Old 12-24-2013, 09:10 PM   #43
bpracer
Drives: Asphalt FR-S
I got my new SU003-05176 fuel pump today in my FRS.
It is mechanically quieter than the first replacement pump, which took about two months for the crickets to resume.
I'm also thinking this is a lubricity issue with the alcohol laced fuel as somebody else mentioned.
I've been using TC-W3 oil on a regular basis but with no great success. I did double up on the mixture right before the last pump was to be installed and it did seem to help a little. Unfortunately, it also got colder, so I still don't have a valid test sample.
Time will tell...
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline   Reply With Quote
The Following User Says Thank You to bpracer For This Useful Post:
Mr.EvoMR (12-25-2013)
Old 12-24-2013, 10:12 PM   #44
ID86
Drives: FRS
Originally Posted by Mikem53 View Post
Congrats! Mine and many others had the chirping start at around 600 miles.
It's not that bad really.. Some DFI systems sounds are louder than others.
I agree the chirping isn't normal.. But it hasn't affected performance in any way.
Just another "distinctive" sound from this minimalistic sports car..
Uh oh. That's not good. I took delivery of the car with 7Mi..
And only have 31 miles now.
I hope that crickets doesn't come..
Maybe I should put some of these into my fuel if I do get it.
ID86 is offline   Reply With Quote
The Following User Says Thank You to ID86 For This Useful Post:
Guff (12-26-2013)
Old 12-25-2013, 06:06 PM   #45
fistpoint
Drives: Supercharged Golf Cart
Oh they will, look at the poll numbers. Many of those that voted "no crickets" came back to the thread to report they now have crickets...so the number of actual cases is higher than the results show.
Besides those that voted too early, you also have a bunch that have no idea what a cricket sounds like and insist their car sounds normal, whereas the rest of us would recognize the sound from blocks away and confirm they do in fact have it.
I'm confident that the crickets are damn near if not fully 100% for the U.S. cars.
fistpoint is offline   Reply With Quote
Old 12-25-2013, 07:00 PM   #46
Imrac
Drives: 13 SWP BRZ Prem
Every FRS/BRZ I have ever heard idle has had it (So probably around 30 or so cars)
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 12-26-2013, 01:37 AM   #47
strat61caster
strat61caster's Avatar
Mine and several others have gone away, there are members who report thousands of miles with no crickets (whaap comes to mind, maybe humfrz), I think the poll is accurate within 10% plus or minus, the majority of cars have crickets at some point or another.
Remember that a lot of people would never look at a forum for their car and have zero issues to report vs. people who would never look this place up until they had crickets, we won't get a true cross section of owners on a poll like this (not to mention that these kind of polls are rarely secure, someone could be screwing with the numbers either way). The internet amplifies negative responses, it's a simple truth.
ineedyourdiddly
Old 12-26-2013, 01:50 AM   #48
husker741
Originally Posted by Hakuzen View Post
So the dealership just showed me three other FR-S that all had the exact same sound. I'm stunned.
One was another 2014 that just got the new pump installed, like me. The other two were both brand new 2014s that still had factory seals. All three had the exact same sound.
At this point, I'm not sure what to think. I know for a fact my car never made this sound before I brought it in, but on the other hand the dealership was able to reproduce it on three seperate FR-S in stock as a normal sound.
I'm going to record the noise on my next cold start and post it up, maybe you guys can clear this up for me. I'm unsure if I should even bother taking it to another dealership, as it seems like they are likely to tell me the same thing.
Ill try and post the soundclip soon. Thanks for reading
I'm almost certain you are hearing the direct injection. It was probably masked by the chirping. It's an odd noise at first but then you learn it's the sound of the engine working correctly. Just make a video and post up to see if that's in fact what it is.
husker741 is offline   Reply With Quote
The Following User Says Thank You to husker741 For This Useful Post:
strat61caster (12-26-2013)
Old 12-27-2013, 01:50 PM   #49
Hakuzen
Drives: 2014 Scion FR-S
Hello,
I recorded the sound this morning.
http://chirb.it/shxygt (Noise first appears around 0:15)
Let me know what you guys think. My car did not make this noise previous to the HPFP install.
Hakuzen is offline   Reply With Quote
Old 12-27-2013, 01:56 PM   #50
husker741
Hello,
That does sound a little obnoxious. Do you RPMs raise?
Old 12-27-2013, 02:26 PM   #51
Hakuzen
Yes, the noise happens when I accelerate out of idle, and is no longer audible when the RPMS pass ~1800.
Keep in mind is that is being recorded from a phone that was sitting literally 6 inches away from the pump as I was pressing the gas pedal. Just for context. It doesn't sound nearly that bad from inside the cabin, just sounds like a mechanical clicking noise that is only audible in the lower RPMs as im accelerating from idle.
Old 12-29-2013, 06:50 PM   #52
kjdd787
Drives:
Toyota replaced my coil pack 1 day later total engine failure
kjdd787 is offline   Reply With Quote
The Following User Says Thank You to kjdd787 For This Useful Post:
Mr.EvoMR (12-29-2013)
Fuel pump sw20kosh Engine, Exhaust, Transmission 1 12-10-2013 10:21 PM
High Pressure Fuel Pump Difference? Toyota vs. Subaru 86_ZN6 Engine, Exhaust, Transmission 18 06-03-2013 06:48 AM
Fuel pump issue. sevi21 Issues | Warranty | Recalls / TSB 13 02-01-2013 09:57 AM
Car fuel pump on... Genomaxter Engine, Exhaust, Transmission 5 11-29-2012 10:06 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
