#43 |
Aww but that's where I put my stiiickers!
Amanda - 2013 Scion FRS (Raven)
#44 |
#45 | |
Drives: FR-S 10 Series
Another fairly cheap mod is installing LEDs in the door get a wiring harness from a BRZ if you want it to look OEM. You could tap into your brake lights and light the triangle between the reverse lights for a low mount 4th taillight. You could put a thin strip of white LEDs and solder a mercury switch so it will light up the engine compartment at night if you have car problems, want to show off the boxer, or want to look for hp fuel pump crickets. Mudguards are another cheap mod.
#46 |
Drives: FRS
damn. that makes it look so much cleaner!
#47 |
Drives: UM86 - 6MT
OFT for $495
Use E85 + E85 map and you'll never want to go back ![]() Back roads will never be the same again. |
#48 |
Drives: Brz
#49 |
Drives: UM86 - 6MT
That is a bit of a broad question, what would you like to know specifically? I just picked mine up on 1/17/14. Ask away
| Simple mods to improve handling while improving looks? | Jinzen | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 06-07-2013 11:48 AM |
| Bullnettles simple mods build | Bullnettles | Member's Car Journals | 0 | 05-15-2013 03:15 PM |
| A not so simple question. | Asterisked Accolade | Tracking / Autocross / HPDE / Drifting | 10 | 01-18-2013 08:40 PM |
| Simple Question! | Spencer Strayer | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 09-09-2012 06:53 PM |
| simple tires? | jarviz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 08-02-2012 03:43 PM |
