Old 11-05-2012, 10:05 AM   #43
kanundrum
Drives: 2013 Whiteout FR-S
Notice that there is no article that is attached to your car the wing of 86 had seen the contents of the blog the other day, I I can not believe they did not have to introduce once though it is selling well in the rack ヾ I (__ *) reflection ... 86 introduce today is the customers who visit us for the first time last weekend, there was a stock happens to keep the vehicle on the spot, I was allowed to attached to the clear coating.
Good?
Although there are likes and dislikes, you say that you look good
Here are some images are also like this.
o you have a picture you've gotta get it out (__) o Peko~tsu
The following is a picture of the 86's in the showroom certain AREA86
Gazoo rack 86 is just 86 at the time of image
What color do you installed 86 if you? Assumption that I wear?
Thank you I'm sorry F (゚ ∀ ゚ F) Ahya
Old 11-05-2012, 10:05 AM   #44
kanundrum
86 yesterday as I was going to be the installation of a second ENDLESS caliper.
Mr. users we have installed last month, was set around MONO4, you may not be able to change the color now is MONO4
Mounted in gold color finish custom kits 6POT & RACING4 Caliper body is renewed at the beginning of this year, 6POT are becoming slimmer and lighter.
Caliper is part feature, of course, also has helped dress up the foot
A black wheel, brake system, except gold, I - I will glory in it to black body
It is sooo good to be tailored feel that I ride!
Try to experience the peace of mind that you also really Tomareru.
But ..... \ also be assured that will skip too (; ゚ ∇ ゚) /
Please note!
I also do not forget to say overwhelmingly shorter braking distance and safety as well as peace of mind ...
Is not it good ... brake overkill, but it is welcome who he did seem overkill to me but that.
Are you a good idea about shorter the braking distance I
It's also important to balance in sports driving,
There is also a matter of taste, so it please consult the feeling!
Old 12-03-2012, 12:08 AM   #45
kanundrum
I was allowed to attached def def mount color mount and support the sport of El 86. I will sell well in the easy installation.
When you attach the mount support people to travel this sport because of the rear mount has always torn, suppression of the movement of the differential is of course, a significant increase in the durability of the mount bush genuine
I was allowed to be seated classic metal catalyzer of SARD.
Located at the front of the catalyst in relation to the exhaust gas, the greater the resistance, more recent cars to spoil the performance.
Since the catalyst is attached to the exhaust manifold, 86 power loss more and more ...
Exhaust Manifold SARD less catalyst appeared soon, the second of SARD
Now also comes with a certificate so that it also supports inspection in the catalytic converter and mounting set.
Some people worry that is mounted ahead of the catalytic converter 2 already, so I can be put on after replacing the corresponding certificate.
I took the high-frequency field is much better from mid-range.
The item that I would stick to the aim Moapawa NA, want to come attached.
Old 12-03-2012, 12:09 AM   #46
kanundrum
Paper weight 86 ...
86 and a cool logo that is laser engraved crystal glass 5cm square
Such items or if the coveted 86 owner (o ^ - ^ o) Omission will be presented with a purchase more than $ 100 000 86 ... 86 product owner here this time.
There is no plan at the moment of sale.
Please forgive me, an amateur does not take pictures well, so Crystal
Spot is beautiful as Swarovski
Because there is a limited number on a first-come-first-served basis to
Old 12-03-2012, 12:09 AM   #47
kanundrum
Us to study a little ...
I tried to disassemble the FA20 engine.
As you may know, up to now, horizontally-opposed engine was belt drive, chain drive is changed from type F.
Independent left and right chain
Piston top is such a state to a engine that is not only riding several thousand kilometers.
It looks like this guys I gotta direct-injection engine.
Although the oil pump are common, the shape of the gear is changed a little.
I'm sorry, but I image you are a little blurred.
Also down the engine, gotta get off pretty easily, leaving the mission in this way.
Drop off in the rack, etc. This is how well Impreza ...
I wonder if people do not appear to say you want to put the hand to the engine body quickly
Let's make about HKS supercharged 400PS vehicle to enhance engine ~ ヽ ('▽ `) /
Old 12-03-2012, 08:16 AM   #48
Blue86
Drives: Sonic Blue 86GT Manual
Wow I didn't understand a word of that
Blue86 is offline   Reply With Quote
Old 12-03-2012, 11:18 AM   #49
Opposed
Drives: 2013 Asphalt FR-S
Or the post a few above this one by Kunundrum. What is going on in here?
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 12-03-2012, 11:20 AM   #50
kanundrum
Blame Google for the translations
As I said, google translations aren't the best
Old 07-23-2013, 02:52 PM   #51
kanundrum
Continuous the 2nd, Mars I am allowed to the installation of the oil cooler of freshly released Really sorry for those first rod is sold out for the time being, next time is I am waiting ... will be around at the end of the month now.
To apologize ...? I put out the image not in the instruction manual.
I and out of the blind in the thermostat near the lower radiator hose destination is taken out part of our products.
It is it's a hole in the hex.
Remove this, and the replacement nipple as this.
Blind cover is listed with the MT car cooler connections AT car, return side will be happy to replace our parts off it.
I do not know to be a little hard to understand. . . I am sorry.
I Remove the mounting ... oil filter also simplifies core body.
It is a core attachment there.
That's all there is to this feeling.
It is the cooling performance of this simple and fairly.
Thus when it with an oil block, put a sensor of the meter such
Can be installed without interference to the hood You can use the short filter JURAN.
My best regards because we offer good luck the number currently.
Old 07-23-2013, 02:54 PM   #52
kanundrum
Just a little late now, but will be released engine oil cooler BRZ & 86 for the (MT only) finally. The Company, to come and continue to the test in the harsh Japan Rally from the vehicle previously released by mounting a water-cooled early than anywhere, it has led to the launch to see the effect and reliability.
To simplify the most processing in less design at all full bolt-on, mounting also can be mounted in a short time structure.
I think in order to pull out some of the cooling water, it takes a little time to get air bleeding the last, to be able to in about two hours the mounting itself.
Water-cooled, pre shorter warm air rise of oil temperature as early as compared to air-cooled,
In addition, it is possible to run at a temperature that is stable in all seasons because there is no over-cool in winter.
I think you believe that water temperature and the water temperature rise is pulled oil temperature goes up also come, but it also is stable at a level almost no problem.
In addition, it is the oil sensor attachment to be used when the oil temperature, the oil pressure gauge and the like mounted, but that it uses a thin conventional non-FA20 commercial Making use thin oil element, is mounted on the cooler core meter sensor also can be mounted.
※ The image cooler core is different from the product for the prototype.
More data graphically There is not, Larry, mini circuit Fuji Speedway, such as different is stable up to 120 ℃ at most tested in situations.
And running style, also used by oil, etc. Because it is (our test data
Changes)
It is a cheap price (including tax) · · · ¥ 52.500 to suppress much.
Product delivery will be mid-July.
Please note that take your time because there is so we have gotten a lot of reservations already.
Old 07-23-2013, 02:55 PM   #53
kanundrum
It was somewhat slower but, VSC & TRC canceller delivery will start from early July finally. Feelings in the durability of the product, Nakano foundation also made of excellent domestic manufacturer, we have to improve the reliability.
VSC is becoming normal, and is canceled by holding down button, but not everything will be to cancel In fact, in sports driving, conditions that made it difficult to run intervention VSC is still are happening.
Full cancellation is possible in a separate way, but it has become a product that can be completely canceled with one button for quite troublesome.
You can easily attach relatively reduce the hassle of wiring can be part coupler on. Installation.
This thing that you run as I happily freely vehicle is excellent and can be ...
A switch with price is ¥ 16.800.
For Exclusively designed for competition, please do not use it in public roads.
Old 07-23-2013, 02:55 PM   #54
kanundrum
Today, I was allowed to 86 attached to the direct plasma became a major say about a staple of the ignition system parts in recent years. Plugs exchange incidentally!
I think muffler black case of direct injection specific you talk also previously prompted the complete combustion of even more plasma direct this ... but is mitigated just plug replacement, that it might be headed in a better direction.
For effect, because it is part that you can experience enough from the past track record
86 also should obtain a sufficient effect.
Image m that was received by the image of your FB (. ¯ ¯.) M vinegar Suimasen
In the Now, Mars and is wait for an order from you
Old 07-23-2013, 02:56 PM   #55
kanundrum
We have a lot of attachment request of the oil cooler to say about what units Innovation must've put between about January here Stand ... I do not know what 10 units or attached yet? 20 units? More? ? ?
Oil cooler installation time is speed up considerably thanks to the staff
I put in the GVB! Today
The water-cooled mounting it at BRZ today!
It will be TRUST oil cooler mounted HKS oil cooler, in 86 BRZ yesterday, I was allowed to delivered
HKS, TRUST, CUSCO has received an order quite a lot in the main, still attached to ... continues ヽ ('▽ `) /
Request of pretty tough 86 & BRZ oil temperature rise and there are quite a lot of (. _.) Thanks
Old 07-23-2013, 02:58 PM   #56
kanundrum
HKS has done it once again ... I was also introduced earlier manifold with catalytic converter.
GT-SPEC cheap
It seems tedious (but not be mounted that there is no equipment such as welding for the O2 sensor relocation ... )
· Introduced the set second catalytic converter of (front pipe) and exhaust manifold without catalytic converter that for the power-up further ... But, be R-SPEC time this is, as the inspection this is not the normal original muffler Because I do not ...
I take the person to say - It does not matter ...
Huh? The no good Why? Those who think it too many to be or be stay ...
It becomes a long time to hear even talk tears and talk tears · · ·
The front pipe BRZ & 86, when you replace with the rear muffler for sound absorber is attached to the catalyst other than, as it was through the acceleration volume test a set pursuant to the provisions of the current, however, is no good to judicial.
Second catalyst even if the exhaust gas test with goods outside your muffler is also a car inspection current, to say that Innovation is there such thing to say in a combination of rose and useless.
We would either be introduced soon in the pages of manufacturers.
Sorry to those who have already muffler replacement, where
The HKS, I will release the muffler set of SPEC-L and R-SPEC.
Price will be released in the set price ¥ 312.900 whopping R-SPEC ¥ 207.900 + SPEC-L ¥ 126.000 = 333.900.
The Mmm not stop there! ! ! ! !
ECU rewriting tool that was introduced the other day what "flash editor" ¥ 73.500
The GT-SPEC · R-SPEC · R-SPEC & SPEC-L full set respectively + ¥ 31.500 a
Out will be sold as a package.
To hasten the person you are having you study for an order of flash editor rather similar is expected!
It is supposed to be outrageous When you are satisfied with your order situation of flash editor to the previous HKS
If you would like to know more, please come to rack means.
Fart I will explain courteous (° ∀ ° F) Ahya
FR-S PARTS CATALOG SYSTEM IS UP AND RUNNING TPO Scion FR-S / Toyota 86 GT86 General Forum 96 06-03-2015 05:16 PM
LUCK Motorsport 86 ZetaVI Scion FR-S / Toyota 86 GT86 General Forum 18 04-04-2012 02:38 PM
Toyota 86 LUCK equipment Harinjo Scion FR-S / Toyota 86 GT86 General Forum 31 02-28-2012 02:18 PM
New Project x2 S2KtoFT86 Other Vehicles & General Automotive Discussions 9 10-25-2009 11:17 AM
