM   #54
Grassroots_BRZ
Drives: Pearl White BRZ
Took it to the track.
Grassroots_BRZ is offline   Reply With Quote
Old 05-22-2014, 09:38 PM   #55
CO777DAL
CO777DAL's Avatar
Drives: 2014 Ultramarine Monogram FRS
Hit 1000 miles only after 20 days. Ouch. 95% was heavy city street driving. I almost never get to go on the freeway to see how fast the car can really go. Closest thing I get to drive on is Skillman St where I can go 70. Speed limit is 45 but mos everyone is doing between 60 to 70. Going to be a lot of wear on the vehicle. I was leaving Albertsons when it changed to 1000. Stop and grabbed a photo.
CO777DAL is offline   Reply With Quote
Old 05-22-2014, 10:07 PM   #56
torqdork
torqdork's Avatar
Drives: RV-7
Added TRD CAI, Perrin catback, RE-11A's, changed oil and filter, then this:
torqdork is offline   Reply With Quote
Just hit 1000 Miles vinh359 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 02-16-2014 06:48 PM
Almost at 1000 miles. Oil change when? TheGuyWithTheFireStorm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 08-08-2013 01:31 PM
FS in IL - OEM tires only 1000 miles Captain Insano Wheels and Tires 9 07-21-2013 07:39 PM
1000+ miles jarviz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 31 02-02-2013 01:23 AM
1000 miles jarviz Scion FR-S / Toyota 86 GT86 General Forum 8 06-29-2012 03:42 PM
