Old 05-07-2014, 09:38 AM   #43
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Originally Posted by AVodka14 View Post
I already looked at it, 'genius'. They're weak. End of story.
Your acting like an idiot. This holds especially true when you stated "only gays buy the ESC" if your such a macho tough guy why did you buy a car with a tiny 2 liter engine?
This type of electric power energy is still in development but used successfully in many of todays applications. I am pretty sure the maclaren p1 uses some type and we have really fast electric cars like the Tesla.
I dont own an ESC but am appreciative of the technology and its growth. So how about you keep your childish comments to yourself and stick with being constructive.
To the OP, have you or the dealer simply tried to uninstall the Esc and put it back to stock. Wiring is fussy and any shorts will cause a car not to work. I feel like you would have heard something explode or pop had it been an engine problem.
Good luck.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline
Old 05-07-2014, 10:26 AM   #44
steve99
Originally Posted by jpit View Post
Was driving into town today and the BRZ just died. Tried to restart it several times but it after a second it would just shut off but didn't throw a code. Besides this problem it was towed to the dealer with the electric supercharger still attached among other modifications - should prove interesting.
I think you would have to be realistic re warantee.
"It just died, no codes" does not sound mechanical, actually sounds more electrical/electronics/ecu issue.
If you have electric supercharger you have modified wiring, non-standard batteries, a high power electric motor and associated high current switchgear all of these quite capable of inducing surges/spikes into other components in your car's electrical system, even if none of this additional non-standard components have failed , shorted out ect.
Your chances of having anything electrical , electronic or ecu related covered under warantee would be almost nill even if they don't find the changed ECU mapping.
Your chances of any motor gearbox drive train warantee would also be limited as you have theoretically added horsepower/torque over standard.
I would imagine they would be able to charge for additional time to remove or work around your mods or possibly refuse to work on the car until the mods were removed if they believe the mods are causing or have caused the issue.
Should be very interesting.best of luck. Might be worth turning up with a case of beer
steve99 is offline
Old 05-07-2014, 10:51 AM   #45
raven1231
What's "weak" is your car without one!
raven1231 is offline
Old 05-07-2014, 11:08 AM   #46
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
*Ignoring the obviously idiotic and prejudicial remarks*
Jpit... Can you run down your mods again? I know you have the ESC, trunk mounted battery, borla header, ecutek tune, and an after market exhaust?
Couple things have you tried placing a battery at the stock location, and just trying to start the car? That way we can rule out the trunk mounted battery. Also you said you think its the alternator, was the system recharging fine before the issue?
Installed Mods:
Sojhinn is offline
Old 05-07-2014, 12:15 PM   #47
jpit
Drives: Subaru BRZ
You have all the mods right except no after market exhaust. I doubt it is the alternator because the battery should have taken over most of the car's functions for awhile if the alternator died. When it died the battery seemed to have a full charge. Because no codes were thrown I believe the problem is electrical in nature. If the dealer can't find the problem (I'll give them a couple of hours) I will tow it to my house and work on it myself.
I may install an earlier Ecutek ROM to check to see if it is the ECU causing the problem.
jpit is offline
Old 05-07-2014, 12:45 PM   #48
Sojhinn
Sojhinn's Avatar
Just trying to picture it, and weed out issues can you describe what happened?
Installed Mods:
Sojhinn is offline
Old 05-07-2014, 01:01 PM   #49
steve99
Does anything electrical work ?
Dash indications ?
Is OBD port responsive ?
Not trying to be a smart but have you checked all the fuses including high capacity ones in engine bay.
steve99 is offline
Old 05-07-2014, 01:22 PM   #50
jpit
Drives: Subaru BRZ
Sojhinn,
Was just driving down the highway and went to accelerate but there was no response and the car just died. Try several times to start it and it catches for a split second and then just dies. Doesn't seem like fuel starvation. Haven't had a chance to check the fuses yet but it will be the first thing I do when I get it back.
jpit is offline
Old 05-07-2014, 01:24 PM   #51
s2d4
s2d4's Avatar
Bad battery connection?
I've had this before, similar behaviour.
s2d4 is offline
Old 05-07-2014, 01:31 PM   #52
shif7i7down
Erected Member
Drives: frs
After reading all the comments, my only wish is that technology would have advanced far enough to the point were we could give e-slaps. I would definitely back hand e-slap some of the idiots posting in this thread
shif7i7down is offline
Old 05-07-2014, 01:36 PM   #53
Sojhinn
Sojhinn's Avatar
Yeah sounds like it to me, but the alternator should of kept it running. Maybe your ground wire is bad?
Installed Mods:
Sojhinn is offline
Old 05-07-2014, 01:41 PM   #54
s2d4
s2d4's Avatar
Not if the connection is loose/bad enough to have ignition on but not able to start due to not being able to pull enough current.
If you take one of the connectors off while the car is running, the car will stop.
s2d4 is offline
Old 05-07-2014, 01:48 PM   #55
jpit
Drives: Subaru BRZ
Actually, the first item I check was the positive and negative connections to the alternator.
Both seemed fine.
jpit is offline
Old 05-07-2014, 02:35 PM   #56
tinma
Drives: '13 BRZ
all I read in this thread in Electric Supercharger... So I will just leave this here
[ame="http://www.youtube.com/watch?v=cbGWgvJN1_8"]Electric SuperChargers Mythbusted - YouTube[/ame]
Going to start my build today! (basically going to copy this video from this point)
[ame="http://www.youtube.com/watch?v=cbGWgvJN1_8&feature=player_detailpage#t=50 7"]Electric SuperChargers Mythbusted - YouTube[/ame]
tinma is offline
First problem with the STX Brz Simmons Tracking / Autocross / HPDE / Drifting 94 06-23-2014 12:05 AM
Problem with car Atticus808 Other Vehicles & General Automotive Discussions 1 02-19-2014 11:14 PM
A bit of a problem Gost Other Vehicles & General Automotive Discussions 13 02-12-2013 07:07 PM
ABS Problem chrislee2423 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 07-09-2012 04:06 PM
anyone with this problem? debs0712 Scion FR-S / Toyota 86 GT86 General Forum 2 06-30-2012 10:17 AM
