Old 03-13-2014, 07:07 PM   #43
1Cor10:23
1Cor10:23's Avatar
Originally Posted by trevorovert View Post
@BaeK @JB86'd @Target70 @whiskerbox
solution found... easy, 5 minute fix. will post later tonight.
Must be such a weight off your chest - congrats man!
Old 03-13-2014, 07:59 PM   #44
JB86'd
JB86'd's Avatar
Drives: JAWS
Wuttttttt!!!!! You're the man.
Old 03-13-2014, 08:08 PM   #45
MmmHamSandwich
You know you want it.
MmmHamSandwich's Avatar
Drives: '13 FR-S
Sounds very similar to the issue my 07 Si had. The CMC was the culprit in that case.
Ours wouldn't happen to be made by Aisin would it?
The Following User _________ Stay_Puft(09-13-2014)
Says Thank You to
MmmHamSandwich For
This Useful Post:
MmmHamSandwich is offline   Reply With Quote
Old 03-13-2014, 08:55 PM   #46
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
Okay, so here's the fix.
This bolt here, with the red circle around it, is too tight. It may be hard to locate at first. Look for the rod that you adjusted that goes into the master clutch cylinder. Follow that back until you find the large rod that goes perpendicular to it, going all the way to the clutch pedal. The assembly to hold the actuator in, that bolt there is too tight. Factory spec is 13ft lbs but it should be more around 8 ft lbs. I bought a nylon washer from lowes, not sure if it helps much. This will remove the popping noise. I can still hear some kind of noise, but it is much more subtle and not as loud as the obnoxious pop.
The key is to not over tighten that bolt. Loosen it up a bit, and do a guess and check. Play and see if that causes it to pop. I think the nylon washer allowed me to make it a little tighter while still preventing the noise from happening.
If it is real loose, then the assembly will move around a bit. You want it right where it doesn't move around barely, and it doesn't make the noise
86-tundra is offline   Reply With Quote
Old 03-13-2014, 08:56 PM   #47
z3ro
i watched your video and it annoyed me. i can't imagine dealing with that every day
z3ro is offline   Reply With Quote
Old 03-13-2014, 09:16 PM   #48
86-tundra
Troll Hunter
86-tundra's Avatar
it was very irritating. I would just turn up music loud. But when I was taking a coworker to lunch or something, and it was dead quite.. I was like... man, my new car, and it makes this awful noise..
Old 03-13-2014, 09:17 PM   #49
86-tundra
Troll Hunter
86-tundra's Avatar
I'm not entirely sure. It turned out to be the clutch assembly itself instead of the actual cylinder.
Old 03-13-2014, 09:18 PM   #50
z3ro
how to solve your problem: donkey punch coworker till he/she passes out
Old 03-13-2014, 10:00 PM   #51
JB86'd
JB86'd's Avatar
Drives: JAWS
@trevorovert can't wait to get home and try this. I'll report back tomorrow night if it works for me. Thanks a lot man!
Old 03-13-2014, 10:55 PM   #52
BaeK
BaeK's Avatar
Drives: 2013 Whiteout FRS
Same here!! I will try this tomorrow night when I put my retrofitted headlights on my car. Two birds one stone I hope!
Thanks for your hard work @trevorovert !
BaeK is offline   Reply With Quote
Old 03-13-2014, 11:14 PM   #53
86-tundra
Troll Hunter
86-tundra's Avatar
Yeah no problem guys. You should definitely tinker with it a bit, because you may get slightly different results, but that bolt is 100% the source of the noise.
Old 03-14-2014, 10:12 AM   #54
86-tundra
Troll Hunter
86-tundra's Avatar
Drove it to work today and didn't hear a single pop. I turned the car off and played with it a bit and could only hear minor noises now. I may loosen it a tad more. not concerned with it coming out at all, it still feels very sturdy even with much less torque on the bolt
I imagine you could probably remove the bolt completely, if you wanted.. not sure if it would put any more stress on anything else
Old 03-14-2014, 10:28 AM   #55
BaeK
BaeK's Avatar
Quick question @trevorovert :
Do I have to remove the cotter pin before loosening the bolt you mentioned above? Or can I go straight to the bolt and loosen it without doing anything prior to that?
Thanks.
Old 03-14-2014, 10:40 AM   #56
86-tundra
Troll Hunter
86-tundra's Avatar
Thanks.
just go straight for the bolt and loosen it
Clutch pedal springy sound pdreams Issues | Warranty | Recalls / TSB 16 06-01-2015 02:33 PM
Clutch Pedal Adjustment? EAGLE5 Northern California 41 05-20-2015 01:10 AM
Clutch Pedal Noise Help!! ZackZ Scion FR-S / Toyota 86 GT86 General Forum 6 09-06-2013 05:35 PM
BRZ gas pedal popping/squeaking noise chenshuo Issues | Warranty | Recalls / TSB 8 05-10-2013 09:52 AM
Popping/Clicking Dead Pedal BRaZinDave BRZ First-Gen (2012+) — General Topics 6 12-08-2012 04:14 AM
