Old 05-14-2014, 10:37 PM   #43
mike the snake
What are "crushed ice" connecting rods?
Old 05-14-2014, 10:42 PM   #44
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
The stroker kit takes you from 2.0 - to 2.1 ..... a capacity gain of 100cc? Probably easier to just go another 2psi of boost lol
Toyota 86 test driver
Tradewind is offline   Reply With Quote
Old 05-14-2014, 10:49 PM   #45
kelee
Drives: RX350
Why was the smaller M8 con rod bolt used? subaru beefed it up to M9.5 intentionally to handle the pressure at 7000 rpm speeds.
at least that's what the FA20 D4S development paper in the injection thread sticky says.
kelee is offline   Reply With Quote
Old 05-14-2014, 11:29 PM   #46
xwd
Poor translation of cracked rod caps?
I guess the more interesting thing to me is the cams, not so sure about a longer stroke to get .1L of displacement.
Old 05-14-2014, 11:48 PM   #47
JerryMichaels7
Drives: Whiteout FRS
were are people getting 2.2 max and that is rounding up I guess? Because every calculator I use says 90mm stroke 90 mm bore = 2.27 liters so almost 2.3
life's greatest stories usually start with the words, "fuck it!".
JerryMichaels7 is offline   Reply With Quote
Old 05-15-2014, 04:17 AM   #48
kelee
Drives: RX350
because it's 86x90
Old 05-15-2014, 08:19 AM   #49
JerryMichaels7
someone mentioned in another thread with the same kit at 90x90 it was still barely 2.2, I know that stock its 86x86
Old 05-15-2014, 12:55 PM   #50
xwd
There was some conjecture a long time ago they were working on a 2.2L stroker kit. Well as you can see, it's a 2.1L stroker kit. Now if someone wanted to pair their parts with some custom pistons using a larger bore, then you would see >2.1L. 90mm is a lot to overbore in this engine, I don't think it would really work well especially with a 90mm stroke.
Old 05-15-2014, 01:37 PM   #51
Evasive Motorsports
Evasive Motorsports's Avatar
Drives: 2012 FR-S and BR-Z
Send a message via AIM to Evasive Motorsports
Should be cracking not crushed ice. Poor translation from HKS haha.
Evasive Motorsports is offline   Reply With Quote
Old 05-15-2014, 02:03 PM   #52
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I was reading an article the other day about an FA20 tear down, they seemed to notice it's a pretty tight fit for those stock cams, so fitting any kind of significantly larger lobed cams would probably run into interference issues.
http://www.revvolution.com/blog/2014...amp-amp-4u-gse
Now to get a lil' more off topic...this badass RC car will definitely tickle the pickle.
http://www.carthrottle.com/record-br...r-porsche-911/
Old 06-06-2014, 09:07 PM   #53
Evasive Motorsports
6/6/14 UPDATE
Finally got the motor and size to the piston bore. Measured the rings gaps and time to start assemble the motor with the new HKS billet crankshaft.
Old 06-06-2014, 09:34 PM   #54
D K
Stig's dark passenger
Question
This is abviously an FB25 crank. Has HKS done any additional prep to the crank? Shot Peening, nitride, cryo?
D
D K is offline   Reply With Quote
Old 06-15-2014, 03:02 AM   #55
Staf00
Drives: SWP DZE
Any updates?
Staf00 is offline   Reply With Quote
Old 06-15-2014, 03:51 AM   #56
Evasive Motorsports
Originally Posted by Staf00 View Post
Any updates?
Two more weeks till Pikes Peak, we have just finished the shims for the cams. HKS 2.1L stroker with cams and Ferrea valvetrain for the Evasive Pikes Peak FRS. We need all the torque we can get for the climb!
HKS New Stroker Kit and Evasive Motorsports Engine Build 2014 UPDATE 9/9/14 Evasive Motorsports Engine, Exhaust, Transmission 113 06-04-2015 12:02 PM
HKS New Stroker Kit and Evasive Motorsports Engine Build 2014 UPDATE 9/9/14 Evasive Motorsports FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 41 09-15-2014 03:52 PM
EVASIVE MOTORSPORTS UPDATE BUILD FOR PIKES PEAK Evasive Motorsports FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 04-28-2014 05:10 PM
Evasive Motorsports Scion FR-S Build Begins Evasive Motorsports FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 95 02-19-2013 03:56 PM
***EVASIVE MOTORSPORTS SEMA BUILD*** Evasive Motorsports FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 25 09-09-2012 08:27 AM
