#43 | |
#44 |
My gtx2867r does not stop making power (or full boost) until redline. It's all in the cams and boost control, for which I use a simple hallman mbc.
| The Following User Says Thank You to jamesm For This Useful Post: | Sportsguy83 (02-06-2014) |
#45 |
Drives: 2014 Monogram FR-S
Sorry to dig up this old post but... @diss7, you mentioned having previous experience with the GT2876R or GT25/40R and how it wasn't a great choice on your ae86.
Would that be an equally poor choice on the FA20? I ask because I happen to have an unused GT25/40R .86ar sitting in my garage which makes the $950 savings a pretty enticing notion so long as it's not god awful. Thoughts? |
#46 |
Drives: AE86, 2x GT86, TE27
If you've already got it, then try it.
#47 | |
Drives: 86
EFR 7163
my target is 330whp (dynodynamics) on stock FA20 12.5 CR |
#48 | |
Drives: S1000RR
unfortunately, we have no idea on how the EFR turbo will perform against the GT turbos. That might be something we test out in the future. |
#49 |
Junior
Drives: a car
| The Following User Says Thank You to cdrazic93 For This Useful Post: | Mrc@ptuning (10-13-2014) |
#50 | |
Drives: S1000RR
A true test would be to have the same turbo system setup, ie. IC piping, intercooler, downpipe, WG, Exhaust, etc, with only the turbocharger being different. On top of that having the same tuner, atmospheric conditions and dyno to perform the comparison. That would be quite a bit of work
#51 |
Drives: 86
Thanks PTuning
It seems EFR 7163 with single scroll setup for under 10psi is a good choice |
#52 |
Drives: Scion FRS Argento Manual
Taking it to drift
If the purpose of my car was to go to the track twice a month will a smaller turbo do me justice or is getting a bigger 3071R be better on the engine?
#53 | |
Drives: S1000RR
That depends on what kind of power levels you're looking to run which also depends on the type of fuel you have access to. We'll be releasing our version 2 of our turbo system shortly with options to run the GTX2867 up to GTX3076R. |
| The Following User Says Thank You to Mrc@ptuning For This Useful Post: | Andre Suwuh (07-27-2016) |
#54 |
Well ill have access to 93 pump gas and a occasionally e85 For drifting on a stock motor plus uel headers and an oft stage 2 tune. I enter corners going in at 50-60 and rev from about 4.5k to 6k.
#55 | |
Drives: S1000RR
What is your power goals. 300whp? more? You'll probably have to switch to ecutek for the tuning in order to be able to run flex fuel (e85). At this point you're probably leaning towards a GTX2867R. |
| Which turbine size for gtx3071r? | diss7 | Forced Induction | 67 | 02-02-2014 09:19 PM |
| EFR6258 vs GTx2863R | diss7 | Forced Induction | 25 | 12-01-2013 11:15 PM |
| Garrett GTX2863R turbo, TiAL v-band wastegate | Turbowned | Engine, Exhaust, Bolt-Ons | 10 | 11-27-2013 03:07 PM |
