#43 | |
The diffuser was specifically mounted so that the front clips would fail, and ONLY the bumper would be lost if something like the incident in the video happened. I love seeing fireballs coming out of the tailpipe on that S2k... it's running a Vortech 1200 at 5.5 psi. |
#44 |
Off Topic
Is that your S2K?
I love that they planned for this contingency. That's the kind of thing I do at work, and it makes me warm and fuzzy to see it in the civilian world as well. |
#45 | |
Built-in failure points are good. We try to do it whenever it's feasible, particularly with splitters. I try to avoid diffusers altogether, unless we have no other option. |
#46 |
Off Topic
Would they not help keep the rear of the car planted on the track though? Is there a benefit to a diffuser vs. a bigass wing?
#47 |
#48 |
Off Topic
Now just for fun, what about canards vs. a front splitter? Canards are much less likely to be damaged, but I don't think they'd be as effective.
#49 |
Driveway labs.
Drives: '13 BRZ Limited, 6sp, SWP
Hate to jump on here so late, and I'm not trying to promote my diffuser. I only found the thread by mistake trying to search for a different thread.
My type 1 diffuser has 5-6 inches of ground clearance on my car (stock size wheels, h&r super sport springs). The type 2 has about 2-3 more inches of ground clearance. The leading edge is mounted to the frame and is designed as a failure point in case of an off. Also, I build mine from aluminum, not cf. Aluminum can be bent and repaired easily. All the strakes come off with a drill and can be replaced easily. I've personally tore mine off on a deer carcass that was hiding mid apex on the way to work; it broke the mounting tabs and popped the diffuser off the car with zero damage to my bumper cover. But on the same token, I can do pull-ups on the diffuser with the car on a lift. I have tons of track and street cars that have given great feedback as to the added stability, and reduced drag (improved highway mpg).
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list) -'13 Town and Country Limited (Mods: too many kids) |
| The Following User Says Thank You to Wonderbar For This Useful Post: | glamcem (04-14-2014) |
#50 |
Off Topic
Have you noticed if the type 2 is more or less effective than the type 1? I'm interested in the benefits you mentioned, but don't want the huge square diffuser racecar look.
| The Following User Says Thank You to gramicci101 For This Useful Post: | kavanagh (04-14-2014) |
#51 |
Drives: Subaru
#52 | |
Off Topic
I'm not trying to accomplish anything with aero on my car, I'm just interested in how it all works. Thanks for answering. |
#53 |
Thanks
How would OEM vs a bolt on GT type wing compare? Would have either without a front splitter adversely effect the car if the rest of the aero was stock?
#54 | |
Drives: Subaru
Canards can create a little downforce and can be used to adjust aero balance. They are/should be used more to direct airflow to other parts to create more downforce. Also good at decreasing front wheel well pressure decreasing lift there. |
| The Following User Says Thank You to plucas For This Useful Post: | gramicci101 (04-13-2014) |
#55 | |
Driveway labs.
| The Following User Says Thank You to Wonderbar For This Useful Post: | gramicci101 (04-13-2014) |
#56 | |
Off Topic
Also, interestingly, the GT300 BRZ doesn't seem to use them, from a brief image search. And my ipad doesn't seem to realize that brief is actually a word and I didn't really mean to say grief. Dammit. |
| New TRD Aero Parts & Others | zephyr69 | Cosmetic Modification (Interior/Exterior/Lighting) | 44 | 10-06-2013 11:20 PM |
| Aero Parts Availibility? | maj75 | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 12-06-2012 11:48 AM |
| How do you buy aero kit / TRD parts? | scwewywabbit | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 03-17-2012 11:45 PM |
