Old 09-04-2010, 10:53 PM   #43
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
I've been tempted to do my own lip for both the Supra and the Legacy but my landlord isn't too keen on me playing with hot-wire cutting styrofoam and mixing up epoxy on the premises... Don't want to kill the cat either.
I've got too many things to do and not enough time or space. Grrr!!!
Hey, I know what you mean... My neighbor has some of the machines that you have at work in his garage (I need to take some pic next weekend or something to show you what he has in his garage)... but he had a stroke and haven't had a time to teach me anything for long time. I would make some of custom parts for my car and all... but I don't have the knowledge to use the machine to make one.
Old 09-05-2010, 12:40 AM   #44
4agze
4agze's Avatar
Drives: Toyota Corolla SR5
Two things that I have trouble wrapping my head around on the AE86 is how the struts have the bearing integrated into them (making custom coilovers a bigger pain than they have to be?) and the solid axle. (What no rear camber adjustment?)
I don't follow a bearing on the struts?
rear camber for what? and why?
4agze is offline   Reply With Quote
Old 09-05-2010, 12:46 AM   #45
4agze
4agze's Avatar
I don't have any friends that own any tuning shop... but my friend's uncle owns a body shop... but we're talking bout high quality body shop (Porsche, Ferrari, & all those exotic cars) shop, so even they give me discount, it's still high up for me... but one day, I'll have enough $ to make my Impreza wide body (22B or GD style).
so I envy ya
wow 22B will be nice, my friend got a GC8 and we're just talking about what to do with his car. wait I send you a private msg about a GC8 question, few days ago maybe didn't went thru?
Old 09-05-2010, 12:55 AM   #46
Dimman
Kuruma Otaku
Dimman's Avatar
I don't know much about the AE86's strut, but most MacStuts don't look like that. I assumed the pin thing sticking out of the bottom is for a shaft for a wheel bearing or something? (Probably just talking out my ass right now... and looking like one.) I'm used to seeing struts with a lower bracket that bolts to the uprights. If I want to make some Koni-insert coilovers for my Legacy all I have to do is get some steel tubing, thread it for spring perches, weld a cap on the bottom with a hole for a 14mm(?) bolt and two tabs with two holes each to mount it to the upright.
I just really have no idea what that shaft/pin thing sticking out of the bottom of the AE86's strut is.
As for the rear camber, I don't know enough about a solid axle's geometry to know even if they need it. But I have heard of circle track guys going to elaborate measures to get a bit of rear camber.
For these two reasons I've stayed away from AE86s. I don't know enough about the funny struts and solid axles.
Because titanium.
Old 09-05-2010, 01:09 AM   #47
ichitaka05
Site Moderator
ichitaka05's Avatar
Yeah, I don't think I got it. If I get any PM, I usually reply asap. Sent em again
Old 09-05-2010, 01:19 AM   #48
4agze
4agze's Avatar
here is a FSM diagram of the front suspension, circle what you saw and I'll try to explain it or name it.
well rear camber usually is just adds grip on rear tires but the solid axles cars also have a way to add extra grip on the rear, like traction brackets. heres a pic from a forum member,its the silver bracket I have one also.
Old 09-05-2010, 01:56 AM   #49
Dimman
Kuruma Otaku
Dimman's Avatar
The part that confuses me looks like a shaft for the wheel bearings.
I'm used to seeing struts like this:
In this design the wheel bearings are in the upright.
As for the rear camber it reduces loss (or increases depending on the starting camber) of grip as the car rolls. But both tires on a sold axles are rigidly linked to each other so I'm assuming the behavior is different that what I'm used to.
Because titanium.
Old 09-05-2010, 02:35 AM   #50
4agze
4agze's Avatar
ahhh the spindle, yeah old school cars has the strut casing welded with spindle. its funny how a ae86 has less parts than the modern cars . yeah the solid rear vs independent rear are always a good debate, the feel and grip level but on modern cars independent rear is a must don't know why the mustangs are still solid rear .
Old 09-05-2010, 02:46 AM   #51
ichitaka05
Site Moderator
ichitaka05's Avatar
Cuz, they're morons!
It's same thing why Viper still using that 80's pos heavy cast-iron pushrod v10 instead of upgrading their engine & put some technology into it.
Old 09-05-2010, 02:57 AM   #52
Dimman
Kuruma Otaku
Dimman's Avatar
Not morons. Just cheap.
Because titanium.
Old 09-05-2010, 01:49 PM   #53
MtnDrvr86
Drives: 2002 honda civic ex
It does great on the track, the solid rear axle. But independant is better for bumbs in the corners.
MtnDrvr86 is offline   Reply With Quote
Old 09-05-2010, 03:48 PM   #54
4agze
4agze's Avatar
And they say the new vette still have lift springs? WTF
Old 09-05-2010, 05:29 PM   #55
Dimman
Kuruma Otaku
Dimman's Avatar
Totally different than old-school steel multi-leaf springs used to locate solid axles. The 'Vette's are transverse mounted and made out of composite materials. I don't fully understand why when there are perfectly good coils available, but they are pretty advanced and the 'Vettes handle pretty damn good.
Because titanium.
