Old 02-06-2014, 01:55 AM   #43
jamesm
Originally Posted by diss7 View Post
I just can't see how a gtx3076 is feeling just the same as a gtx2863/7r
The 76r graphs I've seen don't hit peak torque until 5500rpm or later. The 67r is closer to 4000rpm
That's basing my understanding that the point where a turbo has reach max psi (in other words, fully spooled" is where max torque is. Or at least where it stops significantly ramping up.
Happy to be proven wrong.
But at this point I can't swallow that stepping up to a 3076r from a 2867r is "not all that different"
Just take a ride in one. I wouldn't have believed it either.
Old 02-06-2014, 01:59 AM   #44
jamesm
My gtx2867r does not stop making power (or full boost) until redline. It's all in the cams and boost control, for which I use a simple hallman mbc.
The Following User Says Thank You to jamesm For This Useful Post:
Sportsguy83 (02-06-2014)
Old 06-10-2014, 02:41 AM   #45
loafy777
Drives: 2014 Monogram FR-S
Sorry to dig up this old post but... @diss7, you mentioned having previous experience with the GT2876R or GT25/40R and how it wasn't a great choice on your ae86.
Would that be an equally poor choice on the FA20? I ask because I happen to have an unused GT25/40R .86ar sitting in my garage which makes the $950 savings a pretty enticing notion so long as it's not god awful.
Thoughts?
loafy777 is offline   Reply With Quote
Old 06-10-2014, 09:22 AM   #46
diss7
Drives: AE86, 2x GT86, TE27
If you've already got it, then try it.
diss7 is offline   Reply With Quote
Old 10-12-2014, 11:43 AM   #47
diodelphi
diodelphi's Avatar
Drives: 86
EFR 7163
Originally Posted by Mrc@ptuning View Post
Stick with the GT3076 .63 and you'll be happy for a while even with upping the boost down the road. We did not see any gains in power or spoolup on the GTX3071R vs the GT3076R both .63 A/R at around 310-320whp on the dyno. On paper you would expect the transient response to be slightly better with the 71 but it's not enough to tell with the butt dyno. The 30R really shine when you get into the 400whp range, where as the 28s will start to run out of steam.
I'm currently running the GTX3076R with my setup and the spoolup is a tad slower than the GT3076 but again transient response and spoolup seems the same on the road. The GT30R works great on this motor and gives you a lot of room to grow when you get that itch for more power. There's no one magic turbo to fit everyone's need. You just have to pick and choose your weapon based on the type of driving/racing you plan for your car.
You can't really choose a turbo based on how it performed on another motor/vehicle. For example, a GT30R on an Evo 8 4G63, is mediocre, where as that same turbo on a S2000 make awesome power--with the right turbo system setup of course. So I don't know if it makes sense to expect the same result from the same turbo on say an EJ25 vs FA20.
Do you have any idea about EFR 7163 in comparison with GTX2867 or GTX3076 ?
my target is 330whp (dynodynamics) on stock FA20 12.5 CR
diodelphi is offline   Reply With Quote
Old 10-13-2014, 12:37 PM   #48
Mrc@ptuning
Mrc@ptuning's Avatar
Drives: S1000RR
unfortunately, we have no idea on how the EFR turbo will perform against the GT turbos. That might be something we test out in the future.
Mrc@ptuning is offline   Reply With Quote
Old 10-13-2014, 02:34 PM   #49
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
There ya go @Mrc@ptuning @diodelphi
http://blog.perrinperformance.com/bo...test-and-tune/
The Following User Says Thank You to cdrazic93 For This Useful Post:
Mrc@ptuning (10-13-2014)
Old 10-13-2014, 04:27 PM   #50
Mrc@ptuning
Drives: S1000RR
Originally Posted by cdrazic93 View Post
A true test would be to have the same turbo system setup, ie. IC piping, intercooler, downpipe, WG, Exhaust, etc, with only the turbocharger being different. On top of that having the same tuner, atmospheric conditions and dyno to perform the comparison. That would be quite a bit of work
Old 10-14-2014, 02:31 AM   #51
diodelphi
diodelphi's Avatar
Drives: 86
Thanks PTuning
It seems EFR 7163 with single scroll setup for under 10psi is a good choice
Old 07-25-2016, 08:21 PM   #52
Andre Suwuh
Drives: Scion FRS Argento Manual
Taking it to drift
If the purpose of my car was to go to the track twice a month will a smaller turbo do me justice or is getting a bigger 3071R be better on the engine?
Andre Suwuh is offline   Reply With Quote
Old 07-26-2016, 09:23 AM   #53
Mrc@ptuning
Drives: S1000RR
That depends on what kind of power levels you're looking to run which also depends on the type of fuel you have access to. We'll be releasing our version 2 of our turbo system shortly with options to run the GTX2867 up to GTX3076R.
The Following User Says Thank You to Mrc@ptuning For This Useful Post:
Andre Suwuh (07-27-2016)
Old 07-27-2016, 01:40 AM   #54
Andre Suwuh
Well ill have access to 93 pump gas and a occasionally e85 For drifting on a stock motor plus uel headers and an oft stage 2 tune. I enter corners going in at 50-60 and rev from about 4.5k to 6k.
Old 07-27-2016, 10:19 AM   #55
Mrc@ptuning
Drives: S1000RR
What is your power goals. 300whp? more? You'll probably have to switch to ecutek for the tuning in order to be able to run flex fuel (e85). At this point you're probably leaning towards a GTX2867R.
Which turbine size for gtx3071r? diss7 Forced Induction 67 02-02-2014 08:19 PM
EFR6258 vs GTx2863R diss7 Forced Induction 25 12-01-2013 10:15 PM
Garrett GTX2863R turbo, TiAL v-band wastegate Turbowned Engine, Exhaust, Bolt-Ons 10 11-27-2013 02:07 PM
