Old 02-20-2017, 08:59 AM   #43
15limited
15limited's Avatar
Resurrection 👻👻👻 has anyone ran into problems with an install or long term use, any confirmation on ride height that may or may not require subframe notching with stock axles?
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 02-20-2017, 09:45 AM   #44
Zer0
Drives: 2015 frs
I didn't drive mine much after the install. I pulled the engine and transmission at 2700 miles and sold them. I don't see any wear on the axles or subframe I'm on stock axles.
Zer0 is offline   Reply With Quote
Old 02-20-2017, 09:54 AM   #45
15limited
15limited's Avatar
Ls swap? Or no swap yet?
Old 02-20-2017, 09:57 AM   #46
Zer0
Drives: 2015 frs
LS swap acquiring parts should be done at the beginning of next year.
Old 02-21-2017, 01:02 AM   #47
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
Had mine in for 12+ months now, no issues at all.
Don't even notice the sound really.., kinda is drowned out by the exhaust.
car is sitting pretty low,
Dates love it when i pick them up hey!
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
Old 02-21-2017, 05:05 AM   #48
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Hey Fudds,
What is that thingy?
Old 02-21-2017, 05:38 PM   #49
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
Hey Fudds,
I think it's this thingy
Holds my bumper up, and didn't cost me $350!
$15, couple of nutserts, stainless bolts and bam! I can now join the rest of the hardparker car racers kids with their quick releases!
The Following 2 Users Say Thank You to fuddbutter For This Useful Post:
Captain Snooze (02-21-2017), Tristor (02-24-2018)
Old 02-21-2017, 06:22 PM   #50
DAEMANO
Time Traveller
Originally Posted by Bodalenko View Post
So just for my own info, how extreme does the lowering have to be to require this treatment?
I was under the impression, hopefully not wrong impression, that anything up to 50mm (2") was fine with the axles and tail/drive shaft of these cars.
I'm lowering my 86 25mm on coil-overs and if this is best practise or even advisable, when lowering a pissy 1", forget it!!!
Also;
Forgive me if this is a stupid question but how does this affect the front end of the car, specifically the the rake, braking, anti dive, geometry, weight balance, etc?
Isn't there going to be nose up effect, even minor, when this is done to the rear and not the front?
Is the difference so minimal it has no effect? Doesn't every action have an equal and opposite reaction?
Again apologies if this has been mentioned or explained and I've missed it.
Am putting down ~230 WHP @ 7200 RPM and ~210 ft/bs TQ at ~3000 RPM
... lowered -1.8" rear
... snapped first axle at outer CV (driver's side) 20K mi
... raised rear to -1.6"
... snapped second axle at inner CV (also driver's side) 1 year later and also toasted my ring & pinion at the same time ($1400 fix btw). 33k mi
... raised rear to -1.25"
lets' see where this goes.
Lowering too much matters. If axle goes again, will get PBM diff kit.
The Following 3 Users Say Thank You to DAEMANO For This Useful Post:
J95 (02-19-2024), JoeBro (03-09-2019), smg1138 (06-19-2017)
Old 02-21-2017, 10:45 PM   #51
15limited
15limited's Avatar
Supercharged? I've been running ~1.7" lowered in the rear for maybe 20k miles NA with no problems so far, mix between hwy and spirited driving, no real track days
Edit: ohhhh phantom charger. I was wondering how you had so much torque without more HP. 👍
The Following User Says Thank You to 15limited For This Useful Post:
DAEMANO (02-22-2017)
Old 02-19-2024, 02:12 PM   #52
J95
J95's Avatar
Hi, I got the risers from PSM
https://store.partsshopmax.com/shop/...s/ZNC6SDR.html
Im debating between installing them myself or taking it to a professional, would you be able to estimate how long does it take to mount the risers? including taking the diff out
and most important, did you need to notch the subframe, and how much drop you have? I will be lowering ~1.4 inch with KW v3, really hope theres no need to notch
J95 is offline   Reply With Quote
Old 02-19-2024, 04:40 PM   #53
Falkon240
Falkon240's Avatar
Drives: 2013 FRS
I had a local shop do PBM diff bushings. I had the subframe notched and installed whiteline subframe bushings instead of to solid subframe risers to reduce NVH.
IG
2013 Scion FR-S
2022 Chevrolet Colorado ZR2 Bison
1998 Nissan 240SX KA24DET
Falkon240 is offline   Reply With Quote
The Following User Says Thank You to Falkon240 For This Useful Post:
J95 (09-03-2024)
Old 02-20-2024, 12:05 PM   #54
terboboost
terboboost's Avatar
Drives: 2013 BRZ HKS Turbo
The install isn't too bad, but you probably need a press or air hammer to get the old bushings out of the diff. I did end up needing to notch the subframe. Not sure how much of a drop I have, but my rear 235/40/17 tires are just about even with the fender. The axles also were rubbing on the upper control arm, which I let self clearance I attached a pic of my subframe trim.
I don't recall exactly how long it took, but I'd say probably 6 hours from tires up to tires down. Here is a reel I put together of the install:
https://www.instagram.com/reel/Cn0Yx...NlZDc0MzIxNw==
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
terboboost is offline   Reply With Quote
Parts Shop MAX USA prototyping philstar Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 03-04-2014 01:14 PM
Need a Shop for Aftermarket Parts Installation in Portland - Suggestions? Ammunition Northwest 11 12-23-2013 03:19 AM
RallySportDirect 2011 STi Shop Car for Sale. Over 50K in Parts, under 3500 Miles! RallySport Direct Cars for Sale/Trade 14 06-21-2013 12:52 PM
Installing TRD Parts / Locating a good shop Re~Mix Engine, Exhaust, Transmission 9 06-12-2012 01:05 PM
