Old 12-04-2013, 10:04 AM   #43
utekineir
blowhard
Drives: frs, project forester
Originally Posted by subwaynm View Post
I'll keep that in mind; thanks
I just wish we had a little more mph without such high rpm's
Block your cabin noise pipe and pretend you don't hear the engine?
Not sure what to tell you, na 4 cyl aren't exactly something meant for low rpms.
If mpg is your rpm concern the car even with a manual can easily pull over 30 in highway driving despite the epa rating.
I average around 33, have seen a best of 36 and thats after ditching the low rolling resistance tires. Others here have claimed even higher.
not terrible for a cheap to maintain rwd toy
utekineir is offline   Reply With Quote
The Following User Says Thank You to utekineir For This Useful Post:
SirBrass (12-04-2013)
Old 12-04-2013, 10:43 AM   #44
subwaynm
subwaynm's Avatar
Drives: Scion FR-S Coupe
Thanks I'm sure I'll hit decent mpg; and for my purposes will have plenty of power. I'm not going to be racing the car.
subwaynm is offline   Reply With Quote
Old 12-04-2013, 10:46 AM   #45
FRiSson
Drives: FR-S MT
"Too close" not "To close".
And before you defenders of grammar ignorance pipe in your usual tripe... don't bore me.
FRiSson is offline   Reply With Quote
The Following User Says Thank You to FRiSson For This Useful Post:
Old 12-04-2013, 12:15 PM   #46
humfrz
Originally Posted by bestwheelbase View Post
MT 3.73
AT 4.10
DANG, bestwheelbase, one of us is having a brain fart on this differential ratio thing for the FR-S......
From what I read, the rear end ratio is 4:1, for both the MT and the AT.
Help me out here.....
humfrz
Old 12-04-2013, 12:28 PM   #47
Luis_GT
Unless you get a diesel, or a big V8, most cars will cruise at around 3000+ RPM
This car will hit 100mph at about 4000rpm in 6th gear
Old 12-04-2013, 12:45 PM   #48
R.S-HawK
Drives: '13 Gen Coupe 3.8 R
Originally Posted by Hanni_0176 View Post
I've never driven the AT, so maybe the acceleration from 70-100 mph is weak with the taller gears. My car is also lightly modded, and I never tried to take the car above 80 mph before the mods, so that may bias my experience. The temperatures are a bit colder right now, too. However, my car accelerates from 70-100 mph within a few seconds. Redlining in 4th gear takes me over 100 mph.
I've always been curious as to the redlines on the MT.
On the AT, 1st red lines at around 32mph, with 2nd redlining at 62-64mph, 3rd redlines at 86-87mph. I've only red-lined 4th once, so I cannot recall how that one ends.
5th and 6th? God knows. I don't think there is a straight away long enough to get that far.
R.S-HawK is offline   Reply With Quote
Old 12-04-2013, 01:01 PM   #49
subwaynm
subwaynm's Avatar
I guess some of this will rectify itself with break in . And so far I only have 375 miles on her so far. So the engine should loosen up afterward
Old 12-04-2013, 01:03 PM   #50
Luis_GT
MPH to RPM won't change with breakin...
unless you meant to write umph instead of mph
Old 12-04-2013, 01:18 PM   #51
bestwheelbase
Drives: 1985 P-Type
humfrz
It's probably me... I may be confusing USDM FRS specs for JDM 86 specs. We need to make a compilation of the various technical differences to eliminate my brain flatulence.
86 manual in Japan has 3.73, I know that's right.
Edit: You should see the badass list of components I'm creating to build my perfect car. Most of the components are things people never even see, but it's going to be so rad.
Old 12-04-2013, 05:57 PM   #52
humfrz
Yep, I understand ..... between my brain farts and senior moments ..... I too can confuse even myself ....
So, when can we expect to view this beast you are creating .... ??
humfrz
Old 12-04-2013, 07:38 PM   #53
bestwheelbase
Drives: 1985 P-Type
humfrz
Never be the first to a party. Always make a grand entrance.
The Following 2 Users Say Thank You to bestwheelbase For This Useful Post:
ae86stunt (12-04-2013), humfrz (12-04-2013)
Old 12-04-2013, 10:47 PM   #54
cycleboy
Drives: 2013 Scion FR-S - Argento
Can I boar yew? (As one w/ a bit of grammar/spelling OCD, I can relate.)
As to the original question, I don't find this car underpowered. The tires aren't very sticky and the speed limit is not above 65 hwy where I live. Taking a corner at 50 that's marked 25 (not speed limit, just the caution signs) is a total blast! Commuting, I usually shift at about 4K and get 31 mpg. Having fun, I wind it up to 5-6K+ and . Downshifting to pass is part of driving a stick.
cycleboy is offline   Reply With Quote
The Following User Says Thank You to cycleboy For This Useful Post:
Old 12-06-2013, 12:48 AM   #55
Rico415
Rico415's Avatar
Drives: 13FR-S
The Beetle & Supers came with the same engines yes , but the granny's were different. The Super came with a different Ring/Pinion(4:12 or 3:88) also a different final gear which was later dubbed the "Freeway Flyer".
http://www.thesamba.com/vw/archives/...sheet/back.jpg
Same gears , final drive ratio and top speed. 3.875 / 81mph
But it gets muddy... 71 ... 72 lists beetle and super both 4.125
http://www.thesamba.com/vw/archives/...tle/page14.jpg
Lists 4.125 final but top speed is still 81
Makes me brain hurt ...
Rico415 is offline   Reply With Quote
The Following User Says Thank You to Rico415 For This Useful Post:
subwaynm (12-06-2013)
Old 12-06-2013, 11:00 AM   #56
FRiSson
Drives: FR-S MT
That's raises an interesting question. Is there a difference in the minds of law enforcement (ticket worthiness) of surpassing the posted speed on a caution sign versus a speed limit sign?
asked dealer service manager about aftermarket/warranty NuckinFutsFR-S Issues | Warranty | Recalls / TSB 23 10-31-2012 09:24 AM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
