Old 05-12-2017, 05:33 PM   #43
redlined600
redlined600's Avatar
Drives: Fr-s
I had read this thread before and it left me wondering how the heck could someone cross-thread these bolts? I get it now but still maintain that it’s not hard to install the inserts without cross-threading.
A couple tips I think could help:
-Jack the subframe back up against the body prior to putting the bolts in, don’t use the bolts to pull the subframe up.
- Use a flashlight and look up the hole to check if it’s aligned, if not, man-handle the subframe into position
- As countless others have stated, if you cannot thread the bolts in by hand something is misaligned.
Using the above and a prybar I was able to easily thread all the bolts in by hand far enough to ensure they were properly installed.
The Following 4 Users Say Thank You to redlined600 For This Useful Post:
JMon85 (05-12-2017), Marat (05-13-2017), strat61caster (05-12-2017), wheelhaus (05-13-2017)
Old 09-18-2018, 08:55 AM   #44
86TOYO2k17
Drives: 2017 toyota 86
so im not 100%, but i probably cross threaded my rear driver side. was a b*tch to get it in and aligned.
I put in the inserts and now sometimes usually when turning in/out of parking lots and hitting the little bumps rear end makes a little clunking sound.
also this may or may not be related to cross threading, but at 75+ car starts to vibrate a lot. i seen on another thread someone had same problem when they had motor mounts, trans collar, diff inserts, dss cf driveshaft, and then installed subframe inserts said it "broke the camels back"
either way im removing the inserts tomorrow. if i do need to tap the hole with a m14x1.5 do i need a new bolt that same size or does the stock one still work? ive never had to tap before.
Old 03-11-2025, 12:01 AM   #45
grippgoat
Drives: 2023 BRZ, 2018 Golf R 6MT
Necrooooo.
I messed up the forward right side one on my rear subframe to the point where I'm not sure it's save-able. I tried a thread chaser on it, and I think that made it worse, because it got misaligned and I couldn't tell right away. Forward right front might still be save-able, and I have a tap on the way to try.
Thoughts on just drilling and tapping for m16 or 5/8-18? The barrels in the subframe bushings have tons of clearance.
-Mike
grippgoat is offline   Reply With Quote
Whiteline rear subframe bushing install... fl_speed001 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 07-11-2020 12:29 AM
Whiteline KDT922 (Subframe Bushing Inserts) Grease - Safe to use on Rubber? eckoflyte Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-14-2018 11:24 AM
whiteline rear subframe inserts charged86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 05-18-2013 09:20 PM
Subframe/Drivetrain Thoughts.... TrackDog Scion FR-S / Toyota 86 GT86 General Forum 12 11-10-2011 10:53 PM
