Old 02-26-2014, 09:54 AM   #43
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by spdbydesignchris View Post
Are you using the rear o2 sensor ground to connect? or connecting to a chassis ground location?
Where are you wiring the 12V + switched?
I'm so sorry I did not see this before....
Connecting to chassis ground, and the in car fuse box has an open slot that I used with an add-a-fuse for 12V
Originally Posted by xjohnx View Post
Would like to know this too. Also, are you disconnecting the OEM rear O2 sensor harness completely and splicing in to the blue wire on that harness? Or leaving the harness connected to the o2 sensor and splicing into the blue wire?
Rear O2 sensor stays connected, the only thing cut is the blue cable.
After seeing the AEM Uego wideband, you would be simply running the 0-5V output wire from the gauge, inside the car, to the blue wire on the rear o2 sensor.
I'm using the passenger ECU wiring harness loom grommet, making a small slit with a razor and sliding the AEM harness through. (As well as the 0-5V output wire, which will need to go into the engine bay.)
I used the passenger ECU harness too.
Old 02-26-2014, 10:00 AM   #44
spdbydesignchris
spdbydesignchris's Avatar
Drives: 2013 BRZ Premium
Connecting to chassis ground, and the in car fuse box has an open slot that I used with an add-a-fuse for 12V.
Can be purchased at NAPA
http://www.napaonline.com/Catalog/Ca...226_0361086491
Can you take a picture of the slot you used and post up?
Thanks!
spdbydesignchris is offline   Reply With Quote
Old 02-26-2014, 10:02 AM   #45
spdbydesignchris
I want to reference this thread for our FT86 Turbo Kit thread, as there will be several DIY'ers, and I'd like to clearly lay out the install path.
Old 02-26-2014, 10:06 AM   #46
xjohnx
Grip>Slip
xjohnx's Avatar
Amazon.com: Bussmann BP/HHH ATM Add-A-Fuse: Automotive
Thanks!
You might want to get a low profile version instead, like either of these two:
[ame="http://www.amazon.com/Shipping-Holder-Circuit-Profile-Automotive/dp/B00EO5P2B4/ref=pd_sbs_auto_9?ie=UTF8&refRID=192VTBXPCTZEJQF7P CVP"]FAST Shipping! Mini Blade Fuse Tap Holder Add A Circuit Line Mini Low Profile ATM + 5A 7.5A 10A 15A, Car Add a Fuse Automotive Car: Amazon.com: Industrial & Scientific[/ame]
[ame="http://www.amazon.com/Littelfuse-FHA200BP-ATO-Add-A-Circuit-Kit/dp/B0002BGELQ/ref=sr_1_1?s=automotive&ie=UTF8&qid=1393427024&sr= 1-1&keywords=add-a-fuse+micro"]Amazon.com: Littelfuse FHA200BP ATO Add-A-Circuit Kit: Automotive[/ame]
Old 02-26-2014, 10:07 AM   #47
xjohnx
Grip>Slip
xjohnx's Avatar
Rear O2 sensor stays connected, the only thing spliced is the blue cable.
Thanks!
Old 02-26-2014, 11:11 AM   #48
Sportsguy83
Drives: Limited BRZ
Thanks!
Our cars use the low profile mini fuse.
Need this type of add a fuse: http://www.ebay.com/itm/Mini-Low-Pro...item23315fcc74
See pic below. The slot BETWEEN 10A DRL AND 10A TAIL is available and its ignition 12V.
Old 02-26-2014, 11:47 AM   #49
spdbydesignchris
Thanks! Now time to make an auto store parts run
Old 02-26-2014, 11:51 AM   #50
spdbydesignchris
Thanks, yes, found them at the local NAPA.
Old 02-26-2014, 02:19 PM   #51
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Just trying to confirm and a bit confused. Here you say splice, typically splicing implies that you would keep the wire intact, and simply add the new wire to the same unbroken circuit.
But early on in this post
Yes sir. I cut the O2 cable thus leaving the OEM harness intact.
You said you cut the blue wire and connected the new (white) wire. This sounds like you broke the circuit and left it open on the sensor side.
Can we agree that all we are actually doing is splicing into the blue o2 sensor wire with the wideband (white wire for AEM) output, and not cutting the wire in half?
Also, if thats the case, why go into the engine bay when you can simply do that at the ecu in the harness plug?
Thanks!
gdrider77 is offline   Reply With Quote
Old 02-26-2014, 02:24 PM   #52
Sportsguy83
Drives: Limited BRZ
Thanks!
I'm really sorry for the confusion... I cut the cable in two leaving the circuit in the sensor open. I onestly don't know if splicing would work, but my guess is that you don't want the Rear O2 signal interfering with the Wideband signal.
You can do it at the ECU connector also, I just didn't want to cut the OEM harness.
Old 02-26-2014, 05:43 PM   #53
spdbydesignchris
Install is done, now I'm just waiting on the ATI vPod to arrive on Friday and I'll post up the completed pics.
Appreciate the advice provided
Old 02-27-2014, 04:40 PM   #54
gdrider77
gdrider77's Avatar
For those that have done this mod, can you tell me, will you get a check engine light and misc codes thrown initially? Thinking this is normal until i have the new tune with the updates to take this into account?
I have done the wiring, but wont have the new tune until i get the car to my tuner this weekend. Cant imagine there is any harm with the CEL, but wanted to confirm.
Old 02-27-2014, 05:06 PM   #55
jamesm
Yes you will definitely get codes if you haven't updated the tune.
Old 02-27-2014, 05:09 PM   #56
spdbydesignchris
So far I have had to turn off P0138, PO13A and P013E.
I'll update if anymore pop up.
BRZ Front and Rear LED Turn Signal Bulbs convoy Cosmetic Modification (Interior/Exterior/Lighting) 23 11-25-2013 07:51 AM
Aftermarket Rear Diffuser Realm Cosmetic Modification (Interior/Exterior/Lighting) 8 05-08-2013 11:23 PM
FS: BNIB Concept Three LED Amber/White signal bulbs Front and Rear with Relay xxscaxx Exterior Parts (Aero, Lighting, Etc.) 10 03-27-2013 10:17 AM
DIY: front and rear LED turn signal bulbs jjdrivesajazz DIY (Do-It-Yourself) Guides 6 10-15-2012 09:53 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 12:42 PM
